Infocenter as Webapp - Problems [message #624475] |
Tue, 31 August 2010 03:29  |
I'm trying to run Infocenter on Tomcat. My Help system works when I start the infocenter over the command line but I want to use tomcat.
I've deployed the infocenter.war which I downloaded from the eclipse homepage. After setting the eclipse_home in web.xml I get the following error:
exception
org.apache.jasper.JasperException: Could not find bootstrap code. Check location of boot plug-in or specify -boot.
org.apache.jasper.servlet.JspServletWrapper.handleJspExcepti on(JspServletWrapper.java:476)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:371)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:315)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :265)
javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
root cause
javax.servlet.ServletException: Could not find bootstrap code. Check location of boot plug-in or specify -boot.
org.eclipse.help.servlet.InitServlet.init(InitServlet.java:4 6)
javax.servlet.GenericServlet.init(GenericServlet.java:212)
org.apache.jsp.index_jsp._jspService(index_jsp.java:48)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:98)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:328)
root cause
org.eclipse.help.servlet.Eclipse.init(Eclipse.java:150)
org.eclipse.help.servlet.Eclipse.<init>(Eclipse.java:33)
org.eclipse.help.servlet.InitServlet.init(InitServlet.java:3 8)
root cause
java.lang.RuntimeException: Could not find bootstrap code. Check location of boot plug-in or specify -boot.
org.eclipse.help.servlet.Eclipse.searchForBoot(Eclipse.java: 213)
org.eclipse.help.servlet.Eclipse.getBootLoader(Eclipse.java: 89)
org.eclipse.help.servlet.Eclipse.init(Eclipse.java:108)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.23 logs.
I've tried also to create my own webapp with different tutorials but after the last steps I only get this error.
Please give me some hints!
Thanks in advance
FUDForum. Page generated in 0.08040 seconds
