Home » Eclipse Projects » Platform - User Assistance (UA) » Infocenter as Webapp - Problems
Infocenter as Webapp - Problems [message #624475] Tue, 31 August 2010 03:29 Go to next message
I'm trying to run Infocenter on Tomcat. My Help system works when I start the infocenter over the command line but I want to use tomcat.
I've deployed the infocenter.war which I downloaded from the eclipse homepage. After setting the eclipse_home in web.xml I get the following error:
exception
org.apache.jasper.JasperException: Could not find bootstrap code. Check location of boot plug-in or specify -boot.
org.apache.jasper.servlet.JspServletWrapper.handleJspExcepti on(JspServletWrapper.java:476)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:371)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:315)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :265)
javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
root cause
javax.servlet.ServletException: Could not find bootstrap code. Check location of boot plug-in or specify -boot.
org.eclipse.help.servlet.InitServlet.init(InitServlet.java:4 6)
javax.servlet.GenericServlet.init(GenericServlet.java:212)
org.apache.jsp.index_jsp._jspService(index_jsp.java:48)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:98)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:328)
root cause
org.eclipse.help.servlet.Eclipse.init(Eclipse.java:150)
org.eclipse.help.servlet.Eclipse.<init>(Eclipse.java:33)
org.eclipse.help.servlet.InitServlet.init(InitServlet.java:3 8)
root cause
java.lang.RuntimeException: Could not find bootstrap code. Check location of boot plug-in or specify -boot.
org.eclipse.help.servlet.Eclipse.searchForBoot(Eclipse.java: 213)
org.eclipse.help.servlet.Eclipse.getBootLoader(Eclipse.java: 89)
org.eclipse.help.servlet.Eclipse.init(Eclipse.java:108)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.23 logs.
I've tried also to create my own webapp with different tutorials but after the last steps I only get this error.
Please give me some hints!
Thanks in advance
Re: Infocenter as Webapp - Problems (Tomcat) [message #624480 is a reply to message #624475] Tue, 31 August 2010 09:24 Go to previous messageGo to next message
I would recommend trying to build the war using the help documentation first (for 3.6 it is here):
http://help.eclipse.org/helios/topic/org.eclipse.platform.do c.isv/guide/ua_help_war.htm
Then you can work on customizing it.
Re: Infocenter as Webapp - Problems (Tomcat) [message #624482 is a reply to message #624475] Tue, 31 August 2010 10:27 Go to previous messageGo to next message
I used the help documentation and my errors were the result. I will try it again tomorrow, maybe I skipped something.
I have also tried it with this guide:
http://blog.maxant.co.uk/pebble/2008/06/09/1213043100000.htm l
Same result.
Re: Infocenter as Webapp - Problems (Tomcat) [message #624485 is a reply to message #624475] Wed, 01 September 2010 02:15 Go to previous messageGo to next message
Today I tried another complete version, it gives me another exception but I think I am near to the wished result.
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Servlet.init() for servlet equinoxbridgeservlet threw exception
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:151)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:870)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:685)
java.lang.Thread.run(Thread.java:619)
root cause
java.lang.IllegalStateException: instance already set
org.eclipse.equinox.servletbridge.BridgeServlet.setInstance( BridgeServlet.java:184)
org.eclipse.equinox.servletbridge.BridgeServlet.init(BridgeS ervlet.java:44)
Any proposes?
Re: Infocenter as Webapp - Problems (Tomcat) [message #624487 is a reply to message #624475] Thu, 02 September 2010 03:23 Go to previous messageGo to next message
Another update:
I've tried a war from https://bugs.eclipse.org/bugs/show_bug.cgi?id=201666 Maybe it's not compatible with my eclipse 3.5.1 and Tomcat 5.5?
In my /WEB-INF/eclipse/plugins directory org.eclipse.core.runtime_3.4.0.v20080512.jar exists...
Here is the complete stackstrace:
02.09.2010 09:14:01 org.apache.catalina.core.ApplicationContext log
SCHWERWIEGEND: Error while starting Framework
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1359)
at org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1205)
at org.eclipse.equinox.servletbridge.FrameworkLauncher$ChildFir stURLClassLoader.loadClass(FrameworkLauncher.java:650)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at org.eclipse.equinox.servletbridge.FrameworkLauncher.start(Fr ameworkLauncher.java:209)
at org.eclipse.equinox.servletbridge.BridgeServlet.init(BridgeS ervlet.java:63)
at javax.servlet.GenericServlet.init(GenericServlet.java:212)
at org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:1139)
at org.apache.catalina.core.StandardWrapper.load(StandardWrappe r.java:966)
at org.apache.catalina.core.StandardContext.loadOnStartup(Stand ardContext.java:3956)
at org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4230)
at org.apache.catalina.core.ContainerBase.addChildInternal(Cont ainerBase.java:760)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBas e.java:740)
at org.apache.catalina.core.StandardHost.addChild(StandardHost. java:544)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostC onfig.java:920)
at org.apache.catalina.startup.HostConfig.deployDirectories(Hos tConfig.java:883)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig .java:492)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java :1138)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostCo nfig.java:311)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent (LifecycleSupport.java:120)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1022)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:736)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1014)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:448)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:700)
at org.apache.catalina.startup.Catalina.start(Catalina.java:552 )
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 95)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:43 3)
SCHWERWIEGEND: StandardWrapper.Throwable
java.lang.RuntimeException: org.eclipse.core.runtime.adaptor.EclipseStarter
at org.eclipse.equinox.servletbridge.FrameworkLauncher.start(Fr ameworkLauncher.java:225)
02.09.2010 09:14:01 org.apache.catalina.core.StandardContext loadOnStartup
SCHWERWIEGEND: Servlet /help threw load() exception
02.09.2010 09:14:14 org.apache.catalina.core.ApplicationContext log
at org.eclipse.equinox.servletbridge.BridgeServlet.setInstance( BridgeServlet.java:184)
at org.eclipse.equinox.servletbridge.BridgeServlet.init(BridgeS ervlet.java:44)
at org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:791)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:127)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:151)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:870)
at org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:685)
at java.lang.Thread.run(Thread.java:619)
02.09.2010 09:14:14 org.apache.catalina.core.StandardWrapperValve invoke
SCHWERWIEGEND: Allocate exception for servlet equinoxbridgeservlet
Re: Infocenter as Webapp - Problems (Tomcat) [message #624488 is a reply to message #624475] Thu, 02 September 2010 03:58 Go to previous messageGo to next message
Now I just extracted org.eclipse.osgi_3.4.0.v20080605-1900.jar into /plugins (It was already in the plugin-folder but packaged in the same-named plugin as jar) and the osgi prompt appears.
When I browse to localhost:8080/help a page appears but it doesn't look like infocenter.
The header-frame has the content "Mit dieser XML-Datei sind anscheinend keine Style-Informationen verknüpft. Nachfolgend wird die Baum-Ansicht des Dokuments angezeigt."
The frame at the bottom has only "
<component name="Help System Webapp" version="1.1">
<plugin id="org.eclipse.help.webapp"/>
</component>"
as content.
Maybe is there an error with the permission of the filesystem so that eclipse may not extract the jars to work with them or something like this?
Thanks in advance
Re: Infocenter as Webapp - Problems (Tomcat) [message #624489 is a reply to message #624475] Fri, 03 September 2010 04:22 Go to previous message
My last post is the solution to my problem. I only had to brrowse directly to index.jsp and my help shows up!
Previous Topic:Infocenter Mapping
Next Topic:Setting the default help home page
Current Time: Thu Jul 24 21:46:01 EDT 2025
Powered by FUDForum. Page generated in 0.09545 seconds
