Auto-Reverse Engineering [message #665963] |
Mon, 18 April 2011 07:49  |
Dear All,
I'm trying to use the reverse engineering functionality in modisco. I want to know how to generate the reverse engineering class diagram from the source code. Currently, I've loaded all the source code in to eclipse and using the modisco, I discovered the KDM. Then, based on the KDM I discover the UML model. By using the papyrus, I drag and drop the model to get the class diagram.
Is it the 'drag and drop' classes is the only way to get the class diagram? or there is other way that I can generate the class diagram automatically. I really need your advice.
Thank you.
Re: Auto-Reverse Engineering [message #771113 is a reply to message #769788] |
Mon, 26 December 2011 05:47  |
As you can see in http://youtu.be/n2iF8y7U2AM, it works for me with the following configuration:
Eclipse Indigo SR1:
- Eclipse Platform 3.7.1
- MoDisco Model Filter (Incubation) 0.9.1.v201109150824
- MoDisco SDK (Incubation) 0.9.1.v201109150824
- MDT Papyrus - SDK: Runtime, Tools, Documentation and sources (Incubation) 0.8.1.v201109161105
You should try to use Indigo.
Grégoire Dupé
[Updated on: Mon, 26 December 2011 05:47] by Moderator
FUDForum. Page generated in 0.08991 seconds
