[Xpand] dynamic EXPAND statement [message #725207] |
Wed, 14 September 2011 04:46  |
Some time ago, there was a request for a dynamic EXPAND statement that
takes the name of the template to be expanded from an expression instead
of a constant string. This was filed as bug 161915, then moved to the
oAW bugtracker, and I somehow lost track then. I could still use this
feature - are there any plans to implement it?
Volker
* Volker Wegert * http://www.volker-wegert.de/contact *
Re: [Xpand] dynamic EXPAND statement [message #725264 is a reply to message #725228] |
Wed, 14 September 2011 07:00   |
Karsten,
Am 14.09.11 12:08, schrieb Karsten Thoms:
> I don't think that we would realize this feature. It does not fit to the
> way Xpand works.
Thanks for the clarification.
> If you need to work around, follow the instructions Jörg was pointing at.
I think I've got it working now, but I'm wondering whether I could
improve this a bit more:
My current setup consists of a three-step workflow:
1. Generate an intermediate model from a source model
2. Generate code from both the source and the intermediate model
3. Read the generated code and insert it into attributes of the
intermediate model
(I'm not generating Java code here, but ABAP - that has to be treated in
a very different way. The next steps involve computing a dependency
graph and generating the individual objects of the intermediate model in
reverse order, but I digress...)
This approach in itself is already a workaround - I'd love to get rid of
the intermediate "generate code, write it to files and read the files"
steps and call the Xpand templates directly from Xtend, storing the
result into attributes of the intermediate model. So if there was a way
to write
method.setBody(expandTemplate("Foo:Bar", x, y)) ->
and expandTemplate would include some handwavium to evaluate the Xpand
template and return the result, that would be cool. Is it possible to
register some kind of outlet that does not write the generated source to
a file but that loops back to the class that runs the evaluation?
Volker
Re: [Xpand] dynamic EXPAND statement [message #725355 is a reply to message #725323] |
Wed, 14 September 2011 10:52  |
Am 14.09.11 16:14, schrieb Karsten Thoms:
> You can guess from the complexity of the workaround that your approach
> is something that is not the typical way to use Xpand. The natural way
> is to use static template invocation. But if really need it, an approach
> that works somehow is the right one.
I'd love to restrict myself to static template invocations with some AOP
magic, but that doesn't seem to be possible in this case - at least not
without duplicating large parts of the logic involved. I can only tell
which templates I have to invoke after the intermediate model is
generated, because during the generation of this model, a lot of
conditions are evaluated that control which parts of the code need to be
generated. I could duplicate that and make the decisions during the code
generation as well as during the model transformation, but that would be
even less maintainable.
On the other hand, everything I do here seems to be a less-than-typical
way to do stuff. You can take a look at
http://www.volker-wegert.de/en/mdd-sap-r3 if you're interested, I've
blogged about the entire process some time ago...
Thanks anyhow, I think I've got something to work with now.
Volker
FUDForum. Page generated in 0.46615 seconds
