Enlarge click area for connections [message #729556] |
Mon, 26 September 2011 09:40  |
In my Editor, you add model objects by placing them on a connection. The problem is the click area for the connection is very small, so you have to aim precisly.
Is there possibility to enlarge the click area for a connection, for example return a rectangle as click area for connections?
I tried the getClickArea() in the BehaviourProvider, but you cannot create a rectangle there, you can only return existing graphic algorithms...
I would also be happy about workaround ideas, if the framework does not provide such a functioniolity.
Thanks!
FUDForum. Page generated in 0.30379 seconds
