Home » Eclipse Projects » Platform - User Assistance (UA) » Infocenter Authentication
Infocenter Authentication [message #624490] Fri, 03 September 2010 04:30 Go to next message
my Infocenter is up and running, also I'm only able to connect to my Infocenter by logging in with my external Browser.
When I connect to the infocenter with my Eclipse RCP I can't access the help. I want the Eclipse RCP to ask the user for login like the external webbrowser or another possibility to automatically transfer the username and password. SSL is not necessary.
I've searched a bit and found this http://dev.eclipse.org/viewcvs/index.cgi/platform-help-home/ infocenter_secure_access.html?view=co but these extension points do not exist (heard tomcat isn't used internal anymore, instead jetty?) and also some bug-entries which didn't help me.
Is it possible without rewriting everything?
Thanks in advance
Re: Infocenter Authentication [message #624491 is a reply to message #624490] Mon, 06 September 2010 03:53 Go to previous messageGo to next message
Has nobody a clue how to make a secure infocenter?
Re: Infocenter Authentication [message #624492 is a reply to message #624490] Thu, 09 September 2010 08:36 Go to previous messageGo to next message
I have updated my IDE to Helios and since the new update it can connect to my hostet infocenter.
Now the question is, which plugin of my rcp do I have to update to get the same functionality? (Login Dialog on Infocenter connect / SSL connection) I can't update everything because it's a rather huge project.
Thanks in advance
Re: Infocenter Authentication [message #624493 is a reply to message #624492] Fri, 10 September 2010 02:14 Go to previous messageGo to next message
Originally posted by: h.grosse-plankermann.iks-gmbh.com
Hi Matthias,
just a wild guess:
Looks like the functionality you are looking for went to
org.eclipse.equinox.security
Perhaps the extension points provided by this plugin can be helpful.
Especially org.eclipse.equinox.security.loginConfigurationProvider and
org.eclipse.equinox.security.loginModule look promising to me.
Hope that helps a bit.
Holger
Am 09.09.2010 14:36, schrieb Matthias:
> Thanks in advance
Re: Connect with an RCP-application to an Infocenter using SSL [message #624537 is a reply to message #624490] Fri, 10 September 2010 03:36 Go to previous message
Thanks for your help Holger!
It's not the right plugin but this doesn't matter anymore because when I update some plugins I need to update a lot more because of the dependencies.
I will suggest to move the targetPlattform to Helios but for now it seems that I cannot do more.
Matthias
Previous Topic:Setting the default help home page
Next Topic:activate output of org.eclipse.help/debug/context without IDE
Current Time: Sat Jul 26 21:16:27 EDT 2025
Powered by FUDForum. Page generated in 0.26036 seconds
