Home » Eclipse Projects » Platform - User Assistance (UA) » dynamic help / help view
dynamic help / help view [message #474160] Fri, 18 July 2008 06:41 Go to next message
In my RCP application I must show informations about each input element
in a complex form editor.
Those help informations should be available from the help system too.
I 'upgraded' from a customized browser widget to contex help with
success. Now I can use all the features of the help system like platform
URLs (which allows me to package my plugins as jars) or common css.
The disadvantage is the less control I have over the help view. The help
view is defined as sticky, what prevents me from placing it where I want
and to stay in one perspective.
1. Can I get rid of the sticky behaviour ? I already tried
equinox.tranforms but I learned that this solution is too heavyweight
for me.
2. If not, how can I use the help system features as described above in
a browser widget, e.g. get the help system to render a context help
html-page to pass to it ?
Sebastian
Re: dynamic help / help view [message #474163 is a reply to message #474160] Mon, 21 July 2008 18:14 Go to previous messageGo to next message
You can change the F1 behavior to open in an infopop rather than in the
help view. This is controlled by the preferences window_infopop and
dialog_infopop, see
http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/guide/ua_help_setup_preferences.htm
The second thing you would need to do to prevent the help view from
appearing is to fix help/search to show the external browser rather than
the help view. Unfortunately there is not a preference for this, there
probably should be. If that is important to you please open a bug report
and I'll see if I can attach a snippet to direct search to the browser.
Sebastian Fuchs wrote:
> Hello,
> for me.
> Thanks
> Sebastian
Re: dynamic help / help view [message #474164 is a reply to message #474163] Tue, 22 July 2008 06:14 Go to previous messageGo to next message
Thank You Chris,
unfortunatly none of both options apply to my requirements.
What I need is a (non-sticky) view where I can show a specific help topic.
Sebastian
> dialog_infopop, see
Re: dynamic help / help view [message #474168 is a reply to message #474164] Mon, 28 July 2008 07:08 Go to previous message
I managed to extract the URL the Help-System uses itself.
IHelpResource helpResource =
HelpSystem.getContext(contextID).getRelatedTopics()[0];
String href = helpResource.getHref();
url = PlatformUI.getWorkbench().getHelpSystem().resolve(href, true);
Then I pass this URL to a browser widget in a view.
Works great.
Sebastian
Re: dynamic help / help view [message #619283 is a reply to message #474160] Mon, 21 July 2008 18:14 Go to previous message
dialog_infopop, see
> Hello,
> for me.
> Thanks
> Sebastian
Re: dynamic help / help view [message #619285 is a reply to message #474163] Tue, 22 July 2008 06:14 Go to previous message
Thank You Chris,
Sebastian
> dialog_infopop, see
Re: dynamic help / help view [message #619296 is a reply to message #474164] Mon, 28 July 2008 07:08 Go to previous message
Works great.
Sebastian
Previous Topic:Redirection on Eclipse infocenter
Next Topic:Possible to set help context for a Perspective
Current Time: Mon Jun 16 17:24:29 EDT 2025
Powered by FUDForum. Page generated in 0.04005 seconds
