Home » Eclipse Projects » Mylyn » superscript rendering
superscript rendering [message #70218] Mon, 06 July 2009 13:41 Go to next message
I am using WikiText for converting textile to html. I found it does not
detect superscript if there is no space ahead of it.
For example, ab^3^ will not be detected.
But on http://www.textism.com/tools/textile/index.php , it can detect it.
Does any one have some comment?
Thank you!
Re: superscript rendering [message #70241 is a reply to message #70218] Mon, 06 July 2009 14:43 Go to previous messageGo to next message
Yu,
This looks like a defect. Interestingly http://textile.thresholdstate.com/ requires a preceding space. It's likely
that this is a recent change to Textile. Please post a bug under Tools/Mylyn/WikiText at bugs.eclipse.org.
David
> Thank you!
Re: superscript rendering [message #70261 is a reply to message #70241] Mon, 06 July 2009 16:32 Go to previous messageGo to next message
I just reported it as a bug.
Btw, I also found that for -- . The following case doesn't work.
1) "a--b"
2) " -- "
3) "a --b"
It looks like "--" has to be surrounded with spaces and also requires char
before and after the spaces.
All these three cases works in http://textile.thresholdstate.com/ and
http://textism.com/tools/textile/index.php
Shall I report it as a bug also?
Thanks!
Re: superscript rendering [message #70280 is a reply to message #70261] Mon, 06 July 2009 16:41 Go to previous message
Yes, please report any such inconsistencies as a bug
Re: superscript rendering [message #598029 is a reply to message #70218] Mon, 06 July 2009 14:43 Go to previous message
Yu,
David
> Thank you!
Re: superscript rendering [message #598031 is a reply to message #70241] Mon, 06 July 2009 16:32 Go to previous message
1) "a--b"
2) " -- "
3) "a --b"
Thanks!
Re: superscript rendering [message #598039 is a reply to message #70261] Mon, 06 July 2009 16:41 Go to previous message
Previous Topic:Trac Timing and Estimation Plugin mylyn integration
Next Topic:Mylyn - Time tracking -> Bugzilla
Current Time: Tue Sep 16 08:50:22 EDT 2025
Powered by FUDForum. Page generated in 0.05212 seconds
