Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] Run transformation from java code
[Acceleo 3] Run transformation from java code [message #637585] |
Sun, 07 November 2010 06:21  |
Im developing a eclipse plug-in. The plugin's actions parses annotations from java code and create a very simple model. Using this model, i want to generate code. The metamodel and module(.mtl) was created at plugin code. The model is created at runtime from annotation's parsing.
Creating a Acceleo project, the transformation occurs with no problems, but when i try to do this in java code, i got a problem. After create the "Generate.mlt" file, i studied the "Generate.java" and what his main method does. Then, on my plugin code, i create a new instance of "Generate" passing the parameters exactly how the Generate.main() does.
The Generate object loads the model file and find the Generate.emtl module correctly, but a exception occur after that:
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.progress.ProgressManager$5.run(ProgressManager.java:961)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:996)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:971)
at easypatterns.ui.popup.actions.GenerateLayerPattern.run(GenerateLayerPattern.java:50)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1050)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3984)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3577)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2407)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2371)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2220)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:367)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:611)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:566)
at org.eclipse.equinox.launcher.Main.run(Main.java:1363)
at org.eclipse.equinox.launcher.Main.main(Main.java:1339)
Caused by: java.lang.StackOverflowError
at org.eclipse.ocl.ecore.impl.OrderedSetTypeImpl.<init>(OrderedSetTypeImpl.java:50)
at org.eclipse.ocl.ecore.impl.EcoreFactoryImpl.createOrderedSetType(EcoreFactoryImpl.java:278)
at org.eclipse.ocl.ecore.internal.OCLFactoryImpl.createOrderedSetType(OCLFactoryImpl.java:88)
at org.eclipse.ocl.ecore.internal.UMLReflectionImpl.getOCLCollectionType(UMLReflectionImpl.java:645)
at org.eclipse.ocl.ecore.internal.UMLReflectionImpl.getOCLType(UMLReflectionImpl.java:145)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.getCollectionKind(EcoreEvaluationEnvironment.java:241)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.coerceValue(EcoreEvaluationEnvironment.java:275)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.navigateProperty(EcoreEvaluationEnvironment.java:222)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.navigateProperty(EcoreEvaluationEnvironment.java:1)
at org.eclipse.ocl.EvaluationVisitorImpl.visitPropertyCallExp(EvaluationVisitorImpl.java:1925)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitPropertyCallExp(AcceleoEvaluationVisitor.java:1009)
at org.eclipse.ocl.ecore.impl.PropertyCallExpImpl.accept(PropertyCallExpImpl.java:238)
at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(AbstractEvaluationVisitor.java:247)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(EvaluationVisitorDecorator.java:156)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1517)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitExpression(AcceleoEvaluationVisitor.java:912)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoForBlock(AcceleoEvaluationVisitor.java:332)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1480)
Then repeat the last ones several times.
What am i doing wrong?
(Sorry for my bad english)
Hugo Melo
Re: [Acceleo 3] Run transformation from java code [message #640852 is a reply to message #637877] |
Tue, 23 November 2010 05:58   |
I tried to run Acceleo module as java Application, I passed the 2 arguments (model and folder) but I get this Exeption while running (it deals with the model contents, that contains a profile application)
I used the MARTE profile (HLAM profile)
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/papyrus/HLAM/1' not found. (file:/export/home/charfi/runtime-EclipseApplication/myModel /model.uml, 49, 147)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils. java:349)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. initialize(AbstractAcceleoGenerator.java:311)
at org.eclipse.acceleo.module.Uml2Generic.files.Generate.<init >(Generate.java:83)
at org.eclipse.acceleo.module.Uml2Generic.files.Generate.main(G enerate.java:125)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/papyrus/HLAM/1' not found. (file:/export/home/charfi/runtime-EclipseApplication/myModel /model.uml, 49, 147)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2591)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2422)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:504)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(AbstractXMLDocumentParser.java:182)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.j ava:1315)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(XMLDocumentFragmentSca nnerImpl.java:2723)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(XMLDocumentScannerImpl.java:624)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 486)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:810)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:740)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:110)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1208)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(SAXParserImpl.java:525)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:392)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 5 more
the line 49 of the model.xmi = the last xml tag of the snippet bellow:
<profileApplication xmi:id="_xC62YPPaEd-Rm5Xgj2ludw">
<eAnnotations xmi:id="_xD4fsPPaEd-Rm5Xgj2ludw" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href="http://www.eclipse.org/papyrus/MARTE/1#//HLAM"/>
</eAnnotations>
<appliedProfile href=" pathmap://Papyrus_PROFILES/MARTE.profile.uml#_yNSZIAPMEdyuUt -4qHuVvQ"/>
</profileApplication>
</uml:Model>
<HLAM:RtUnit xmi:id="_12y1EPPaEd-Rm5Xgj2ludw" isMain="true" main="_p4_6UPL-Ed-fbvZBBnGjcg" base_BehavioredClassifier="_gJHUoPL-Ed-fbvZBBnGjcg"/>
</xmi:XMI>
when I run the module as Acceleo application, it works , so why it does not work as java application ?
thanks
Asma
Re: [Acceleo 3] Run transformation from java code [message #640858 is a reply to message #640852] |
Tue, 23 November 2010 06:03   |
--------------020502090209010606040706
Hi Asma,
The good ol' Package with URI not found :p. As mentionned on
http://eclipsemde.blogspot.com/2010/06/package-with-uri-not- found.html ,
you need to register the EPackage of the metamodels you're using by
yourself as EMF doesn't take care of it when in standalone.
In your case, you have to register the package for the papyrus HLAM
metamodel, no idea of the "XYZPackage" location. If you don't know
either, please ask the development team of this metamodel.
Laurent Goubet
Obeo
On 23/11/2010 11:58, charfi asma wrote:
> Hello,
> 49, 147)
> >(Generate.java:83)
> enerate.java:125)
> 49, 147)
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> nnerImpl.java:2723)
> MLParser.java:110)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> ... 5 more
> </eAnnotations>
> <appliedProfile
> </uml:Model>
> </xmi:XMI>
> thanks
> Asma
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020502090209010606040706--
Re: [Acceleo 3] Run transformation from java code [message #641107 is a reply to message #641092] |
Wed, 24 November 2010 04:42   |
--------------000500080700070602070301
Hi Asma,
I didn't understand that the HLAM metamodel was in fact an UML profile.
UML has many more things you need to register (notably the primitive
types) before you can use it standalone. Please see detailed
instructions on their FAQ at
http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
As a side note, registering the HLAM resource factory for all UML files
seems a little extreme :
resourceSet.getResourceFactoryRegistry().getExtensionToFacto
ryMap().put(UMLResource.FILE_EXTENSION, HLAMFactory.eINSTANCE);
as that would mean this factory will be used for any other "uml" file
your model depends on. You should ask the HLAM development team for
instructions on how to use their profile standalone : I believe they
have a content type against which to register their resource factory,
but I can't say which.
Laurent Goubet
Obeo
On 24/11/2010 10:05, charfi asma wrote:
> Hello Laurant,
> I registred the package of the HLAM profile by following steps described
> in your blog:
> 1. I added this line to the registerPackages method
> resourceSet.getPackageRegistry().put(org.eclipse.papyrus.MAR
> TE.MARTE_DesignModel.HLAM.HLAMPackage.eINSTANCE.getNsURI(),
> HLAMPackage.eINSTANCE);
> 2. I added also the factory to registerResourceFactories method
> this eliminate the Exception generated before " Package with uri
> 'http://www.eclipse.org/papyrus/HLAM/1' not found." but the
> c.getAppliedStereoptype() did not return anything !! no code is
> generated for stereotyped element !
> beside, even for the attribute type, instead of generating type.name
> (which is Integer for example), it generates :
> mailto:org.eclipse.emf.ecore.impl.DynamicEObjectImpl@12943ac (eClass:
> mailto:org.eclipse.emf.ecore.impl.EClassImpl@19ed7e (name:
> OclInvalid_Class) (instanceClassName: null) (abstract: false, interface:
> false))
> so EMF did not recognize either the HLAM profile, nor the UML Primitive
> Type.
> any Idea ?
> thanks
> ASMA
--------------000500080700070602070301--
Re: [Acceleo 3] Run transformation from java code [message #641150 is a reply to message #641141] |
Wed, 24 November 2010 07:39   |
--------------010008020002010205040509
Asma,
As I mentionned in earlier posts, I cannot help you here :'(. I can tell
you how to use Acceleo in standalone applications, I can point you
towards the UML documentations on how to use UML in standalone
applications ... but I don't know how to use the papyrus profiles in
standalone apps.
Please try the eclispe.papyrus newsgroup (web forum
http://www.eclipse.org/forums/index.php?t=thread&frm_id= 121) for this,
as long as they can provide you with the method to register and load
their profiles from standalone EMF, you will be ablt to properly use
your model with Acceleo. Before that, Acceleo can only use what you give
it, and for now you don't give it a profiled model since the profile
itself doesn't appear to be loaded.
Laurent Goubet
Obeo
On 24/11/2010 13:12, charfi asma wrote:
> Hi laurent,
> thank you for your answer, I succed in adding the UML Primitive type I
> just add those lines as mentionned in the UML wiki
> Map uriMap = resourceSet.getURIConverter().getURIMap();
> URI uri = URI.createURI("
> jar:file:/export/home/charfi/eclipse/plugins/org.eclipse.uml
> 2.uml.resources_3.0.0.v200906011111.jar!/ ");
> uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP),
> uri.appendSegment("libraries").appendSegment(""));
> uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP),
> uri.appendSegment("metamodels").appendSegment(""));
> uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP),
> uri.appendSegment("profiles").appendSegment(""));
> but I get the same problem with the HLAM profile which is aub profile
> from the MARTE profile. I even tried to register the UML standard
> profile but I did not succed.
> have you any idea how to register the UML standard profile ?
> the marte profile extension file is profile.uml, so I modify the
> register factroy
> ryMap().put(UMLResource.PROFILE_FILE_EXTENSION, HLAMFactory.eINSTANCE)
> but I get the same pb, acceleo did not generate the code related to the
> profile
> any idea :(
> Asma
--------------010008020002010205040509--
Re: [Acceleo 3] Run transformation from java code [message #642503 is a reply to message #641351] |
Wed, 01 December 2010 10:45  |
Hi Laurent,
thank you for your help
the papyrus provide a plugin to use marte profile (not a jar file but a plugin that I download from their svn in my workspace to use it)
so, I added it in the dependencies when clicking at manifest.mf of the acceleo project.
the MARTE.profile.uml is in " org.eclipse.papyrus.marte.static.profile.resources" and not in a jar file
so, have you an idea how to well load this profile ?
I tried with ecore profile and it works very well cause the file "Ecore.profile.uml" is already in the org.eclipse.uml2.uml.resources_3.1.1.v201008191505.jar that I add it using:
Map uriMap = resourceSet.getURIConverter().getURIMap();URI uri = URI.createURI(" jar:file:/export/home/charfi/Bureau/Logiciel/eclipse/plugins /org.eclipse.uml2.uml.resources_3.1.1.v201008191505.jar!/ ");
thank you very much
Asma
Current Time: Sat Jul 26 08:51:47 EDT 2025
Powered by FUDForum. Page generated in 0.30530 seconds
