Home » Archived » Eclipse Communications Framework (ECF) » Question about ECF architecture
Question about ECF architecture [message #619819] |
Wed, 12 December 2007 06:17  |
Hi folks,
I have to use ECF in my RCP applications. I found that both instant
messaging and Shared Objects would be very useful.
By now I already have tested them and it works fine.
But my questions are more about ECF architecture :
I would like to know if contacts in my buddy list are connected to my
specific application(s). I think about using a shared object to store and
exchange application informations (user connected, application title,
special actions, etc...).
Is it the best way to achieve that ?
How does SharedObject and containers work actually ? Do any instance of
Eclipse RCP have to send Shared Object to everybody, or is it possible to
store a Shared Object in a server and then clients requests it when they
need ?
Hope my questions are understandable :)
Thanks by advance.
Lionel
Re: Question about ECF architecture [message #619825 is a reply to message #619819] |
Sun, 16 December 2007 22:18   |
Hi Lionel,
Lionel wrote:
> Hi folks,
By default, entries in the buddy list are not associated with any
applications. However, ECF allows an application to create and then use
arbitrary channels for messaging. These channels are created via the
ECF datashare API: http://wiki.eclipse.org/ECF_API_Docs#Datashare_API
The way this can work is that an application interested in creating a
channel for messaging to a buddy can
1) Get the IChannelContainerAdapter instance
2) Create a channel to a remote application using the instance
3) Use the channel
So, for example, given an IRosterEntry instance, a channel container
adapter can be retrieved from the provider responsible for the
IRosterEntry via
IPresenceContainerAdapter prca =
rosterEntry.getRoster().getPresenceContainerAdapter();
IContainer container = (IContainer) prca.getAdapter(IContainer.class);
IChannelContainerAdapter cca = (IChannelContainerAdapter)
container.getAdapter(IChannelContainerAdapter.class);
To create a channel, then:
ID channelID =
IDFactory.getDefault().createID(cca.getChannelNamespace(),"channel ");
IChannelListener channelListener = <create channel listener to receive
events>
IChannel newChannel = cca.createChannel(channelID, channelListener, null);
Then to use the channel to send a message to roster entry (where a
channel with same name also has to be established):
newChannel.sendMessage(rosterEntry.getID(),new String("howdy").getBytes());
Note there are examples of doing this in the
org.eclipse.presence.collab.ui plugin
URLShare (distributing URLs to buddy list members via channel):
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/plu gins/org.eclipse.ecf.presence.collab.ui/src/org/eclipse/ecf/ presence/collab/ui/url/URLShare.java?root=Technology_Project &view=log
ViewShare (remotely opening Eclipse views to buddy list members via
channel):
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/plu gins/org.eclipse.ecf.presence.collab.ui/src/org/eclipse/ecf/ presence/collab/ui/view/ViewShare.java?root=Technology_Proje ct&view=log
> and exchange application informations (user connected, application
> title, special actions, etc...).
The above procedure can also be used to get the
ISharedObjectContainerAdapter and to create/add a shared object
(analogous to channel). But the IChannel interface and the
IChannelContainer interface are simpler and easier to use (although they
do not provide as much access to functionality as ISharedObject and
ISharedObjectContainer). So ultimately it's up to you...based upon the
needs of your application. I suggest trying the datashare/IChannel
interfaces first, and see if that will meet your needs.
> to store a Shared Object in a server and then clients requests it when
> they need ?
When shared objects are added to a container (via
ISharedObjectManager.addSharedObject) a thread is started for the shared
object, and events are delivered to that shared object by the container.
The events delivered (asynchonrously via ISharedObject.handleEvent):
Upon being added to container: ISharedObjectActivatedEvent
Upon being removed from container: ISharedObjectDeactivatedEvent
When receiving a message from a remote shared object replica (of same
ID): ISharedObjectMessageEvent
Note that when a shared object is activated, it can send a message to a
remote to create a replica of itself on the remote (with the current
state of the shared object):
sharedObjectContext.sendCreate(targetID,remoteDescription);
where the targetID is the ID of the remote target, and the
remoteDescription is a description of the replica (i.e. class, ID,
state/properties, etc). Note that there is a base shared object class,
that provides a number of utility methods for subclasses (e.g.
getReplicaDescription(), getContext(), replicatToRemoteContainers(), etc):
http://www.eclipse.org/ecf/org.eclipse.ecf.docs/api/org/ecli pse/ecf/core/sharedobject/BaseSharedObject.html#getContext()
The 'original' instance of the shared object can determine when/how
replicas are created...so either of your scenarios described above can
be supported.
Scott
Re: Question about ECF architecture [message #619832 is a reply to message #619825] |
Wed, 19 December 2007 17:23   |
I'm trying to use shareObject Api but i didn't understand how to share
the same content for different user.
I've gotten the sharedObjectContainer and added a new sharedObject to
the container. I can see that the object is added in the local
sharedContainer but I didn't understand how to replicate this object to
the shared container
of the other users.
If you can provide an example or the basic step needed for this I'll be
grateful
Bye,
Luca
Scott Lewis ha scritto:
> Hi Lionel,
> Lionel wrote:
>> Hi folks,
> 3) Use the channel
> IRosterEntry via
> ID channelID =
> events>
> channel):
>> of Eclipse RCP have to send Shared Object to everybody, or is it
>> possible to store a Shared Object in a server and then clients
>> requests it when they need ?
> be supported.
> Scott
Re: Question about ECF architecture [message #619834 is a reply to message #619832] |
Wed, 19 December 2007 19:05   |
Hi Luca,
There is this test code, which adds a shared object to a client, and
this object is then replicated to the server and the other client.
The shared object code is here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/tes ts/org.eclipse.ecf.tests.sharedobject/src/org/eclipse/ecf/te sts/sharedobject/TestSharedObject.java?root=Technology_Proje ct&view=log
The test case code is here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/tes ts/org.eclipse.ecf.tests.sharedobject/src/org/eclipse/ecf/te sts/sharedobject/AddTest.java?root=Technology_Project&vi ew=log
The whole (test) plugin:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/tes ts/org.eclipse.ecf.tests.sharedobject/?root=Technology_Proje ct
See particularly the shared object code, the 'initialize' method for
setting up an event processor that replicates the object.
Hope this helps. We will be doing more test code of this kind.
Scott
Luca Bacco wrote:
> of the other users.
> grateful
> Bye,
> Luca
>> Hi Lionel,
>> Lionel wrote:
>>> Hi folks,
>> use arbitrary channels for messaging. These channels are created via
>> the ECF datashare API:
>> 3) Use the channel
>> IRosterEntry via
>> ID channelID =
>> events>
>> null);
>> channel):
>> they do not provide as much access to functionality as ISharedObject
>> and ISharedObjectContainer). So ultimately it's up to you...based
>> upon the needs of your application. I suggest trying the
>> datashare/IChannel interfaces first, and see if that will meet your
>> needs.
>> shared object, and events are delivered to that shared object by the
>> container. The events delivered (asynchonrously via
>> a remote to create a replica of itself on the remote (with the current
>> class, that provides a number of utility methods for subclasses (e.g.
>> etc):
>> be supported.
>> Scott
Re: Question about ECF architecture [message #619837 is a reply to message #619834] |
Sun, 23 December 2007 04:07   |
> Hi Luca,
> Scott
> Luca Bacco wrote:
>> Hi,
>> to the shared container
>> of the other users.
>> be grateful
>> Bye,
>> Luca
>>> Hi Lionel,
>>> Lionel wrote:
>>>> Hi folks,
>>>> my specific application(s).
>>> 3) Use the channel
>>> IRosterEntry via
>>> ID channelID =
>>> receive events>
>>> null);
>>> channel):
>>> needs.
>>> current state of the shared object):
>>> etc):
>>> can be supported.
>>> Scott
Thank you very much for your answer!
Luca
Re: Question about ECF architecture [message #620015 is a reply to message #619834] |
Tue, 01 January 2008 18:11   |
> Hi Luca,
> Scott
> Luca Bacco wrote:
>> Hi,
>> of the other users.
>> be grateful
>> Bye,
>> Luca
>>> Hi Lionel,
>>> Lionel wrote:
>>>> Hi folks,
>>> 3) Use the channel
>>> IRosterEntry via
>>> ID channelID =
>>> receive events>
>>> null);
>>> channel):
>>> needs.
>>> etc):
>>> can be supported.
>>> Scott
I'm sorry if I ask again about this question but I still have a few
questions :
I followed the examples in the test, I've tried to use a connection to a
xmpp server creating two containers (client a and b):
container =ContainerFactory.getDefault().createContainer("ecf.xmpp.smack " );
container.addListener( this );
id = IDFactory.getDefault().createID( container.getConnectNamespace(),
userName );
connectContext = ConnectContextFactory.createPasswordConnectContext(
password );
container.connect( id, connectContext );
However "addEventProcessor(new IEventProcessor())" has always failed and
I was able to create my object (and share it) only commenting this step
but I didn't understand why.
Now I want to propagate the changes done on my local copy to the others.
If I've understand from the other examples I could send a
sharedMessage and use a handleShaderMessage and make changes to the
other object.
Thank you in advance.
I want to wish you all an happy new year.
Luca
Re: Question about ECF architecture [message #620042 is a reply to message #620017] |
Wed, 09 January 2008 19:45   |
> Hi Luca,
> <stuff deleted>
>> questions :
>> a xmpp server creating two containers (client a and b):
>> container
>> userName );
>> password );
>> and I was able to create my object (and share it) only commenting this
>> step but I didn't understand why.
I've tested more and discovered that this was a simple problem of delay
between server\client...
> Could you describe what you mean by addEventProcessor failing? Does it
> throw some exception? If so, which one? When is addEventProcessor
> called in your code?
>> others. If I've understand from the other examples I could send a
>> other object.
I'm sorry but I still need help here...
I've successfully used this feature sending a message to another
client(after creating 2 instances of contanier connected to a remote
xmpp server), however I've still some doubt about this...
1)it's possible to send automatically a message to all the users
connected to same sever?
2) getReplicaDescription(ID receiver) should let me to create a replica
of a shared object to another remote container so if I've understand, if
client adds a shared object client b should only use
SharedManager.getSharedObject(ID) to obtain a replica of that object.
(or didn't I understand?)
Now even if I'm able to send a message to another client
(sendSharedMsgTo(ID, msg)) I'm not able to get this replica, did i miss
a step?
Do I need to connect the SharedObjectManager to a room/group or to
another client?
I think I'm missing a step.
I'm posting the simple code I'm using for this test (I've just modified
AddTest.java)
http://jazz.di.uniba.it:8000/econference-over-ecf/browser/tr unk/it.uniba.cdg.instantmessenger.handRaise.test/src/it/unib a/cdg/instantmessenger/handraise/test/SobjectTest.java
and this is our project:
Bye,
Luca
> Yes, that's correct. The methods to do these things are in
> BaseSharedObject.
> Sure...just would like to get you fully going.
> Happy New Year to you as well.
> Scott
>> Luca
Re: Question about ECF architecture [message #620044 is a reply to message #620042] |
Thu, 10 January 2008 00:13   |
Hi Luca,
Luca Bacco wrote:
<stuff deleted>
For XMPP servers the answer is no...because XMPP has no concept of a
'group'. So the
BaseSharedObject.sendSharedObjectMsgTo(ID toID, SharedObjectMsg msg)
method will send a message to a given receiver (toID)...OR, if toID is
null, to all members of the group defined by the container. For XMPP
there is no group, and so if toID is null an exception will be thrown.
OTOH, if you use the ECF generic server, toID can be null, and it will
be sent to all participants in the given group. There's an ECF generic
server running at ecftcp://ecf.eclipse.org:3282/server...and you can run
one yourself as an application as described here:
http://wiki.eclipse.org/ECF_Servers
getReplicaDescription(ID receiver) is called by the method
BaseSharedObject.replicateToRemoteContainers(ID[] remoteContainers)
to determine what ReplicaSharedObjectDescription instance to use for
creating a shared object replica on a given remote container.
In the test code for example (TestSharedObject):
You will notice that the event processor created in the init method ends
up calling replicateToRemoteContainers when the shared object is
activated (i.e. the ISharedObjectActivatedEvent). This ends up calling
getReplicaDescription(ID receiver). You should override this method to
return a non-null value for all receivers if you want it to be
replicated to all clients in the group. If getReplicaDescription
returns null, then this means no replication is done.
> a step?
The replica needs to be created as per the description above about
replicateToRemoteContainers and getReplicaDescription
> another client?
> AddTest.java)
Please let me know.Thanks I'll try to take a look at it over the
next few days, but maybe the description of the replication process as
described above will help. I'm happy to help support the project! It
sounds interesting.
Scott
> Bye,
> Luca
>> BaseSharedObject.
>> Scott
>>> Luca
Re: Question about ECF architecture [message #620055 is a reply to message #620050] |
Fri, 11 January 2008 13:32   |
Hi Pasquale,
I did write a little test code, and the use of shared objects in the
IChatRoomContainer for XMPP seems to be working OK. So you should
indeed be able to do this.
Note that the shared objects will *not* be created on the server (as the
Jive or other servers do know know anything of shared objects), but they
can be replicated to all clients that are in the given chat room.
I'll be adding this test to the suite of ECF tests...probably over this
coming weekend.
Scott
>> Hi Pasquale,
>> <stuff deleted>
>>> Hi scott,
>>> I'm new here. I work with luca to this case study.
>>> We want to share an object with users connected to the same room. So
>>> we would like to send a single shared object message to the room's ID
>>> and then have the server forwarding it to the other connected clients
>>> (which will update their replicas accordingly, in our hopes). Are we
>>> right in thinking in this way and can proceed accordingly?
>> Yes, although it will be necessary to create an xmpp chat room (on
>> xmpp server), and on the ECF-based client you will need to use an
>> IChatRoomContainer (see org.eclipse.ecf.presence bundle
>> presence.chatroom package).
>> The IChatRoomContainer is implemented as an ISharedObjectContainer, so
>> it should be possible to use
>> IContainer.getAdapter(ISharedObjectContainer.class) to get a non-null
>> reference to ISharedObjectContainer.
>> This facility (using an ISharedobjectContainer in an XMPP chat room)
>> has yet to be tested fully...but I would be willing to assist in the
>> testing/any needed fixes of using the ISharedObjectContainer adapter
>> within an XMPP chat room (IChatRoomContainer).
>> Note you can also see some example usage of IChatRoomContainer in the
>> org.eclipse.ecf.example.clients bundle.
>> Please let me know as you proceed and I will try to schedule some time
>> to setup some test code for the ISharedObjectContainer adapter (off of
>> an IChatRoomContainer).
>> Thanks,
>> Scott
> Thanks a lot for your suggestions!
> Pasquale.
Current Time: Fri Jul 25 16:07:14 EDT 2025
Powered by FUDForum. Page generated in 0.06557 seconds
