Add link to RCP Help in Windows Start menu [message #475245] |
Wed, 11 March 2009 09:44  |
Originally posted by: j.hurrell.don'tspamme.castsoftware.com
We have an RCP application with help that we package in an Install
Shield setup. We would like to have a link placed in the Windows Start
menu that when clicked will open the RCP Help (Infocenter version - i.e.
Help > Help Contents).
I have noted that the port number defined in the infocenter URL is
seemingly random each time the Help is opened, so a hard link is out I
guess?
Any ideas?
Re: Add link to RCP Help in Windows Start menu [message #475251 is a reply to message #475245] |
Thu, 12 March 2009 19:06  |
You can specify the server port as a VM argument, for example
-Dserver_port=8080 .
> guess?
> Any ideas?
Re: Add link to RCP Help in Windows Start menu [message #623248 is a reply to message #475245] |
Wed, 11 March 2009 11:05  |
Hi James,
What startup command are you using that will underlie the Start menu choice?
I found in this Eclipse Help topic that there used to be a port
customization preference to set the port number on which the embedded
help server will listen to. It says "If port is not given, an arbitrary
port is picked by the system."
See:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_help_setup_preferences.htm
That help topic goes on to say that the port preference has been
deprecated, and instead to start Eclipse with "-vmargs
-Dserver_port=<port>".
So, I would first try using that (-vmargs -Dserver_port=<port>) on the
startup command that is being used for the Start menu choice.
(Note that there is also a -vmargs -Dserver_host=<host> option to set it
to use the local machine host=127.0.0.1 if you are launching the help
system to run in standalone mode.)
Hope this helps!
Lee Anne
> guess?
> Any ideas?
Re: Add link to RCP Help in Windows Start menu [message #623250 is a reply to message #475245] |
> guess?
> Any ideas?
FUDForum. Page generated in 0.05071 seconds
