Home » Modeling » M2T (model-to-text transformation) » Java Model Exception when executing Xtend functions(Whenever an Xtend function is invoked - whether for M2M Xtend transformations or M2T Xpand templates, a Java Model Exception is thrown)
Java Model Exception when executing Xtend functions [message #757252] Thu, 17 November 2011 05:57 Go to next message
Dear forum members,
I'm experiencing a rather frustrating Eclipse Console and log flooding with Java Model Exceptions, which I sadly have been unable to find a solution for.
I'm running a series of M2M and M2T transformations using Xtend and Xpand through Ant (same JRE as Eclipse). I'm starting Eclipse from another Eclipse instance, if that plays any role. It seems that whenever the Xtend engine is accessing an Ecore model, a Java Model Exception is thrown. But this does not hinder the corresponding Xtend function / Xpand define from executing correctly.
Do you have any idea why this could be happening?
Here is a typical stack trace I'm getting for each model access:
!ENTRY org.eclipse.xtend.ui 4 0 2011-11-17 11:39:15.481
!MESSAGE .org.eclipse.jdt.core.external.folders does not exist
!STACK 1
Java Model Exception: Java Model Status [.org.eclipse.jdt.core.external.folders does not exist]
	at org.eclipse.jdt.internal.core.JavaElement.newJavaModelException(JavaElement.java:502)
	at org.eclipse.jdt.internal.core.Openable.generateInfos(Openable.java:246)
	at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(JavaElement.java:515)
	at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:252)
	at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:238)
	at org.eclipse.jdt.internal.core.JavaProject.getJavaProjectElementInfo(JavaProject.java:1603)
	at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(JavaProject.java:2282)
	at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(JavaProject.java:2292)
	at org.eclipse.jdt.internal.core.JavaProject.findType(JavaProject.java:1321)
	at org.eclipse.jdt.internal.core.JavaProject.findType(JavaProject.java:1228)
	at org.eclipse.xtend.ui.core.internal.builder.PluginJavaExtensionStatement.analyzeInternal(PluginJavaExtensionStatement.java:48)
	at org.eclipse.internal.xtend.xtend.ast.AbstractExtension.analyze(AbstractExtension.java:126)
	at org.eclipse.internal.xtend.xtend.ast.ExtensionFile.analyze(ExtensionFile.java:116)
	at org.eclipse.xtend.ui.core.internal.XtendResourceImpl.analyze(XtendResourceImpl.java:49)
	at org.eclipse.internal.xpand2.ast.ExtensionImportDeclaration.analyze(ExtensionImportDeclaration.java:42)
	at org.eclipse.internal.xpand2.ast.Template.analyze(Template.java:126)
	at org.eclipse.xpand.ui.core.internal.XpandResourceImpl.analyze(XpandResourceImpl.java:45)
	at org.eclipse.xtend.shared.ui.core.AbstractResource.analyze(AbstractResource.java:90)
	at org.eclipse.xtend.shared.ui.core.internal.XtendXpandProject.analyze(XtendXpandProject.java:338)
	at org.eclipse.xtend.shared.ui.core.builder.XtendXpandBuilder.build(XtendXpandBuilder.java:201)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:629)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:172)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:203)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:255)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:258)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:311)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:343)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:242)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!SUBENTRY 1 org.eclipse.jdt.core 4 969 2011-11-17 11:39:15.482
Here is a short spec of my installation:
Eclipse Version: 3.6.2
eclipse.buildId=M20110210-1200
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments:  -product org.eclipse.platform.ide
Command-line arguments:  -product org.eclipse.platform.ide -data X:\eclipse_workspaces2\workspace_tools/../workspace_apps -dev file:X:/eclipse_workspaces2/workspace_tools/.metadata/.plugins/org.eclipse.pde.core/m2m/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
Any help is kindly appreciated!
Vitali
[Updated on: Thu, 17 November 2011 06:10] by Moderator
Re: Java Model Exception when executing Xtend functions [message #757261 is a reply to message #757252] Thu, 17 November 2011 06:57 Go to previous messageGo to next message
Hi Vitali!
Yes, the runtime Eclipse instance may play a role. Do you execute the transformation from within a plugin?
This may be something related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=338695
It seems that you have linked folders, from which elements are tried to access. Usually you will have linked folders for plugins that are in your development workspace and used in the runtime workspace.
Is this the case?
Kind regards,
~Karsten
Re: Java Model Exception when executing Xtend functions [message #757280 is a reply to message #757261] Thu, 17 November 2011 08:18 Go to previous message
Hi Karsten,
thanks for your quick answer!
Yes, I'm starting a runtime workbench from a workspace containing a couple of OSGi plugins, which are accessed by an Xtend workflow executed from an Ant script.
I have not explicitly configured any linked resources, but AFAIK Eclipse is implicitly creating linked folders for those plugins to be available in the runtime workbench. And the corresponding configuration is put to the <workspace>/.metadata/.plugins/org.eclipse.jdt.core/.org.eclipse.jdt.core.external.folders/.project file. Thus I guess, I can confirm that Smile
Vitali
Previous Topic:[Acceleo] Profile, Stereotype and getValue
Next Topic:[Acceleo] .mtl or .emtl?
Current Time: Sun Jul 27 08:03:13 EDT 2025
Powered by FUDForum. Page generated in 0.03604 seconds
