Home » Archived » EPF » XML XSD mismatch
XML XSD mismatch [message #665973] Mon, 18 April 2011 08:20 Go to next message
Hi together,
I've modeled the development process of my company in EPF 1.5.1.
Then I exported a XML of this process.
But this XML didn't match to the XML Schema you can download on the eclipse webpage. (http://www.eclipse.org/epf/tool_component/xml_schema.php)
The XML Editor returned an error, that the use of some attributes is not permitted. ('type' attribute)
How is this possible, I thought I can only export XMLs that confirm to the XSD.
IMHO I am neither permitted to do changes to the XML nor to the XSD, so how can I make them match together?
Thanks for your help!
Simon
[Updated on: Mon, 18 April 2011 08:20] by Moderator
Re: XML XSD mismatch [message #668112 is a reply to message #665973] Tue, 03 May 2011 15:21 Go to previous messageGo to next message
The schema published for EPF 1.5.1 is right one, and we have encountered no issue in parsing the exported data. EPF Composer 1.5.1(.1) Import from XML uses the same schema to parse the import XML data.
Please double check how you do your parsing and what it is the exactly error.
We have known some XML tools that could not parse the schema correctly due to the fact they do not correctly interpret the following tag with maxOccurs="unbounded".
We are also confident that the schema works as it has been verified by two other 3rd parties using it.
<xsd:choice minOccurs="0" maxOccurs="unbounded">
<xsd:element name="MandatoryInput" type="xsd:string"/>
<xsd:element name="Output" type="xsd:string"/>
<xsd:element name="AdditionallyPerformedBy" type="xsd:string"/>
<xsd:element name="OptionalInput" type="xsd:string"/>
<xsd:element name="Estimate" type="xsd:string"/>
<xsd:element name="EstimationConsiderations" type="xsd:string"/>
<xsd:element name="ToolMentor" type="xsd:string"/>
</xsd:choice>
Thanks very much.
Bing.
Re: XML XSD mismatch [message #670281 is a reply to message #668112] Fri, 13 May 2011 07:02 Go to previous messageGo to next message
Hi Bing,
the import in EPF Composer Import from XML works fine, so I'm quite sure the schema is correct.
Only if I want to validate the XML with the XSD over a XML-Editor it doesn't work.
And I tryed multiple Editors...
Error Message: "The document contains an attribute \'type\' for element <Method Package> that is not permitted." in this line:
<MethodPackage xsi:type="uma:ContentCategoryPackage" name="ContentCategories" id="_h7rrMAaWEeCQDPDO8aIUzg">
and xsi should be definde here: "<uma:MethodLibrary xmlns:xsi="w3.org/2001/XMLSchema-instance""
So is it possible to validate it via Editor, or do I have to use some special editor?
The XML is auto-generated and the XSD is downloaded, so there shouldn't be errors in. And I am using the correct versions of both!
Thanks very much!
Simon
Re: XML XSD mismatch [message #671835 is a reply to message #665973] Thu, 19 May 2011 02:45 Go to previous message
Hi together,
problem is solved, respectively there was no problem.
The Editor causes the error.
XML output from EPF and XSD are correct, so everythings just fine Smile
Best regards
Simon
Previous Topic:Installation Problem
Next Topic:Concept x Term Definition
Current Time: Wed Jul 23 05:26:09 EDT 2025
Powered by FUDForum. Page generated in 0.04106 seconds
