[acceleo] please see the method named "registerPackages" in the Java launcher of your gene [message #705370] |
Fri, 29 July 2011 15:52  |
I´ve generated a new UI acceleo project, but in the generateAll() method, I want to create a new model in memory instead of reading from the emf model instance, like this
public void doGenerate(IProgressMonitor monitor) throws IOException {
if (!targetFolder.getLocation().toFile().exists()) {
targetFolder.getLocation().toFile().mkdirs();
monitor.subTask("Loading...");
PrestoFactory factory = PrestoFactory.eINSTANCE;
Sistema sistema = factory.createSistema();
sistema.setName("xxx");
sistema.setPacote("com.xxx.yyy");
TipoPlataforma tipo = TipoPlataforma.XXX;
sistema.setTipo(tipo);
xxx.main.Generate gen0 = new xxx.main.Generate(sistema, targetFolder.getLocation().toFile(), arguments);
//xxx.main.Generate gen0 = new xxx.main.Generate(modelURI, targetFolder.getLocation().toFile(), arguments);
monitor.worked(1);
String generationID = org.eclipse.acceleo.engine.utils.AcceleoLaunchingUtil.computeUIProjectID("xxx", "xxx.main.Generate", modelURI.toString(), targetFolder.getFullPath().toString(), new ArrayList<String>());
gen0.setGenerationID(generationID);
gen0.doGenerate(BasicMonitor.toMonitor(monitor));
so in the doGenerate() method (the last one above), I´ve got in the stage eclipse instance
"The generation fail to generate any file because there are no model elements that matches at least the type of the first parameter of one of your main templates."
and in the launcher eclipse instance
"!ENTRY org.eclipse.acceleo.engine 2 0 2011-07-29 16:48:20.682
!MESSAGE The generation fail to generate any file because there are no model elements that matches at least the type of the first parameter of one of your main templates.
The problem may be caused by a problem with the registration of your metamodel, please see the method named "registerPackages" in the Java launcher of your generator. "
This method is, of course
public void registerPackages(ResourceSet resourceSet) {
super.registerPackages(resourceSet);
* TODO If you need additional package registrations, you can register them here. The following line
* (in comment) is an example of the package registration for UML. If you want to change the content
* of this method, do NOT forget to change the "@generated" tag in the Javadoc of this method to
* "@generated NOT". Without this new tag, any compilation of the Acceleo module with the main template
* that has caused the creation of this class will revert your modifications. You can use the method
* "isInWorkspace(Class c)" to check if the package that you are about to register is in the workspace.
* To register a package properly, please follow the following conventions:
* if (!isInWorkspace(UMLPackage.class)) {
* // The normal package registration if your metamodel is in a plugin.
* resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
* } else {
* // The package registration that will be used if the metamodel is not deployed in a plugin.
* // This should be used if your metamodel is in your workspace and if you are using binary resource serialization.
* resourceSet.getPackageRegistry().put("/myproject/myfolder/mysubfolder/MyUMLMetamodel.ecore", UMLPackage.eINSTANCE);
however, It´s not clear to me what exactly should I do here. Should I add the code for my XXXPackage.class? In this case, how my acceleo eclipse project will "see" my generated EMF java classes?
Thanks in advance
Kenji
[Updated on: Fri, 29 July 2011 15:54] by Moderator
FUDForum. Page generated in 0.07558 seconds
