Home » Archived » XML Schema Definition (XSD) » Need to update application schema, Please help.
Need to update application schema, Please help. [message #74904] Sun, 27 July 2008 05:01 Go to next message
Originally posted by: kalkar.prashant.gmail.com
I am using XML Schema, EMF, Teneo and hibernate for managing the
application persistent layer.
I am new to these technologies.
Currently the code for the persistent layer is already generated from
the XML Schema (XML Schema -> Ecore -> Model) and Teneo is used for
integrating with Hibernate.
Now I need to modify the current schema, need to add some new fields in
the existing tables and need to add some new tables.
I can update these changes in the XML Schema (XSD file). But I don't
know how to generate the corresponding Ecore file from the updated xsd
file, or is there any other way of doing this.
Can someone please help me.
Prashant
Re: Need to update application schema, Please help. [message #74918 is a reply to message #74904] Sun, 27 July 2008 12:23 Go to previous messageGo to next message
You need to right click the .genmodel and hit "Reload...".
Marcelo
Prashant Kalkar wrote:
> in the existing tables and need to add some new tables.
> Regards,
> Prashant
Re: Need to update application schema, Please help. [message #74929 is a reply to message #74904] Mon, 28 July 2008 00:36 Go to previous message
Hi Prashant,
If you right-click on the genmodel and choose reload then you can reload the xsd into the genmodel.
After reloading, regenerate the java classes (right-click on the epackage in the genmodel). Teneo
picks up the new ecore model automatically and will create a new mapping, hibernate will then update
the database (depends on the hbm2ddl setting). Note that hibernate in update mode add columns and
tables but does not add indexes.
gr. Martin
> Regards,
> Prashant
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Need to update application schema, Please help. [message #603151 is a reply to message #74904] Sun, 27 July 2008 12:23 Go to previous message
Marcelo
> Regards,
> Prashant
Re: Need to update application schema, Please help. [message #603154 is a reply to message #74904] Mon, 28 July 2008 00:36 Go to previous message
Hi Prashant,
gr. Martin
> Regards,
> Prashant
The Netherlands
Previous Topic:Need to update application schema, Please help.
Next Topic:XSD to Ecore order attributes
Current Time: Tue Jul 29 11:35:01 EDT 2025
Powered by FUDForum. Page generated in 0.05525 seconds
