Home » Language IDEs » C / C++ IDE (CDT) » Debugger terminates unexpectantly
Debugger terminates unexpectantly [message #70780] Mon, 19 May 2003 18:08 Go to next message
Originally posted by: jmiller.incon.com
Hi folks,
Been working today on getting my cross development environment going on my
Power PC. Except for a little pesky snag where I had to modify the
mi.core plugin.xml, setting cpp to "ppc" .... the IDE is very slick!!! As
I step through code with the debugger, I get the following message:
../../insight-5.3/ui-out.c:130: gdb-internal-error: push_level: Assertion
`uiout->level >= 0 && uiout->level < MAX_UI_OUT_LEVELS' failed.
I found that they had this problem in the hurd user group and recommneded
cranking up MAX_UI_OUT_LEVELS. Originally set to 5, I raised it to 12,
which got me farther along debugging the "HelloWorld" demo, now I've
cranked it up to 32. At this point I'm able to completely step through
the entire program, but am sure that this not the best solution.
OS is Redhat8.0
Eclipse is latest and greatest as is cdt (2.1 and 1.1 respective, I think)
gdb is version5.3
Any suggestions on a more appropriate solution to the MAX_UI_OUT_LEVELS
issue?
cheers
Re: Debugger terminates unexpectantly [message #70860 is a reply to message #70780] Tue, 20 May 2003 11:12 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
CDT uses legitimate gdb commands to communicate with gdb. What you are
getting is an internal gdb error and has to be fixed in gdb.
BTW, are there messages in the gdb console? Check the "Show Debugger Console
On Target Selection" button of the "Debug" view's toolbar to switch between
the inferrior and gdb outputs.
"John Miller" <jmiller@incon.com> wrote in message
news:babklb$bv$1@rogue.oti.com...
> Hi folks,
> OS is Redhat8.0
> gdb is version5.3
> issue?
> cheers
Re: Debugger terminates unexpectantly [message #71022 is a reply to message #70860] Wed, 21 May 2003 09:20 Go to previous messageGo to next message
Hi Mikhail,
Yes, I did check the output, that is where the error message below comes
from, clueing me into the fact that maybe I should crank up
MAX_UI_OUT_LEVELS. I will post this on a GDB newsgroup to see if they
have any ideas. Regards
> > Hi folks,
> > OS is Redhat8.0
> > gdb is version5.3
> > issue?
> > cheers
Re: Debugger terminates unexpectantly [message #71041 is a reply to message #71022] Wed, 21 May 2003 10:55 Go to previous messageGo to next message
You can run Eclipse with tracing to find out which of gdb commands causes
the problem.
To run with tracing:
1. Create a file (for example, .options)
2. Add the following line to it:
org.eclipse.cdt.debug.mi.core/debug=true
3. Start Eclipse with
-debug "file:<full path>/.options"
You will see all gdb commands that CDT sends to gdb.
news:bafufh$ff8$1@rogue.oti.com...
> Hi Mikhail,
Console
between
> > > Hi folks,
on my
As
Assertion
recommneded
12,
through
> > > OS is Redhat8.0
think)
> > > gdb is version5.3
MAX_UI_OUT_LEVELS
> > > issue?
> > > cheers
Re: Debugger terminates unexpectantly [message #71140 is a reply to message #71041] Thu, 22 May 2003 12:26 Go to previous messageGo to next message
The gdb news groups seem to be dead so I searched on the Problem Reports
and found that a colleauge of yours was running into the same types of
problems, alain@qnx.com. S/He submitted PR\'s 1045 and 796, neither
which has been resolved yet. I also created a PR, #1223. The trace
information should be very useful, Thanks again.
> the problem.
> -debug \"file:<full path>/.options\"
> \"John Miller\" <jmiller@incon.com> wrote in message
> > Hi Mikhail,
> > > BTW, are there messages in the gdb console? Check the \"Show Debugger
> Console
> > > On Target Selection\" button of the \"Debug\" view\'s toolbar to switch
> between
> > > > Hi folks,
> on my
> > > > mi.core plugin.xml, setting cpp to \"ppc\" .... the IDE is very
slick!!!
> As
> Assertion
> > > > `uiout->level >= 0 && uiout->level < MAX_UI_OUT_LEVELS\' failed.
> recommneded
> 12,
> > > > which got me farther along debugging the \"HelloWorld\" demo, now I\'ve
> > > > cranked it up to 32. At this point I\'m able to completely step
> through
> > > > OS is Redhat8.0
> think)
> > > > gdb is version5.3
> MAX_UI_OUT_LEVELS
> > > > issue?
> > > > cheers
Re: Debugger terminates unexpectantly [message #71199 is a reply to message #70780] Thu, 22 May 2003 17:09 Go to previous messageGo to next message
Hi folks,
I solved this issue (with some help!). fetch the latest version of gdb
from the "Mainline" and the problem does not occur. the version I used is
insight+dejagnu-weekly-CVS-20030520.tar.bz2 from
ftp://sources.redhat.com/pub/gdb/snapshots/current/
thanks to those involved.
John
John Miller wrote:
> Hi folks,
> OS is Redhat8.0
> gdb is version5.3
> issue?
> cheers
Re: Debugger terminates unexpectantly [message #71219 is a reply to message #71140] Thu, 22 May 2003 17:11 Go to previous message
Hi folks,
John
John Miller wrote:
> > the problem.
> > > Hi Mikhail,
> > Console
> > between
> > > > > Hi folks,
> > on my
> slick!!!
> > As
> > Assertion
> > recommneded
> > 12,
I\'ve
> > through
> > > > > OS is Redhat8.0
> > think)
> > > > > gdb is version5.3
> > MAX_UI_OUT_LEVELS
> > > > > issue?
> > > > > cheers
Previous Topic:CDT with WSAD 5.0.0
Next Topic:Eclipse/CDT and embedded development
Current Time: Thu Sep 18 01:51:18 EDT 2025
Powered by FUDForum. Page generated in 0.05138 seconds
