Home » Archived » Service Oriented Architecture Tools Platform (STP) » [JAX-WS] Java first artifacts no longer being generated
[JAX-WS] Java first artifacts no longer being generated [message #375067] Thu, 19 March 2009 00:52 Go to next message
I had been running successfully with JAX-WS for a few weeks using Ganymede
SR1 with the latest STP code from the Ganymede update site. It generated the
artifacts for my web services when I run my code in the debugger and worked
correctly all the time. After a few days of work on code not related to web
services I did a system regression test and found it stopped generating the
artifacts and the services can't start. I have not added/removed anything
from eclipse. I did integrate Teneo support to persist my EMF models in the
same project with these web services. I am using Spring to load my JAX-WS
web services.
Any suggestions on what I should look at? Unfortunately, I am not
knowledgable about what triggers the JAX-WS and where to look.
Thanks in advance!
Derek
Re: [stp-newsgroup] [JAX-WS] Java first artifacts no longer being generated [message #375068 is a reply to message #375067] Thu, 19 March 2009 04:34 Go to previous message
Hi Derek,
You should visit the new JAX-WS Project wiki page at
http://wiki.eclipse.org/JAXWS to see the new and exciting
work on JAX-WS service development. This replaces the
older (and buggier) capabilities that were in STP and is
orders of magnitude more complete.
best regards
Oisin
Re: [stp-newsgroup] [JAX-WS] Java first artifacts no longer being generated [message #621199 is a reply to message #375067] Thu, 19 March 2009 04:34 Go to previous message
Hi Derek,
best regards
Oisin
Previous Topic:[JAX-WS] Java first artifacts no longer being generated
Next Topic:Is there any Policy meta-model in STP?
Current Time: Sun Jul 27 16:21:05 EDT 2025
Powered by FUDForum. Page generated in 0.06077 seconds
