Home » Modeling » OCL » how to get all classes of one package?
how to get all classes of one package? [message #66683] Thu, 05 February 2009 17:22 Go to next message
Hi Group,
I need help, i want to know how to write an ocl query thats return all
classes of one determined package .
best regards
Re: how to get all classes of one package? [message #66704 is a reply to message #66683] Thu, 05 February 2009 23:54 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Victor,
Are you talking about an Ecore package or a UML package?
If the former, try evaluating
self.eClassifiers->select(instanceof(EClass))
on your package. If the latter,
self.ownedType->select(instanceof(Class))
HTH,
Christian
Victor Hugo wrote:
> Hi Group,
> best regards
Re: how to get all classes of one package? [message #66777 is a reply to message #66704] Sat, 07 February 2009 12:53 Go to previous messageGo to next message
what I want i something like that:
getAllClassesOfPackage: getAllClassesOfPackage(str:String) :
Set(Class) = Package.allInstances()->any(a | a.name =
str).allOwnedElements()
->select(a | a.oclIsTypeOf(Class)).oclAsType(Class)->asSet()
this query dont returns what i want because I use the complete name of
package, if I use just 'domain' this query runs correctly.
Someone know what should I do?
And I have doubt in another query, I need a query thats returns all
classes that have an stereotype applied, the name of stereotype should be
a parameter.
thanks a lot! =)
Re: how to get all classes of one package? [message #67319 is a reply to message #66777] Mon, 09 February 2009 11:01 Go to previous message
Hi, Victor,
I'm not sure that I understand fully. I think you want to search for
packages by qualified name? Also, allOwnedElements is recursive, so it
will also obtain classes that maybe you don't want:
- classes nested in other classifiers of the package
- classes in nested packages
How about this?
context NamedElement
def: getAllClassesOfPackage(qname : String) : Set(Class) =
Package.allInstances()->any(qualifiedName = qname).ownedType->
iterate(t : Type; c : Set(Class) = Set{} |
if t.oclIsKindOf(Class)
then c->including(t.oclAsType(Class))
else c
endif)
Note that OCL 2.0 doesn't provide a means to cast collection types (this
will be fixed by OCL 2.1).
If you're looking for a stereotype by name, then just change the "if"
condition using the Element::getAppliedStereotype(...) operation from
the Eclipse UML2 implementation
def: getAllClassesOfPackage(qname : String, stereotype: String) :
Set(Class) =
if not t.getAppliedStereotype(stereotype).oclIsUndefined()
else c
endif)
Assuming that the stereotype extends the Class metaclass, so that we are
implicitly checking that the type is a class.
HTH,
Christian
> getAllClassesOfPackage: getAllClassesOfPackage(str:String) : Set(Class)
> = Package.allInstances()->any(a | a.name = str).allOwnedElements()
> be a parameter.
> thanks a lot! =)
Previous Topic:Re: [EMF] How to create an instance of an ecore model
Next Topic:Re: Redefinition
Current Time: Sat Nov 01 07:13:53 EDT 2025
Powered by FUDForum. Page generated in 0.04467 seconds
