Home » Archived » Swordfish » IWAB0135E An unexpected error has occurred. 500 javax.xml.ws.WebServiceException(problem creating a composite webservice based on the flight reservation tutorial)
IWAB0135E An unexpected error has occurred. 500 javax.xml.ws.WebServiceException [message #555722] Fri, 27 August 2010 16:34 Go to next message
I am running the latest Eclipse SOA platform package ; eclipse helios. My platform is linux fedora 11 x64. I am trying to familiarize myself and understand the Eclipse SOA platform better by following the flight reservation tutorial that is covered in the swordfish webinar by oliver wolf. Building the first two static web services covered in the webinar goes with out any problems.
However i seem to be running into problems trying to build the composite web service. In the webinar Oliver Wolf mentions that we need to add a parameter to the OSGI framework, from what i could make out from the video this parameter is:
DrmiRegistryPort=4711
regardless of what port number i use for that parameter, i get the following error :
500
The following is output on my console when i try to submit the form data to the flight booking composite service.
Aug 27, 2010 4:16:53 PM org.eclipse.swordfish.plugins.planner.policy.PolicyBasedFilterStrategy filter
INFO: Filtering the interceptors with the followng list of policy based hints: []
INFO: Dropped interceptor org.eclipse.swordfish.plugins.compression.ConsumerRequestCompressionInterceptor@7b34c5ff from the list of valid interceptors.
INFO: Dropped interceptor org.eclipse.swordfish.plugins.compression.ConsumerResponseDecompressionInterceptor@54c9f997 from the list of valid interceptors.
INFO: Dropped interceptor org.eclipse.swordfish.plugins.compression.ProviderRequestDecompressionInterceptor@34115512 from the list of valid interceptors.
INFO: Dropped interceptor org.eclipse.swordfish.plugins.compression.ProviderResponseCompressionInterceptor@71ce5e7a from the list of valid interceptors.
INFO: Dropped interceptor org.eclipse.swordfish.internal.core.interceptor.CxfDecoratingInterceptor@54e0d16b from the list of valid interceptors.
Aug 27, 2010 4:16:54 PM org.eclipse.swordfish.samples.flightbooking.FlightBookingImpl bookFlight
INFO: Executing operation bookFlight
Aug 27, 2010 4:16:54 PM org.apache.cxf.configuration.spring.ConfigurerImpl getBeanName
INFO: Could not determine bean name for instance of class org.apache.servicemix.cxf.transport.nmr.NMRConduit.
Aug 27, 2010 4:16:54 PM org.eclipse.swordfish.plugins.cxf.support.NMROutputStream sendOutputMessage
INFO: {ResponseContext={}, RequestContext={java.lang.reflect.Method=public abstract java.lang.String org.eclipse.swordfish.samples.flightreservation.FlightReservation.reserveFlight(org.eclipse.swordfish.samples.flightreservation.FlightData), org.apache.cxf.jaxws.context.WrappedMessageContext.SCOPES={org.apache.cxf.message.Message.ENDPOINT_ADDRESS=APPLICATION}, org.apache.cxf.message.Message.ENDPOINT_ADDRESS=nmr:FlightReservationService}}
INFO: [MessageInfo INPUT{http://www.eclipse.org/swordfish/samples/FlightReservation/}reserveFlight]
INFO: true
INFO: public abstract java.lang.String org.eclipse.swordfish.samples.flightreservation.FlightReservation.reserveFlight(org.eclipse.swordfish.samples.flightreservation.FlightData)
INFO: true
INFO: false
INFO: {SOAPAction=["http://www.eclipse.org/swordfish/samples/FlightReservation/reserveFlight"]}
INFO: [null]
INFO: UTF-8
INFO: nmr:FlightReservationService
INFO: {}
INFO: {org.apache.cxf.message.Message.ENDPOINT_ADDRESS=APPLICATION}
INFO: org.apache.cxf.service.model.BindingMessageInfo@2e1df471
INFO: text/xml
INFO: []
Aug 27, 2010 4:16:54 PM org.eclipse.swordfish.plugins.cxf.support.NMROutputStream createNMRMessageExchange
INFO: Invoking serviceinterface org.eclipse.swordfish.samples.flightreservation.FlightReservation
INFO: Create messageExchange{http://www.eclipse.org/swordfish/samples/FlightReservation/}FlightReservationService
INFO: Exchange endpoint {http://www.eclipse.org/swordfish/samples/FlightReservation/}FlightReservationService
INFO: setup message contents on Message []
INFO: service for exchange {http://www.eclipse.org/swordfish/samples/FlightReservation/}FlightReservationService
INFO: Sending message
null
Aug 27, 2010 4:16:54 PM org.eclipse.swordfish.plugins.planner.policy.PolicyBasedFilterStrategy filter
Aug 27, 2010 4:16:54 PM org.apache.servicemix.nmr.management.ManagementEndpointRegistry exchangeSent
WARNING: No managed endpoint registered with id: 497936a8-d6cc-457c-9785-c8c9b1daaab2
Aug 27, 2010 4:16:54 PM org.apache.commons.httpclient.HttpMethodDirector executeWithRetry
INFO: I/O exception (java.net.ConnectException) caught when processing request: Connection refused
INFO: Retrying request
Aug 27, 2010 4:16:54 PM org.apache.servicemix.common.AsyncBaseLifeCycle processExchangeInTx
SEVERE: Error processing exchange org.apache.servicemix.jbi.runtime.impl.InOutImpl@f8db08
java.net.ConnectException: Connection refused
	at java.net.PlainSocketImpl.socketConnect(Native Method)
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:310)
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:176)
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:163)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:384)
	at java.net.Socket.connect(Socket.java:542)
	at java.net.Socket.connect(Socket.java:492)
	at java.net.Socket.<init>(Socket.java:389)
	at java.net.Socket.<init>(Socket.java:263)
	at org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:80)
	at org.apache.commons.httpclient.protocol.DefaultProtocolSocketFactory.createSocket(DefaultProtocolSocketFactory.java:122)
	at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707)
	at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361)
	at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387)
	at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
	at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
	at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346)
	at org.apache.servicemix.http.processors.ProviderProcessor.process(ProviderProcessor.java:160)
	at org.apache.servicemix.soap.SoapEndpoint.process(SoapEndpoint.java:368)
	at org.apache.servicemix.common.AsyncBaseLifeCycle.doProcess(AsyncBaseLifeCycle.java:627)
	at org.apache.servicemix.common.AsyncBaseLifeCycle.processExchange(AsyncBaseLifeCycle.java:581)
	at org.apache.servicemix.common.AsyncBaseLifeCycle.processExchangeInTx(AsyncBaseLifeCycle.java:478)
	at org.apache.servicemix.common.AsyncBaseLifeCycle$2.run(AsyncBaseLifeCycle.java:347)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
	at java.lang.Thread.run(Thread.java:636)
Aug 27, 2010 4:16:54 PM org.eclipse.swordfish.plugins.planner.policy.PolicyAssertionHintExtractor extractHints
WARNING: Couldn't extract hints from terminated (status == DONE) message exchange!
Aug 27, 2010 4:16:54 PM org.apache.cxf.phase.PhaseInterceptorChain doIntercept
INFO: Interceptor has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Could not send Message.
	at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:64)
	at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:220)
	at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:466)
	at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:299)
	at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:251)
	at org.apache.cxf.frontend.ClientProxy.invokeSync(ClientProxy.java:73)
	at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:124)
	at $Proxy160.reserveFlight(Unknown Source)
	at org.eclipse.swordfish.samples.flightbooking.FlightBookingImpl.bookFlight(FlightBookingImpl.java:50)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:616)
	at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:136)
	at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:82)
	at org.apache.cxf.jaxws.JAXWSMethodInvoker.invoke(JAXWSMethodInvoker.java:54)
	at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:68)
	at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:56)
	at org.apache.cxf.workqueue.SynchronousExecutor.execute(SynchronousExecutor.java:37)
	at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:92)
	at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:78)
	at org.apache.servicemix.cxf.transport.nmr.NMRDestination.process(NMRDestination.java:116)
	at org.apache.servicemix.nmr.core.InternalEndpointWrapper.process(InternalEndpointWrapper.java:86)
	at org.apache.servicemix.nmr.core.ChannelImpl.process(ChannelImpl.java:255)
	at org.apache.servicemix.nmr.core.ChannelImpl$1.run(ChannelImpl.java:215)
Caused by: java.io.IOException: Remote service error
	at org.eclipse.swordfish.plugins.cxf.support.NMROutputStream.sendOutputMessage(NMROutputStream.java:102)
	at org.eclipse.swordfish.plugins.cxf.support.NMROutputStream.doClose(NMROutputStream.java:77)
	at org.apache.cxf.io.CachedOutputStream.close(CachedOutputStream.java:167)
	at org.apache.cxf.transport.AbstractConduit.close(AbstractConduit.java:66)
	at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:62)
	... 28 more
javax.xml.ws.WebServiceException: org.apache.cxf.interceptor.Fault: Could not send Message.
	at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:142)
Caused by: org.apache.cxf.interceptor.Fault: Could not send Message.
	... 22 more
	... 28 more
INFO: Application has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: javax.xml.ws.WebServiceException: org.apache.cxf.interceptor.Fault: Could not send Message.
	at org.apache.cxf.service.invoker.AbstractInvoker.createFault(AbstractInvoker.java:119)
	at org.apache.cxf.jaxws.AbstractJAXWSMethodInvoker.createFault(AbstractJAXWSMethodInvoker.java:83)
	at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:107)
Caused by: java.lang.RuntimeException: javax.xml.ws.WebServiceException: org.apache.cxf.interceptor.Fault: Could not send Message.
	at org.eclipse.swordfish.samples.flightbooking.FlightBookingImpl.bookFlight(FlightBookingImpl.java:66)
	... 14 more
Caused by: javax.xml.ws.WebServiceException: org.apache.cxf.interceptor.Fault: Could not send Message.
	... 20 more
	... 22 more
	... 28 more
Aug 27, 2010 4:16:54 PM org.apache.servicemix.http.jetty.JCLLogger warn
WARNING: /FlightBookingService/
	... 14 more
	... 20 more
	... 22 more
	... 28 more
I suppose i will be working on resolving this issue for the next few days but if anyone has any insight into this error i would appreciate your feedback on this forum and would like to thank you in advance.
best regards,
ante
Re: IWAB0135E An unexpected error has occurred. 500 javax.xml.ws.WebServiceException [message #555891 is a reply to message #555722] Mon, 30 August 2010 01:54 Go to previous messageGo to next message
Hi Ante,
the rmiRegistryPort parameter influences the way the JMX support is initialized and has (as you discovered) no effect on your problem.
My impression is that your flight reservation provider has not been started (or startup has not finished yet. That's why you get the "Connection refused" error.
The OSGi runtime and the underlying web service support needs a bit time to start up. You might just have pushed the button a bit too early.
You can check if the services are ready by typing the ss command in the OSGi console. All listed bundles (except those that refer to a master) should be active.
Cheers
Jürgen
[Updated on: Mon, 30 August 2010 02:31] by Moderator
Re: IWAB0135E An unexpected error has occurred. 500 javax.xml.ws.WebServiceException [message #641650 is a reply to message #555722] Fri, 26 November 2010 09:06 Go to previous message
Hi Ante,
I am running it on a win32 and I've got the same error. The log looks slightly different, though, that's why I'll post it here two.
By the way waiting didn't work for me and all the consumers are up and running.
INFO: Overriding bean definition for bean 'configurationService': replacing [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class [org.eclipse.swordfish.internal.core.configuration.ConfigurationServiceImpl]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [bundleentry://39.fwk5184781/META-INF/spring/configuration-service.xml]]
26.11.2010 15:00:15 org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@c5122f: defining beans [mbeanServer,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,rmiRegistry,jmxConnectorService,jmxConnectorEnvironment,jaasAuthenticator,propertyConfigurer]; root of factory hierarchy
26.11.2010 15:00:15 org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager findServiceDependencies
INFO: 1 OSGi service dependencies, 0 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.nmr.osgi, config=osgibundle:/META-INF/spring/*.xml)
26.11.2010 15:00:15 org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor stageOne
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.nmr.osgi, config=osgibundle:/META-INF/spring/*.xml)
26.11.2010 15:00:15 org.springframework.beans.factory.support.DefaultListableBeanFactory registerBeanDefinition
INFO: Overriding bean definition for bean 'configurationAdmin': replacing [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
26.11.2010 15:00:15 org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@c16b18]: org.springframework.beans.factory.support.DefaultListableBeanFactory@148e798
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@cb07ef: defining beans [servicemix,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,flowRegistry,org.apache.servicemix.nmr.osgi.OsgiServiceRegistryTracker#0,listenerRegistry,org.apache.servicemix.nmr.osgi.OsgiServiceRegistryTracker#1,endpointRegistry,internalEndpointRegistry,org.apache.servicemix.nmr.osgi.OsgiServiceRegistryTracker#2,wireRegistry,org.apache.servicemix.nmr.osgi.OsgiServiceRegistryTracker#3,authorizationService,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#1,authorizationEntries,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#2,authenticationService,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#3,executorFactory,org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#0]; root of factory hierarchy
INFO: 3 OSGi service dependencies, 1 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.core.configuration, config=osgibundle:/META-INF/spring/*.xml)
26.11.2010 15:00:15 org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean registerService
INFO: Publishing service under classes [{org.apache.servicemix.nmr.api.NMR}]
26.11.2010 15:00:15 org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager$DependencyServiceListener serviceChanged
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=PaymentProcessingConsumer, config=osgibundle:/META-INF/spring/*.xml)
INFO: Publishing service under classes [{org.apache.servicemix.nmr.api.security.AuthorizationService}]
26.11.2010 15:00:15 org.springframework.osgi.extender.internal.ContextLoaderListener addAnnotationBPP
INFO: Disabled automatic Spring-DM annotation processing; [ org.springframework.osgi.extender.annotation.auto.processing=null]
26.11.2010 15:00:15 org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@e06ce: display name [OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.kernel.jaas.config, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1cd280b: defining beans [cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,org.apache.cxf.resource.ResourceManager,org.apache.cxf.configuration.Configurer,org.apache.cxf.binding.BindingFactoryManager,org.apache.cxf.transport.DestinationFactoryManager,org.apache.cxf.transport.ConduitInitiatorManager,org.apache.cxf.wsdl.WSDLManager,org.apache.cxf.phase.PhaseManager,org.apache.cxf.workqueue.WorkQueueManager,org.apache.cxf.buslifecycle.BusLifeCycleManager,org.apache.cxf.endpoint.ServerRegistry,org.apache.cxf.endpoint.ServerLifeCycleManager,org.apache.cxf.endpoint.ClientLifeCycleManager,org.apache.cxf.transports.http.QueryHandlerRegistry,org.apache.cxf.endpoint.EndpointResolverRegistry,org.apache.cxf.headers.HeaderManager,org.apache.cxf.catalog.OASISCatalogManager,org.apache.cxf.endpoint.ServiceContractResolverRegistry,org.apache.cxf.binding.soap.SoapBindingFactory,org.apache.cxf.binding.soap.SoapTransportFactory,org.apache.cxf.binding.soap.customEditorConfigurer,org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean#0,org.eclipse.swordfish.plugins.cxf.support.NMRTransportFactoryWrapper,org.eclipse.swordfish.plugins.cxf.support.NMRStreamReplacingInterceptor#0,PaymentProcessingClient.proxyFactory,PaymentProcessingClient,org.apache.servicemix.common.osgi.EndpointExporter#0,org.apache.servicemix.http.HttpEndpoint#0]; root of factory hierarchy
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@180a8b7: display name [OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.resolver.backend.remote, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Publishing service under classes [{org.apache.servicemix.nmr.api.security.AuthorizationEntry}]
INFO: Publishing service under classes [{javax.management.MBeanServer}]
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.jbi.deployer, config=osgibundle:/META-INF/spring/*.xml)
26.11.2010 15:00:15 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [bundleentry://63.fwk5184781/META-INF/spring/endpoint-provider-remote.xml]
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.nmr.management, config=osgibundle:/META-INF/spring/*.xml)
INFO: Loading XML bean definitions from URL [bundleentry://64.fwk5184781/META-INF/spring/servicemix-jaas.xml]
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@e06ce]: org.springframework.beans.factory.support.DefaultListableBeanFactory@a010ba
INFO: 2 OSGi service dependencies, 0 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.kernel.jaas.config, config=osgibundle:/META-INF/spring/*.xml)
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.kernel.jaas.config, config=osgibundle:/META-INF/spring/*.xml)
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@a010ba: defining beans [config,realms,proxyLoginModuleInitializer,keystoreManager,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,keystores]; root of factory hierarchy
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@c2ee15: defining beans [deployer,endpointListener,listener,jbiHandler,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#1,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#2,namingStrategy,managementAgent,adminService,adminCommandsService,installationService,deploymentService,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#3,environment,transactionManagers,namingContext,mbeanServer,preferencesService,org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#0]; root of factory hierarchy
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1f2cea2: defining beans [mbeanServer,endpointRegistry,namingStrategy,managementAgent,endpoints,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0]; root of factory hierarchy
INFO: Publishing service under classes [{org.apache.servicemix.nmr.api.security.AuthenticationService}]
26.11.2010 15:00:15 org.springframework.osgi.context.support.AbstractOsgiBundleApplicationContext publishContextAsOsgiServiceIfNecessary
INFO: Publishing application context with properties (org.springframework.context.service.name=org.apache.servicemix.nmr.osgi)
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@180a8b7]: org.springframework.beans.factory.support.DefaultListableBeanFactory@c12474
INFO: Publishing service under classes [{org.apache.servicemix.kernel.jaas.config.KeystoreManager}]
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.http, config=osgibundle:/META-INF/spring/*.xml)
INFO: 2 OSGi service dependencies, 1 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.resolver.backend.remote, config=osgibundle:/META-INF/spring/*.xml)
INFO: Not publishing application context with properties (org.springframework.context.service.name=org.apache.servicemix.kernel.jaas.config)
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.core.configuration, config=osgibundle:/META-INF/spring/*.xml)
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@97d3f0: display name [OsgiBundleXmlApplicationContext(bundle=FlightReservationConsumer, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@1566a6c: display name [OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.common, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Loading XML bean definitions from URL [bundleentry://65.fwk5184781/META-INF/spring/jaxws-consumer.xml]
INFO: Loading XML bean definitions from URL [bundleresource://33.fwk5184781/META-INF/cxf/cxf.xml]
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@136bdda: display name [OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.jbi.osgi, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@a166bd: display name [OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.core.event, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Loading XML bean definitions from URL [bundleentry://75.fwk5184781/META-INF/spring/servicemix-jbi.xml]
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@136bdda]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1cdfd19
INFO: 4 OSGi service dependencies, 1 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.jbi.osgi, config=osgibundle:/META-INF/spring/*.xml)
INFO: Publishing service under classes [{org.apache.servicemix.nmr.api.event.ExchangeListener, org.apache.servicemix.nmr.api.event.Listener}]
INFO: Not publishing application context with properties (org.springframework.context.service.name=org.apache.servicemix.nmr.management)
INFO: Publishing service under classes [{org.osgi.service.url.URLStreamHandlerService}]
INFO: Loading XML bean definitions from URL [bundleresource://33.fwk5184781/META-INF/cxf/cxf-extension-soap.xml]
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@166340c: defining beans [servicemix-http,servicemix-http-configuration,executorFactory,endpoint-tracker,authenticationService,keystoreManager,endpoints,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#0]; root of factory hierarchy
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@1db9f45: display name [OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.core, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Loading XML bean definitions from URL [bundleresource://7.fwk5184781/META-INF/org/eclipse/swordfish/plugins/cxf/support/nmr-transport.xml]
INFO: Loading XML bean definitions from URL [bundleentry://67.fwk5184781/META-INF/spring/bootstrap-interceptors.xml]
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@148e798: defining beans [configurationConsumerRegistry,configurationConsumerList,configurationAgent,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,pollableConfigurationSourceRegistry,pollableConfigurationSourceList,configurationService,configurationAdmin,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#1]; root of factory hierarchy
INFO: Publishing service under classes [{org.apache.servicemix.kernel.filemonitor.DeploymentListener}]
INFO: Publishing service under classes [{org.apache.servicemix.nmr.api.event.EndpointListener, org.apache.servicemix.nmr.api.event.ExchangeListener, org.apache.servicemix.nmr.api.event.Listener}]
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@14bc4e6: display name [OsgiBundleXmlApplicationContext(bundle=FlightBookingProvider, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Publishing service under classes [{org.apache.servicemix.jbi.deployer.AdminCommandsService}]
INFO: Not publishing application context with properties (org.springframework.context.service.name=org.apache.servicemix.jbi.deployer)
INFO: Loading XML bean definitions from URL [bundleentry://71.fwk5184781/META-INF/spring/event-service.xml]
INFO: Loading XML bean definitions from URL [bundleentry://74.fwk5184781/META-INF/spring/cxf-endpoint.xml]
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@1566a6c]: org.springframework.beans.factory.support.DefaultListableBeanFactory@b8d09d
INFO: Loading XML bean definitions from URL [bundleentry://67.fwk5184781/META-INF/spring/exchange-listener.xml]
INFO: Overriding bean definition for bean 'nmr': replacing [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
INFO: Overriding bean definition for bean 'swordfishContext': replacing [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
INFO: Loading XML bean definitions from URL [bundleentry://67.fwk5184781/META-INF/spring/service-proxy.xml]
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@97d3f0]: org.springframework.beans.factory.support.DefaultListableBeanFactory@84aa02
INFO: 0 OSGi service dependencies, 0 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.common, config=osgibundle:/META-INF/spring/*.xml)
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.common, config=osgibundle:/META-INF/spring/*.xml)
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@178efd8: display name [OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.document, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Loading XML bean definitions from URL [bundleentry://67.fwk5184781/META-INF/spring/swordfish-registries.xml]
INFO: Publishing service under classes [{org.eclipse.swordfish.core.configuration.access.ConfigurationAgent, org.eclipse.swordfish.core.event.EventHandler}]
INFO: Publishing service under classes [{org.eclipse.swordfish.core.configuration.ConfigurationService}]
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.resolver.backend.remote, config=osgibundle:/META-INF/spring/*.xml)
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@a166bd]: org.springframework.beans.factory.support.DefaultListableBeanFactory@15b4ad2
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@b8d09d: defining beans []; root of factory hierarchy
INFO: Not publishing application context with properties (org.springframework.context.service.name=org.apache.servicemix.common)
INFO: 1 OSGi service dependencies, 0 unsatisfied for OsgiBundleXmlApplicationContext(bundle=FlightReservationConsumer, config=osgibundle:/META-INF/spring/*.xml)
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=FlightReservationConsumer, config=osgibundle:/META-INF/spring/*.xml)
INFO: Overriding bean definition for bean 'swordfishContext': replacing [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class [org.eclipse.swordfish.internal.core.context.SwordfishContextImpl]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [bundleentry://67.fwk5184781/META-INF/spring/swordfish-registries.xml]]
INFO: Overriding bean definition for bean 'eventService': replacing [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean]; scope=singleton; abstract=false; lazyInit=false; autowireCandidate=true; autowireMode=0; dependencyCheck=0; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@1db9f45]: org.springframework.beans.factory.support.DefaultListableBeanFactory@ecf608
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@14bc4e6]: org.springframework.beans.factory.support.DefaultListableBeanFactory@f36e59
INFO: 2 OSGi service dependencies, 0 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.core.event, config=osgibundle:/META-INF/spring/*.xml)
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.core.event, config=osgibundle:/META-INF/spring/*.xml)
INFO: Loading XML bean definitions from URL [bundleentry://83.fwk5184781/META-INF/spring/servicemix-document.xml]
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@178efd8]: org.springframework.beans.factory.support.DefaultListableBeanFactory@867fad
INFO: 0 OSGi service dependencies, 0 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.document, config=osgibundle:/META-INF/spring/*.xml)
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.document, config=osgibundle:/META-INF/spring/*.xml)
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@15b4ad2: defining beans [eventService,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,eventHandlerRegistry,eventHandlerList,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#1,eventAdmin]; root of factory hierarchy
INFO: Publishing service under classes [{org.eclipse.swordfish.core.event.EventService}]
26.11.2010 15:00:15 org.eclipse.swordfish.internal.core.event.EventHandlerRegistry doRegister
INFO: Registering event listener for [org/eclipse/runtime/swordfish/TrackingEvent] topic
INFO: Registering event listener for [org/eclipse/runtime/swordfish/ConfigurationEvent] topic
INFO: Publishing service under classes [{org.eclipse.swordfish.internal.core.event.EventHandlerRegistry}]
INFO: Publishing application context with properties (org.springframework.context.service.name=org.eclipse.swordfish.core.event)
26.11.2010 15:00:15 org.apache.servicemix.kernel.filemonitor.FileMonitor start
INFO: Starting to monitor the deploy directory: .\deploy every 500 millis
INFO: Config directory is at: .\etc
INFO: Will generate bundles from expanded source directories to: .\data\generated-bundles
INFO: 1 OSGi service dependencies, 0 unsatisfied for OsgiBundleXmlApplicationContext(bundle=FlightBookingProvider, config=osgibundle:/META-INF/spring/*.xml)
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=FlightBookingProvider, config=osgibundle:/META-INF/spring/*.xml)
INFO: Publishing service under classes [{javax.jbi.component.Component}]
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@84aa02: defining beans [cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,org.apache.cxf.resource.ResourceManager,org.apache.cxf.configuration.Configurer,org.apache.cxf.binding.BindingFactoryManager,org.apache.cxf.transport.DestinationFactoryManager,org.apache.cxf.transport.ConduitInitiatorManager,org.apache.cxf.wsdl.WSDLManager,org.apache.cxf.phase.PhaseManager,org.apache.cxf.workqueue.WorkQueueManager,org.apache.cxf.buslifecycle.BusLifeCycleManager,org.apache.cxf.endpoint.ServerRegistry,org.apache.cxf.endpoint.ServerLifeCycleManager,org.apache.cxf.endpoint.ClientLifeCycleManager,org.apache.cxf.transports.http.QueryHandlerRegistry,org.apache.cxf.endpoint.EndpointResolverRegistry,org.apache.cxf.headers.HeaderManager,org.apache.cxf.catalog.OASISCatalogManager,org.apache.cxf.endpoint.ServiceContractResolverRegistry,org.apache.cxf.binding.soap.SoapBindingFactory,org.apache.cxf.binding.soap.SoapTransportFactory,org.apache.cxf.binding.soap.customEditorConfigurer,org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean#0,org.eclipse.swordfish.plugins.cxf.support.NMRTransportFactoryWrapper,org.eclipse.swordfish.plugins.cxf.support.NMRStreamReplacingInterceptor#0,FlightReservationClient.proxyFactory,FlightReservationClient,org.apache.servicemix.common.osgi.EndpointExporter#0,org.apache.servicemix.http.HttpEndpoint#0]; root of factory hierarchy
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@c12474: defining beans [configurationService,configurationInjectorRemote,wsdlReader,registryProxyFactory,registryProxy,swordfishRegistryProvider,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0]; root of factory hierarchy
INFO: Publishing application context with properties (org.springframework.context.service.name=org.eclipse.swordfish.core.configuration)
26.11.2010 15:00:15 org.eclipse.swordfish.core.configuration.access.ConfigurationInjector afterPropertiesSet
INFO: Injecting configuration [{priority=2, registryURL=http://localhost:9001/registry}] for the configurationConsumer with id = [org.eclipse.swordfish.internal.resolver.backend.remote.SwordfishRegistryProvider]
INFO: Not publishing application context with properties (org.springframework.context.service.name=org.apache.servicemix.http)
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@867fad: defining beans [documentRepository,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0]; root of factory hierarchy
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@1f4cdd2: display name [OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.resolver.policy, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: Publishing service under classes [{org.apache.servicemix.document.DocumentRepository, org.osgi.service.url.URLStreamHandlerService}]
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.apache.servicemix.jbi.osgi, config=osgibundle:/META-INF/spring/*.xml)
INFO: Not publishing application context with properties (org.springframework.context.service.name=org.apache.servicemix.document)
INFO: Loading XML bean definitions from URL [bundleentry://89.fwk5184781/META-INF/spring/policy-processing.xml]
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@f36e59: defining beans [cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,org.apache.cxf.resource.ResourceManager,org.apache.cxf.configuration.Configurer,org.apache.cxf.binding.BindingFactoryManager,org.apache.cxf.transport.DestinationFactoryManager,org.apache.cxf.transport.ConduitInitiatorManager,org.apache.cxf.wsdl.WSDLManager,org.apache.cxf.phase.PhaseManager,org.apache.cxf.workqueue.WorkQueueManager,org.apache.cxf.buslifecycle.BusLifeCycleManager,org.apache.cxf.endpoint.ServerRegistry,org.apache.cxf.endpoint.ServerLifeCycleManager,org.apache.cxf.endpoint.ClientLifeCycleManager,org.apache.cxf.transports.http.QueryHandlerRegistry,org.apache.cxf.endpoint.EndpointResolverRegistry,org.apache.cxf.headers.HeaderManager,org.apache.cxf.catalog.OASISCatalogManager,org.apache.cxf.endpoint.ServiceContractResolverRegistry,org.apache.cxf.binding.soap.SoapBindingFactory,org.apache.cxf.binding.soap.SoapTransportFactory,org.apache.cxf.binding.soap.customEditorConfigurer,org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean#0,org.eclipse.swordfish.plugins.cxf.support.NMRTransportFactoryWrapper,org.eclipse.swordfish.plugins.cxf.support.NMRStreamReplacingInterceptor#0,FlightReservationClient.proxyFactory,FlightReservationClient,PaymentProcessingClient.proxyFactory,PaymentProcessingClient,flightBookingServiceBean,flightBookingService,org.apache.servicemix.common.osgi.EndpointExporter#0,org.apache.servicemix.http.HttpEndpoint#0]; root of factory hierarchy
INFO: Refreshing org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@10c94a7: display name [OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.ws.wsdlgenerator, config=osgibundle:/META-INF/spring/*.xml)]; startup date [Fri Nov 26 15:00:15 CET 2010]; root of context hierarchy
INFO: 8 OSGi service dependencies, 1 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.core, config=osgibundle:/META-INF/spring/*.xml)
INFO: Publishing service under classes [{org.eclipse.swordfish.core.configuration.ConfigurationConsumer, org.eclipse.swordfish.core.resolver.registry.EndpointDocumentProvider}]
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1cdfd19: defining beans [componentRegistry,managementContext,environment,nmrWrapper,org.apache.servicemix.nmr.osgi.OsgiServiceRegistryTracker#0,nmr,documentRepository,transactionManagers,mbeanServers,namingContext,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0]; root of factory hierarchy
26.11.2010 15:00:15 org.eclipse.swordfish.internal.core.configuration.ConfigurationConsumerRegistry doRegister
INFO: Registering configurationConsumer with id = org.eclipse.swordfish.internal.resolver.backend.local.FilesystemDocumentProvider
INFO: Loading XML bean definitions from URL [bundleresource://33.fwk5184781/META-INF/cxf/cxf-extension-policy.xml]
INFO: Publishing application context with properties (org.springframework.context.service.name=org.eclipse.swordfish.plugins.resolver.backend.local)
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@1f4cdd2]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1bb8694
26.11.2010 15:00:15 org.eclipse.swordfish.internal.core.configuration.ManagedServiceAdapter updated
INFO: Received configuration [{priority=1, wsdlStorage=[bundleresource://8.fwk5184781/wsdl/BookingServiceImpl.zip, bundleresource://8.fwk5184781/wsdl/FlightServiceImpl.zip, bundleresource://8.fwk5184781/wsdl/ReservationStorageService.zip, bundleresource://8.fwk5184781/wsdl/ReservationService.zip], service.pid=org.eclipse.swordfish.internal.resolver.backend.local.FilesystemDocumentProvider}] for the configurationConsumer with id = [org.eclipse.swordfish.internal.resolver.backend.local.FilesystemDocumentProvider]
INFO: Loading XML bean definitions from URL [bundleentry://92.fwk5184781/META-INF/spring/wsdlgenerator.xml]
INFO: Bean factory for application context [org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext@10c94a7]: org.springframework.beans.factory.support.DefaultListableBeanFactory@fd9b97
26.11.2010 15:00:15 org.apache.servicemix.jbi.runtime.impl.ComponentRegistryImpl doRegister
INFO: JBI component registered with properties: {NAME=servicemix-http, TYPE=binding-component, objectClass=[Ljava.lang.String;@152b6f5, service.id=83}
26.11.2010 15:00:16 org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean registerService
26.11.2010 15:00:16 org.eclipse.swordfish.internal.core.configuration.ConfigurationConsumerRegistry doRegister
INFO: Registering configurationConsumer with id = org.eclipse.swordfish.internal.resolver.backend.remote.SwordfishRegistryProvider
26.11.2010 15:00:16 org.springframework.osgi.context.support.AbstractOsgiBundleApplicationContext publishContextAsOsgiServiceIfNecessary
INFO: Publishing application context with properties (org.springframework.context.service.name=org.eclipse.swordfish.plugins.resolver.backend.remote)
26.11.2010 15:00:16 org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager findServiceDependencies
INFO: 2 OSGi service dependencies, 0 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.resolver.policy, config=osgibundle:/META-INF/spring/*.xml)
26.11.2010 15:00:16 org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor stageOne
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.resolver.policy, config=osgibundle:/META-INF/spring/*.xml)
26.11.2010 15:00:16 org.apache.servicemix.nmr.management.ManagementEndpointRegistry register
INFO: Registering endpoint: org.apache.servicemix.nmr.core.InternalEndpointWrapper@252a40b5 with properties {NAME=servicemix-http, TYPE=binding-component, objectClass=[Ljava.lang.String;@c0fc8e, service.id=93}
26.11.2010 15:00:16 org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1bb8694: defining beans [cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,org.apache.cxf.resource.ResourceManager,org.apache.cxf.configuration.Configurer,org.apache.cxf.binding.BindingFactoryManager,org.apache.cxf.transport.DestinationFactoryManager,org.apache.cxf.transport.ConduitInitiatorManager,org.apache.cxf.wsdl.WSDLManager,org.apache.cxf.phase.PhaseManager,org.apache.cxf.workqueue.WorkQueueManager,org.apache.cxf.buslifecycle.BusLifeCycleManager,org.apache.cxf.endpoint.ServerRegistry,org.apache.cxf.endpoint.ServerLifeCycleManager,org.apache.cxf.endpoint.ClientLifeCycleManager,org.apache.cxf.transports.http.QueryHandlerRegistry,org.apache.cxf.endpoint.EndpointResolverRegistry,org.apache.cxf.headers.HeaderManager,org.apache.cxf.catalog.OASISCatalogManager,org.apache.cxf.endpoint.ServiceContractResolverRegistry,org.apache.cxf.ws.policy.AssertionBuilderRegistry,org.apache.cxf.ws.policy.PolicyConstants,org.apache.cxf.ws.policy.PolicyInterceptorProviderRegistry,org.apache.cxf.ws.policy.attachment.external.DomainExpressionBuilderRegistry,org.apache.cxf.ws.policy.attachment.external.EndpointReferenceDomainExpressionBuilder,org.apache.cxf.ws.policy.PolicyBuilder,org.apache.cxf.ws.policy.PolicyEngine,org.apache.cxf.ws.policy.attachment.wsdl11.Wsdl11AttachmentPolicyProvider,org.apache.cxf.ws.policy.attachment.ServiceModelPolicyProvider,org.apache.cxf.ws.policy.mtom.MTOMAssertionBuilder,org.apache.cxf.ws.policy.mtom.MTOMPolicyInterceptorProvider,configurationService,planner,configurationInjectorPDP,resourceToStringConverterPS.url,resourceToStringConverterPS,fsPolicyDefinitionProvider,wsPolicyBuilder,wsPolicyExtractor,wsPolicyIntersector,wsPolicyProcessor,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#1,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#2,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#3,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#4]; root of factory hierarchy
26.11.2010 15:00:16 org.eclipse.swordfish.internal.resolver.backend.local.WSDLManagerImpl setupWSDLs
INFO: portType = {http://cxf.samples.swordfish.eclipse.org/}BookingService
INFO: portType = {http://service.dynamic.samples.swordfish.eclipse.org/}FlightService
INFO: portType = {http://jaxws.demo.swordfish.eclipse.org/}ReservationStorage
INFO: Publishing service under classes [{org.apache.servicemix.jbi.runtime.ComponentRegistry}]
26.11.2010 15:00:16 org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager$DependencyServiceListener serviceChanged
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.core, config=osgibundle:/META-INF/spring/*.xml)
INFO: 3 OSGi service dependencies, 1 unsatisfied for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.ws.wsdlgenerator, config=osgibundle:/META-INF/spring/*.xml)
INFO: portType = {http://reservation.jaxws.samples.swordfish.eclipse.org/}ReservationService
26.11.2010 15:00:16 org.eclipse.swordfish.internal.core.configuration.ManagedServiceAdapter updated
INFO: Received configuration [{priority=2, service.pid=org.eclipse.swordfish.internal.resolver.backend.remote.SwordfishRegistryProvider, registryURL=http://localhost:9001/registry}] for the configurationConsumer with id = [org.eclipse.swordfish.internal.resolver.backend.remote.SwordfishRegistryProvider]
INFO: Not publishing application context with properties (org.springframework.context.service.name=org.apache.servicemix.jbi.osgi)
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@ecf608: defining beans [loggingInterceptor,cxfDecoratingInterceptor,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,endpointResolverInterceptor,serviceResolverRegistry,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#1,swordfishContext,serviceResolvers,componentRegistry,nmr,exceptionNotificationSender,exchangeListener,eventService,planner,registry,internalProxy,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#2,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#3,exceptionListenerRegistry,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#4,exceptionListenerList,configurationService]; root of factory hierarchy
INFO: Publishing service under classes [{org.eclipse.swordfish.core.Interceptor}]
INFO: Publishing service under classes [{org.eclipse.swordfish.internal.core.resolver.ServiceResolverRegistry}]
INFO: Publishing service under classes [{org.eclipse.swordfish.core.proxy.ServiceProxy}]
INFO: Publishing service under classes [{org.eclipse.swordfish.core.SwordfishContext}]
INFO: Publishing service under classes [{org.eclipse.swordfish.internal.core.exception.InterceptorExceptionListenerRegistry}]
INFO: Publishing application context with properties (org.springframework.context.service.name=org.eclipse.swordfish.core)
26.11.2010 15:00:16 org.eclipse.swordfish.core.configuration.access.ConfigurationInjector afterPropertiesSet
INFO: Injecting configuration [{policyStorage=bundleresource://89.fwk5184781/policies/Policies.zip}] for the configurationConsumer with id = [org.eclipse.swordfish.internal.resolver.policy.definitions.provider.FilesystemPolicyDefinitionProvider]
INFO: Publishing service under classes [{org.apache.cxf.Bus}]
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.ws.wsdlgenerator, config=osgibundle:/META-INF/spring/*.xml)
INFO: Publishing service under classes [{org.eclipse.swordfish.core.configuration.ConfigurationConsumer, org.eclipse.swordfish.core.resolver.policy.PolicyDefinitionProvider}]
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@fd9b97: defining beans [org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean#0,org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean#1,httpEndpointListener,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,deployedAssemblyList]; root of factory hierarchy
INFO: Publishing service under classes [{org.eclipse.swordfish.plugins.ws.wsdlgenerator.HttpEndpointListener}]
INFO: Publishing application context with properties (org.springframework.context.service.name=org.eclipse.swordfish.plugins.ws.wsdlgenerator)
INFO: Registering configurationConsumer with id = org.eclipse.swordfish.internal.resolver.policy.definitions.provider.FilesystemPolicyDefinitionProvider
INFO: Received configuration [{policyStorage=bundleresource://89.fwk5184781/policies/Policies.zip, service.pid=org.eclipse.swordfish.internal.resolver.policy.definitions.provider.FilesystemPolicyDefinitionProvider}] for the configurationConsumer with id = [org.eclipse.swordfish.internal.resolver.policy.definitions.provider.FilesystemPolicyDefinitionProvider]
INFO: Publishing service under classes [{org.eclipse.swordfish.core.resolver.policy.builder.PlatformPolicyBuilder}]
INFO: Publishing service under classes [{org.eclipse.swordfish.core.resolver.policy.PolicyExtractor}]
INFO: No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplicationContext(bundle=org.eclipse.swordfish.plugins.planner.policy, config=osgibundle:/META-INF/spring/*.xml)
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@4b82d2: defining beans [policyExtractor,hintExtractor,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,filterStrategy,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#1]; root of factory hierarchy
INFO: Publishing service under classes [{org.eclipse.swordfish.core.planner.strategy.HintExtractor}]
INFO: Publishing service under classes [{org.eclipse.swordfish.core.planner.strategy.FilterStrategy, org.eclipse.swordfish.core.planner.strategy.Strategy}]
Previous Topic:The Eclipse BPEL Designer Project - what's the deal here?
Next Topic:FlightBooking demo not working
Current Time: Sun Jul 27 11:55:14 EDT 2025
Powered by FUDForum. Page generated in 0.07053 seconds
