Home » Archived » XML Schema Definition (XSD) » Loading chameleon schemas
Loading chameleon schemas [message #74773] |
Mon, 23 June 2008 16:42  |
Some schemas use the pattern of importing (or including) a schema that has
no targetNamespace into a schema that does have a namespace (aka chameleon
schemas). When using the XSD model to load these schemas, the imported
chameleon schema definitions are added to EACH schema that imports them. I
believe that this is correct from the perspective of the XSD infoset, but it
causes problems when I want to access and process the XSD definitions as
defined in each original schema. My use case is to transform the XSD to a
UML model that reflects the original schema modularity.
Is there any way to change this behavior when loading XSD so that a
chameleon schema is loaded only once with a null targetNamespace and
imported by the other XSDSchema components? Or, lacking that, some way to
load the chameleon schema and sort out which definitions in other schemas
are actually duplicate copies?
Dave Carlson
Re: Loading chameleon schemas [message #74827 is a reply to message #74810] |
Tue, 24 June 2008 14:58  |
--------------020300020006070009090201
Dave,
Comments below.
Dave Carlson wrote:
> Ed,
>>> has no targetNamespace into a schema that does have a namespace (aka
>>> chameleon schemas).
>> Only including has this effect.
> I had also thought that xsd:include must be used for chameleon schemas. But
> someone recently told me that the Oxygen XML editor throws an error for
> this, with a message that xsd:import should be used for chameleons. I
> checked the XSD specs (both 1.0 and 1.1) and it appears that either
> xsd:include or xsd:import may be used for this. The 'namespace' attribute
> is omitted when using xsd:import of a schema with no namespace.
An import is just an import. The original components will be imported
with the null namespace. Only an include will do the chameleon thing.
Are you going to believe Oxygen or me? :-P
>>> to load the chameleon schema and sort out which definitions in other
>>> schemas are actually duplicate copies?
>> Not really, no. It's a complex problem to untangle the impact of
>> chameleon includes. They suck.
> I couldn't agree more. I try to discourage designers from using chameleon
> schemas, but some still like the idea.
Tell them I consider it a foolish choice. Discourage the use of
redefine even more. That's so horrible I cringe at the mention of it.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Dave,<br>
<br>
Comments below.<br>
<br>
Dave Carlson wrote:
<blockquote cite="mid:g3r6hs$vto$1@build.eclipse.org" type="cite">
<pre wrap="">Ed,
</pre>
<blockquote type="cite">
<pre wrap="">Some schemas use the pattern of importing (or including) a schema that
chameleon schemas).
</pre>
</blockquote>
<pre wrap="">Only including has this effect.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
Are you going to believe Oxygen or me? :-P<br>
<pre wrap="">
</pre>
<pre wrap="">imported by the other XSDSchema components? Or, lacking that, some way
</pre>
</blockquote>
<pre wrap="">Not really, no. It's a complex problem to untangle the impact of
</pre>
</blockquote>
</pre>
</blockquote>
redefine even more. That's so horrible I cringe at the mention of it.<br>
<pre wrap="">
</pre>
</blockquote>
<br>
</body>
</html>
--------------020300020006070009090201--
Re: Loading chameleon schemas [message #603110 is a reply to message #74773] |
Mon, 23 June 2008 17:30  |
Dave,
Comments below.
> schemas).
Don't count on that. Decomposition in to .xsd files is completely
arbitrary from an abstract component point of view and the translation
is done at that level, not the syntactic level.
> Dave Carlson
Re: Loading chameleon schemas [message #603115 is a reply to message #74793] |
Tue, 24 June 2008 12:14  |
Ed,
>> chameleon schemas).
Re: Loading chameleon schemas [message #603119 is a reply to message #74810] |
Dave,
Comments below.
Dave Carlson wrote:
> Ed,
>>> chameleon schemas).
<html>
<head>
</head>
Dave,<br>
<br>
Comments below.<br>
<br>
<pre wrap="">Ed,
</pre>
chameleon schemas).
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<br>
</body>
</html>
Current Time: Fri Jul 18 03:14:20 EDT 2025
Powered by FUDForum. Page generated in 0.06851 seconds
