Home » Archived » Visual Editor (VE) » Clean Installation for Visual Editor in Eclipse
Clean Installation for Visual Editor in Eclipse [message #139696] Sat, 11 August 2007 16:12 Go to next message
even i had faced the same problem...
follow the following steps to have a clean installation of Visual Editor on
3.2
Click on
-> HELP
-> Software Updates
-> Find and Install
-> Search for new Features to Install
-> New Remote Site
--> Under "name: " WRITE "Callisto Discovery Site"
--> Under "URL: "http://download.eclipse.org/callisto/releases/"
--> press "OK"
-->Now under sites to include select "Callisto Discovery Site"
-->Press "Finish"
-->Then under "Callisto Discovery Site"
-->Select Java Development
-->Select Visual Editor 1.2.1
-->Select suitable GMF and EMF
-->then Next
-->Then Accept Terms and License Agreement
-->Then Next
-->Then Finish...
you are done!!!
Re: Clean Installation for Visual Editor in Eclipse [message #139783 is a reply to message #139696] Thu, 16 August 2007 03:54 Go to previous messageGo to next message
Originally posted by: giorger.gmail.com
I am trying to work with Visual Editor but it is a mindbongling and
nerve cracking situation...
I have installed the "europa" for java developers and followed the
underneath installation steps. Therefore, I can now create a visual
class but i get an eternal message "Setting up the visual editor" which
stucks at 25% and after long time it ends with either a parse error or
Null pointer exception. When it is done, I cannot see the visual tools
at the pallete.
Please tell me what to do, cause I cannot find out what is going on.
> 3.2
> Click on
> -> HELP
> -> Software Updates
> -> Find and Install
> -> New Remote Site
> --> press "OK"
> -->Press "Finish"
> -->then Next
> -->Then Next
> -->Then Finish...
> you are done!!!
Re: Clean Installation for Visual Editor in Eclipse [message #139794 is a reply to message #139783] Thu, 16 August 2007 07:26 Go to previous messageGo to next message
Eclipse Europa (3.3) is not supported by the manual descriped below, because
VE 1.2.1 is only working with Eclipse Callisto (3.2).
Erik Hecht is providing an (unofficial) version for Eclipse 3.3 (see VE out
of Eclipse Europa Thread).
Michael
"giwrgos" <giorger@gmail.com> schrieb im Newsbeitrag
news:fa0vrm$jft$1@build.eclipse.org...
>I am trying to work with Visual Editor but it is a mindbongling and nerve
> underneath installation steps. Therefore, I can now create a visual class
> but i get an eternal message "Setting up the visual editor" which stucks
> at 25% and after long time it ends with either a parse error or Null
> pointer exception. When it is done, I cannot see the visual tools at the
> pallete.
>> on
>> 3.2
>> Click on
>> -> HELP
>> -> Software Updates
>> -> Find and Install
>> -> New Remote Site
>> --> Under "URL:
>> --> press "OK"
>> -->Press "Finish"
>> -->then Next
>> -->Then Next
>> -->Then Finish...
>> you are done!!!
Re: Clean Installation for Visual Editor in Eclipse [message #139835 is a reply to message #139794] Sun, 19 August 2007 07:07 Go to previous message
Thanx a lot...
My general opinion is that with Eclipse, the whole setup of components
like Visual Editor or the integration with Tomcat is complicated...Hope
that it will be improved.
Re: Clean Installation for Visual Editor in Eclipse [message #616387 is a reply to message #139696] Thu, 16 August 2007 03:54 Go to previous message
at the pallete.
> 3.2
> Click on
> -> HELP
> -> Software Updates
> -> Find and Install
> -> New Remote Site
> --> press "OK"
> -->Press "Finish"
> -->then Next
> -->Then Next
> -->Then Finish...
> you are done!!!
Re: Clean Installation for Visual Editor in Eclipse [message #616388 is a reply to message #139783] Thu, 16 August 2007 07:26 Go to previous message
Michael
> pallete.
>> on
>> 3.2
>> Click on
>> -> HELP
>> -> Software Updates
>> -> Find and Install
>> -> New Remote Site
>> --> Under "URL:
>> --> press "OK"
>> -->Press "Finish"
>> -->then Next
>> -->Then Next
>> -->Then Finish...
>> you are done!!!
Re: Clean Installation for Visual Editor in Eclipse [message #616392 is a reply to message #139794] Sun, 19 August 2007 07:07 Go to previous message
Thanx a lot...
Previous Topic:Plans to bring back VE to eclipse 3.3 and later?
Next Topic:In the PropertySheet ,the propety if not set View but disable?
Current Time: Sat Jul 19 17:33:16 EDT 2025
Powered by FUDForum. Page generated in 0.04673 seconds
