Home » Eclipse Projects » Platform - User Assistance (UA) » Questions about using the Eclipse Help as standalone infocenter
Questions about using the Eclipse Help as standalone infocenter [message #623861] Sat, 16 January 2010 12:09 Go to next message
I want to use the Eclipse help as standalone infocenter. I have customized it as far as possible so that only the needed plugins are loaded to show the infocenter.
Now when I try to put in my created plugins containing the help files nothing is shown in the topic list and I cannot see if Eclipse loads the bundles. A restart of the infocenter has also no effect. When I load the appropriate plugin in my workbench, everything works fine.
This is the command for starting the infocenter:
base_path=/Users/Java/help_system
java -classpath $base_path/plugins/org.eclipse.help.base_3.4.0.v200909170800 .jar org.eclipse.help.standalone.Infocenter -debug -command start -eclipsehome $base_path -port 8080 -plugincustomization $base_path/custom.ini
And thats what is in custom.ini:
org.eclipse.help.base/remoteHelpOn=true
org.eclipse.help.base/remoteHelpUseDefaultPort=false
org.eclipse.help.base/remoteHelpPort=8080
org.eclipse.help.base/banner=/de.berg.systeme.help.handbook/ html/support_header.html
org.eclipse.help.base/banner_height=80
org.eclipse.help/HELP_DATA=helpData.xml
helpData.xml looks like this:
<extensions>
<tocOrder>
<toc id="/de.berg.systeme.help.handbook/handbook.xml"/>
</tocOrder>
<hidden>
<toc id="/com.ibm.help.hs.doc/iehs_helpsys.xml"/>
<toc id="/com.ibm.help.ic.doc/iehs_infoc.xml"/>
</hidden>
</extensions>
And plugin.xml is this one:
<?eclipse version="3.4"?>
<plugin>
<extension
point="org.eclipse.help.toc">
<toc
file="toc.xml">
</toc>
<toc
file="handbook.xml"
primary="true">
</toc>
</extension>
</plugin>
Maybe someone has encountered the same problems and can give me a hint.
Re: Questions about using the Eclipse Help as standalone infocenter [message #623862 is a reply to message #623861] Thu, 21 January 2010 17:42 Go to previous message
We ran into this problem last year too. I had an intern do a lot of trial and error, and he discovered that you have to update this file so your plugins are recognized:
eclipse\configuration\org.eclipse.equinox.simpleconfigurator /bundles.info
We couldn't figure out what all of the values were supposed to be, but by adapting the other lines in the file, we were able to get our plugins to display in InfoCenter mode. Apparently, this file is updated automatically in platform mode, but not in InfoCenter.
As best we can figure, the entry is:
pluginID,plugin-version,file:plugins\[pluginID],4,false
We have no idea what the 4 and the false mean.
Here's a generic version of the line we add:
com.company.product.plugin,1.3,file:plugins\com.company.prod uct.plugin,4,false
Hope that helps.
Previous Topic:Creating permanent search scopes in Infocenter?
Next Topic:Pre-Built indexes for Infocenter
Current Time: Thu Jun 12 04:39:31 EDT 2025
Powered by FUDForum. Page generated in 0.24104 seconds
