Exporting bundle project uses incorrect MANIFEST.MF [message #721601] |
Fri, 02 September 2011 05:04  |
When using "Export > EclipseRT > Bundle Project" (this is provided by Virgo, right?) I get this warning:
JAR export finished with warnings. See details for additional information.
ru.focusmedia.odp.ssd.db/src/META-INF/MANIFEST.MF was replaced by the generated MANIFEST.MF and is no longer in the JAR.
And the generated MANIFEST.MF is useless: the result actually isn't an OSGi bundle. Of course, I can get the correct result by "Export > Java > JAR file" and setting "Use existing manifest from workspace", but then I need to manually change version number in .jardesc. Is there a way to export Bundle Project correctly?
FUDForum. Page generated in 0.04555 seconds
