Home » Eclipse Projects » Technology Project and PMC » How to run properties view example
How to run properties view example [message #73975] Thu, 07 December 2006 04:21 Go to next message
Originally posted by: swetha.atc.tcs.co.in
I downloaded the propertyviewsample.zip ,unzipped and put it in the
Plugins directory.When I open Window>Show View>Other... and select "Sample
Category/Sample1 View",I get the following error:
java.lang.NoClassDefFoundError:
org/eclipse/ui/internal/dialogs/ListContentProvider
at mview.views.SampleView.createPartControl(SampleView.java:61)
at
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:332)
at
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:197)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:1675)
at
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:987)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:968)
at org.eclipse.ui.internal.WorkbenchPage$13.run(WorkbenchPage.j ava:3497)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3494)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3470)
at
org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHan dler.java:148)
at
org.eclipse.ui.handlers.ShowViewHandler.openOther(ShowViewHa ndler.java:104)
at
org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHand ler.java:70)
at org.eclipse.ui.internal.ShowViewMenu$3.run(ShowViewMenu.java :114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Currently I am using Eclipse 3.2.0...
Thanks in Advance..
Swetha
Re: How to run properties view example [message #74012 is a reply to message #73975] Thu, 07 December 2006 10:53 Go to previous message
Best to ask questions like this in the eclipse.newcomer newsgroup.
Swetha wrote:
> I downloaded the propertyviewsample.zip ,unzipped and ...
Re: How to run properties view example [message #601285 is a reply to message #73975] Thu, 07 December 2006 10:53 Go to previous message
Previous Topic:how to get the eclipse icons
Next Topic:Loading files from ext directory.
Current Time: Wed Jul 23 05:35:58 EDT 2025
Powered by FUDForum. Page generated in 0.04747 seconds
