Home » Language IDEs » Java Development Tools (JDT) » Help about JST
Help about JST [message #638956] Sat, 13 November 2010 16:57 Go to next message
I got a problem when I was trying to use the AST, here is the code,
protected CompilationUnit parse(char[] sourceArray) {
ASTParser parser = ASTParser.newParser(AST.JLS3);
parser.setKind(ASTParser.K_COMPILATION_UNIT);
parser.setSource(sourceArray);
parser.setResolveBindings(true);
return (CompilationUnit) parser.createAST(null);
I got the error below:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/core/resources/IResource
at org.eclipse.jdt.core.dom.ASTParser.<init>(ASTParser.java:176)
at org.eclipse.jdt.core.dom.ASTParser.newParser(ASTParser.java: 125)
at Analyzer.parse(Analyzer.java:96)
at Analyzer.analyzing(Analyzer.java:55)
at API_RM.main(API_RM.java:7)
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.resources.IResource
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 5 more
I have already include the JDT variable(List below) by adding the external variable and also the "org.eclipse.equinox.common_3.6.0.v20100503.jar" from ECLIPSE_HOME. Am I missing something? Why I got the problem?
Please help me out to get this done.
Thanks for your help in advance.
Kam
External variable added
org.eclipse.ant.launching_1.0.0.v20100427.jar
org.eclipse.ant.ui_3.5.0.v20100427.jar
org.eclipse.jdt.apt.core_3.3.401.R36_v20100727-0110.jar
org.eclipse.jdt.apt.pluggable.core_1.0.301.R36_v20100727-011 0.jar
org.eclipse.jdt.apt.ui_3.3.300.v20100513-0845.jar
org.eclipse.jdt.compiler.apt_1.0.300.v20100513-0845.jar
org.eclipse.jdt.compiler.tool_1.0.100.v_A68_R36x.jar
org.eclipse.jdt.core.manipulation_1.3.0.v20100520-0800.jar
org.eclipse.jdt.core_3.6.1.v_A68_R36x.jar
org.eclipse.jdt.debug.ui_3.5.0.v20100602-0830.jar
org.eclipse.jdt.debug_3.6.1.v20100715_r361.jar
org.eclipse.jdt.doc.user_3.6.1.r361_v20100721-0800.jar
org.eclipse.jdt.junit.core_3.6.1.r361_v20100825-0800.jar
org.eclipse.jdt.junit.runtime_3.4.200.v20100526-0800.jar
org.eclipse.jdt.junit_3.6.1.r361_v20100825-0800.jar
org.eclipse.jdt.junit4.runtime_1.1.100.v20100526-0800.jar
org.eclipse.jdt.launching.macosx_3.2.100.v20100505.jar
org.eclipse.jdt.launching.ui.macosx_1.0.100.v20100505.jar
org.eclipse.jdt.launching_3.5.100.v20100526.jar
org.eclipse.jdt.ui_3.6.1.r361_v20100825-0800.jar
org.eclipse.jdt_3.6.1.v201009090800.jar
org.hamcrest.core_1.1.0.v20090501071000.jar
org.junit_3.8.2.v3_8_2_v20100427-1100.jar
org.junit_4.8.1.v4_8_1_v20100427-1100.jar
org.junit4_4.8.1.v20100525.jar
[Updated on: Sat, 13 November 2010 16:59] by Moderator
Re: Help about JST [message #638962 is a reply to message #638956] Sat, 13 November 2010 19:51 Go to previous messageGo to next message
You need at least org.eclipse.core.resources and org.eclipse.core.runtime.
This is needed to resolve some method signatures, but DOM/AST API themselves can be used outside of a headless Eclipse.
Olivier
Re: Help about JST [message #638965 is a reply to message #638962] Sat, 13 November 2010 23:43 Go to previous messageGo to next message
Thank you Olivier.
I have tried to added two jar (Full name listed below). I still got error:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/core/runtime/jobs/ISchedulingRule
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$000(Unknown Source)
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.runtime.jobs.ISchedulingRule
... 17 more
Jar added:
org.eclipse.core.runtime_3.6.0.v20100505.jar
org.eclipse.core.resources_3.6.0.v20100526-0737.jar
Olivier Thomann wrote on Sat, 13 November 2010 19:51
Olivier
Re: Help about JST [message #638992 is a reply to message #638965] Sun, 14 November 2010 09:16 Go to previous messageGo to next message
This means you also need org.eclipse.core.jobs.
You need to continue to do this until everything is there.
The best way to know what you need is to use a launching configuration and select org.eclipse.jdt.core as the only bundle. Then you click on "Add required bundles" and you will see all the bundles that you need.
HTH
Olivier
Re: Help about JST [message #639232 is a reply to message #638992] Mon, 15 November 2010 12:15 Go to previous messageGo to next message
Thank you again, Olivier
I think I know what's going on.
Although I don't know how to use the "launching configuration",
but I have tried to search jar which can solved the exception. The problems is solved temporally.
Thank you for your help.
Kam
Olivier Thomann wrote on Sun, 14 November 2010 09:16
HTH
Olivier
Re: Help about JST [message #1749758 is a reply to message #638992] Sun, 11 December 2016 07:15 Go to previous message
Olivier Thomann wrote on Sun, 14 November 2010 14:16
HTH
Olivier
I have included all required java files and getting the errors
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/core/runtime/preferences/IEclipsePreferences$INodeChangeListener
at org.eclipse.jdt.core.JavaCore.getOptions(JavaCore.java:3927)
at org.eclipse.jdt.core.dom.ASTParser.initializeDefaults(ASTParser.java:284)
at org.eclipse.jdt.core.dom.ASTParser.<init>(ASTParser.java:234)
at org.eclipse.jdt.core.dom.ASTParser.newParser(ASTParser.java:129)
Also would like to know how to launch the configuration set up
Previous Topic:How to resize the contents of the runtime window?
Next Topic:Pattern for annotation based null analysis and GUI programming
Current Time: Sat Jun 14 03:23:29 EDT 2025
Powered by FUDForum. Page generated in 0.04892 seconds
