Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Insert / Delete instead of Update
| [Teneo] Insert / Delete instead of Update [message #129283] |
Mon, 01 September 2008 22:09  |
I'm running the library example and looking in the hypersonic logs and
noticed some odd behaviour.
It appears that no updates are ever issued but instead rows are deleted
and inserted. Also a lot more SQL is executed than would be required.
Obviously you need to allow for some inefficiencies with a persistence
framework but it seemed excessive to me.
Running the first section of the example as follows
// Open a new Session and start transaction.
final Session session = sessionFactory.openSession();
session.beginTransaction();
// Create a library.
Library library = LibraryFactory.eINSTANCE.createLibrary();
library.setName("My Library");
// Make it persistent.
session.save(library);
// Create a writer...
Writer writer = LibraryFactory.eINSTANCE.createWriter();
writer.setName("JRR Tolkien");
// ...and one of his books.
Book book = LibraryFactory.eINSTANCE.createBook();
book.setAuthor(writer);
book.setPages(305);
book.setTitle("The Hobbit");
book.setCategory(BookCategory.SCIENCE_FICTION);
// Add the Writer and Book to the Library. They are made
// persistent automatically because the Library is already
// persistent.
library.getWriters().add(writer);
library.getBooks().add(book);
// Commit the changes to the database.
session.getTransaction().commit();
// Close the session. Not necessary if
session.close();
Results in
INSERT IGNORE INTO "library" VALUES(1,'Library',0,'My Library')
INSERT IGNORE INTO "writer" VALUES(1,'Writer',0,'JRR
Tolkien',NULL,NULL,'Library','1',-2)
INSERT IGNORE INTO "book" VALUES(1,'Book',0,'The
Hobbit',305,'ScienceFiction',1,NULL,NULL,'Library','1',-3)
DELETE FROM "writer" WHERE E_ID=1
Tolkien',1,0,'Library','1',-2)
DELETE FROM "book" WHERE E_ID=1
Hobbit',305,'ScienceFiction',1,1,0,'Library','1',-3)
INSERT IGNORE INTO "writer_books" VALUES(1,1,0)
Where as all that was really needed was
Is this a Teneo or hibernate issue?
Its been a while since I did hibernate but don't remember that?
| Re: [Teneo] Insert / Delete instead of Update [message #129428 is a reply to message #129283] |
Tue, 02 September 2008 14:42   |
Hi Andrew,
I executed the exact same code as you did and got this result:
0 [main] DEBUG org.hibernate.SQL - insert into `library` (e_version, `name`) values (?, ?)
3501 [main] DEBUG org.hibernate.SQL - insert into `writer` (e_version, `name`, econtainer_class,
e_container, e_container_featureid) values (?, ?, ?, ?, ?)
3509 [main] DEBUG org.hibernate.SQL - insert into `book` (e_version, `title`, `pages`, `category`,
econtainer_class, e_container, e_container_featureid) values (?, ?, ?, ?, ?, ?, ?)
3581 [main] DEBUG org.hibernate.SQL - update `writer` set `library_writers_e_id`=?,
`library_writers_idx`=? where e_id=?
3589 [main] DEBUG org.hibernate.SQL - update `book` set `library_books_e_id`=?,
`library_books_idx`=? where e_id=?
3590 [main] DEBUG org.hibernate.SQL - update `book` set `book_author_e_id`=?, `writer_books_idx`=?
where e_id=?
This set of statements is correct. First create the objects and then update their internal relations.
Maybe you set different options and therefore have a different mapping. Can you post the mapping?
You can get it from the datastore.getMappingXML().
Btw, support for Teneo is given on the EMF newsgroup which I cc-ed.
gr. Martin
> book.setPages(305);
> // persistent.
> session.close();
> Results in
> Is this a Teneo or hibernate issue? Its been a while since I did
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] Insert / Delete instead of Update [message #129467 is a reply to message #129428] |
Wed, 03 September 2008 02:31   |
OK that's far more sensible. I don't believe I set any options other than
those in the tutorial.
Either way, I'm only evaluating for now and based on what you have shown
here I am happy with how it was handled, so that's good enough for me for
now.
BTW I assume there is a way to separate the generate schema steps from the
running of the application? We would manage the schema evolution carefully
and not want this to happen when we run the app. Any pointers there?
Thanks for your help
Martin Taal wrote:
> Hi Andrew,
> where e_id=?
> gr. Martin
>> book.setPages(305);
>> // persistent.
>> session.close();
>> Results in
| Re: [Teneo] Insert / Delete instead of Update [message #129505 is a reply to message #129467] |
Wed, 03 September 2008 10:03   |
Hi Andrew,
You can generate a mapping separately (call HbHelper.generateMapping) and store it a
hibernate.hbm.xml file. Then you can tell Teneo to use a mapping file (set the option
USE_MAPPING_FILE to "true"), if your mapping file is not called hibernate.hbm.xml or is not located
in the packages of the model then you can set the mapping file path through the option
MAPPING_FILE_PATH.
The update of the database schema is controlled through hibernate and its option
hibernate.hbm2ddl.auto (see the hibernate manual for more information). So even if Teneo generates a
new mapping, the database schema is only updated if this option is set to create or update. But
having a separate mapping file is always the safest approach.
gr. Martin
> than those in the tutorial.
> for now.
> the running of the application? We would manage the schema evolution
> carefully and not want this to happen when we run the app. Any pointers
> there?
> Martin Taal wrote:
>> Hi Andrew,
>> where e_id=?
>> update
>> mapping. Can
>> gr. Martin
>>> and noticed some odd behaviour.
>>> deleted and inserted. Also a lot more SQL is executed than would be
>>> required. Obviously you need to allow for some inefficiencies with a
>>> persistence framework but it seemed excessive to me.
>>> book.setPages(305);
>>> // persistent.
>>> session.close();
>>> Results in
The Netherlands
| Re: [Teneo] Insert / Delete instead of Update [message #129551 is a reply to message #129505] |
Fri, 05 September 2008 03:32   |
Thanks Martin
Martin Taal wrote:
> Hi Andrew,
store it a
the option
the option
> MAPPING_FILE_PATH.
option
> gr. Martin
>> for now.
>> there?
>> Martin Taal wrote:
>>> Hi Andrew,
>>> where e_id=?
>>> update
>>> mapping. Can
>>> gr. Martin
>>>> book.setPages(305);
>>>> // persistent.
>>>> session.close();
>>>> Results in
| Re: [Teneo] Insert / Delete instead of Update [message #129562 is a reply to message #129551] |
Fri, 05 September 2008 03:50  |
One thing I forgot to mention is that the mapping file probably needs to be explicitly flagged in
the build.properties to be copied to the output directory.
gr. Martin
Andrew H wrote:
> Thanks Martin
> Martin Taal wrote:
>> Hi Andrew,
> store it a
>> (set
> the option
>> through
> the option
>> MAPPING_FILE_PATH.
> option
>> information). So
>> gr. Martin
>>> shown here I am happy with how it was handled, so that's good enough
>>> for me for now.
>>> from the running of the application? We would manage the schema
>>> evolution carefully and not want this to happen when we run the app.
>>> Any pointers there?
>>> Martin Taal wrote:
>>>> Hi Andrew,
>>>> (e_version,
>>>> where e_id=?
>>>> update
>>>> mapping. Can
>>>> gr. Martin
>>>>> a persistence framework but it seemed excessive to me.
>>>>> book.setPages(305);
>>>>> // persistent.
>>>>> session.close();
>>>>> Results in
The Netherlands
| Re: [Teneo] Insert / Delete instead of Update [message #620289 is a reply to message #129283] |
Hi Andrew,
where e_id=?
gr. Martin
> book.setPages(305);
> // persistent.
> session.close();
> Results in
The Netherlands
| Re: [Teneo] Insert / Delete instead of Update [message #620292 is a reply to message #129428] |
now.
Martin Taal wrote:
> Hi Andrew,
> where e_id=?
> gr. Martin
>> book.setPages(305);
>> // persistent.
>> session.close();
>> Results in
| Re: [Teneo] Insert / Delete instead of Update [message #620295 is a reply to message #129467] |
Hi Andrew,
MAPPING_FILE_PATH.
gr. Martin
> for now.
> there?
> Martin Taal wrote:
>> Hi Andrew,
>> where e_id=?
>> update
>> mapping. Can
>> gr. Martin
>>> book.setPages(305);
>>> // persistent.
>>> session.close();
>>> Results in
The Netherlands
| Re: [Teneo] Insert / Delete instead of Update [message #620299 is a reply to message #129505] |
Thanks Martin
Martin Taal wrote:
> Hi Andrew,
store it a
the option
the option
> MAPPING_FILE_PATH.
option
> gr. Martin
>> for now.
>> there?
>> Martin Taal wrote:
>>> Hi Andrew,
>>> where e_id=?
>>> update
>>> mapping. Can
>>> gr. Martin
>>>> book.setPages(305);
>>>> // persistent.
>>>> session.close();
>>>> Results in
| Re: [Teneo] Insert / Delete instead of Update [message #620300 is a reply to message #129551] |
gr. Martin
Andrew H wrote:
> Thanks Martin
> Martin Taal wrote:
>> Hi Andrew,
> store it a
>> (set
> the option
>> through
> the option
>> MAPPING_FILE_PATH.
> option
>> information). So
>> gr. Martin
>>> for me for now.
>>> Any pointers there?
>>> Martin Taal wrote:
>>>> Hi Andrew,
>>>> (e_version,
>>>> where e_id=?
>>>> update
>>>> mapping. Can
>>>> gr. Martin
>>>>> book.setPages(305);
>>>>> // persistent.
>>>>> session.close();
>>>>> Results in
The Netherlands
Current Time: Thu Nov 06 07:21:38 EST 2025
Powered by FUDForum. Page generated in 0.05585 seconds
