Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection
[Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #116341] Sun, 30 March 2008 20:04 Go to next message
Originally posted by: user.example.net
I am trying to go through the library tutorial, but I keep getting the
following error. Any ideas?
Thank you,
Calin
SEVERE: illegal access to loading collection
collection
at
org.hibernate.collection.AbstractPersistentCollection.initia lize(AbstractPersistentCollection.java:341)
at
org.hibernate.collection.AbstractPersistentCollection.read(A bstractPersistentCollection.java:86)
at
org.hibernate.collection.AbstractPersistentCollection.readSi ze(AbstractPersistentCollection.java:109)
at org.hibernate.collection.PersistentList.size(PersistentList. java:91)
at
org.eclipse.emf.common.util.DelegatingEList.delegateSize(Del egatingEList.java:231)
at
org.eclipse.emf.teneo.mapping.elist.PersistableEList.delegat eSize(PersistableEList.java:442)
at
org.eclipse.emf.common.util.DelegatingEList.size(DelegatingE List.java:222)
at
org.eclipse.emf.ecore.util.DelegatingEcoreEList.contains(Del egatingEcoreEList.java:447)
at org.eclipse.emf.edit.command.AddCommand.prepare(AddCommand.j ava:335)
at
org.eclipse.emf.common.command.AbstractCommand.canExecute(Ab stractCommand.java:114)
at
org.eclipse.emf.edit.command.AbstractOverrideableCommand.doC anExecute(AbstractOverrideableCommand.java:118)
at
org.eclipse.emf.edit.command.AbstractOverrideableCommand.can Execute(AbstractOverrideableCommand.java:111)
at
org.eclipse.emf.common.command.CommandWrapper.prepare(Comman dWrapper.java:169)
at
at
org.eclipse.emf.edit.ui.action.StaticSelectionCommandAction. configureAction(StaticSelectionCommandAction.java:147)
at
org.eclipse.emf.edit.ui.action.CreateChildAction.<init>(CreateChildAction.java:53)
at
org.eclipse.emf.edit.ui.action.CreateChildAction.<init>(CreateChildAction.java:63)
at
org.eclipse.example.library.presentation.LibraryActionBarCon tributor.generateCreateChildActions(LibraryActionBarContribu tor.java:304)
at
org.eclipse.example.library.presentation.LibraryActionBarCon tributor.selectionChanged(LibraryActionBarContributor.java:2 80)
at
org.eclipse.example.library.presentation.LibraryEditor.setSe lection(LibraryEditor.java:1682)
at
org.eclipse.example.library.presentation.LibraryEditor$6.sel ectionChanged(LibraryEditor.java:877)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
at
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:2047)
at
org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.java:1138)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer.java:1168)
at
org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:227)
at org.eclipse.jface.util.OpenStrategy.access$3(OpenStrategy.ja va:221)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:388)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #116399 is a reply to message #116341] Mon, 31 March 2008 04:01 Go to previous messageGo to next message
Hi Calin,
I have replayed the tutorial and I don't get this exception. Can you describe which steps you take
to open the editor and which editing actions you do? Then I can try to replicate your steps.
gr. Martin
Calin Medianu wrote:
> Thank you,
> Calin
> collection
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #116445 is a reply to message #116399] Tue, 01 April 2008 01:45 Go to previous messageGo to next message
Hi Martin,
Thank you for responding. I don't do anything special, I start a new
Eclipse Application from the Run menu, including the workspace plugins,
then in the new Eclipse I do File -> New -> Library Model. A new library
is created at this point. When I click on it, to add children, I get the
error. Is there a version of the finished tutorial available somewhere
so I can maybe compare mine with that one, see what's different?
Thank you,
Calin
> Hi Calin,
> describe which steps you take to open the editor and which editing
> gr. Martin
>> Hi,
>> Thank you,
>> Calin
>> collection
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #116469 is a reply to message #116445] Tue, 01 April 2008 03:38 Go to previous messageGo to next message
Hi Calin,
I have put the Library example (for emf 2.3) in the following cvs location:
host: dev.eclipse.org
cvs root: /cvsroot/modeling
module: org.eclipse.emf/org.eclipse.emf.teneo/examples/library (emf 2.3)
You can find the source code changes if you look for the string teneo.start or teneo.end.
There are two additional changes:
- in the plugin.xml of the model project I have changed the extension point to use the
HibernateResourceFactory
- the manifest.mf of the model project has two extra dependencies: one for the hibernate.teneo
plugin and one for a plugin containing all hibernate.jar files. This last plugin is not in cvs
because of licensing reasons. Both dependencies have re-export on true.
Have you set the buddypolicy of the Hibernate plugin to dependent?
The above changes are described in the tutorial also (so afaics I did not do anything other then
what was described in the tutorial).
Let me know if you see any differences with your setup.
I will add the cvs link to the tutorial.
gr. Martin
> Hi Martin,
> Thank you,
> Calin
>> Hi Calin,
>> gr. Martin
>>> Hi,
>>> the following error. Any ideas?
>>> Thank you,
>>> Calin
>>> collection
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
The Netherlands
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #116506 is a reply to message #116469] Tue, 01 April 2008 14:41 Go to previous messageGo to next message
Hello Martin,
This works much better :) I'll go through the tutorial again to see
where mine was different.
Small problem though. If I create a new book and just accept the default
category (Mistery) and pages (0), the category and pages are not set on
the new object, the save fails and the editor crashes.
Is there a quick way to restart the editor without going through the
File -> New wizard, that creates a new library? The problem is that the
state of the editor is never saved on the disk, the way it was in the
..library file..
Thanks a lot!
Calin
Hibernate: update "library" set e_version=?, "name"=? where e_id=? and
e_version=?
Hibernate: select books0_."writer_e_id" as writer1_2_,
books0_."book_e_id" as book2_2_, books0_."writer_books_idx" as
writer3_2_, book1_.e_id as e1_0_0_, book1_.e_version as e3_0_0_,
book1_."title" as title4_0_0_, book1_."pages" as pages5_0_0_,
book1_."category" as category6_0_0_, book1_."book_author_e_id" as
book7_0_0_, book1_.econtainer_class as econtainer10_0_0_,
book1_.e_container as e11_0_0_, book1_.e_container_featureid as
e12_0_0_, writer2_.e_id as e1_2_1_, writer2_.e_version as e3_2_1_,
writer2_."name" as name4_2_1_, writer2_.econtainer_class as
econtainer7_2_1_, writer2_.e_container as e8_2_1_,
writer2_.e_container_featureid as e9_2_1_ from "writer_books" books0_
left outer join "book" book1_ on books0_."book_e_id"=book1_.e_id left
outer join "writer" writer2_ on book1_."book_author_e_id"=writer2_.e_id
where books0_."writer_e_id"=?
1-Apr-2008 11:22:15 AM org.eclipse.emf.teneo.TeneoException <init>
SEVERE: Diagnosis of
org.eclipse.example.library.impl.BookImpl@1d88c1f{platform:/resource/test/My.library#/0/@books.1}
The required feature 'pages' of
'org.eclipse.example.library.impl.BookImpl@1d88c1f{platform:/resource/test/My.library#/0/@books.1}'
must be set
The required feature 'category' of
must be set
org.eclipse.emf.teneo.StoreValidationException: Diagnosis of
must be set
must be set
at
org.eclipse.emf.teneo.resource.StoreResource.validateContent s(StoreResource.java:409)
at
org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:347)
at
org.eclipse.example.library.presentation.LibraryEditor$18.ex ecute(LibraryEditor.java:1461)
at
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
at
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
> Hi Calin,
> point to use the HibernateResourceFactory
> for the hibernate.teneo plugin and one for a plugin containing all
> hibernate.jar files. This last plugin is not in cvs because of licensing
> not do anything other then what was described in the tutorial).
> gr. Martin
>> Hi Martin,
>> plugins, then in the new Eclipse I do File -> New -> Library Model. A
>> new library is created at this point. When I click on it, to add
>> children, I get the error. Is there a version of the finished tutorial
>> available somewhere so I can maybe compare mine with that one, see
>> what's different?
>> Thank you,
>> Calin
>>> Hi Calin,
>>> gr. Martin
>>>> Hi,
>>>> Thank you,
>>>> Calin
>>>> collection
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #116514 is a reply to message #116506] Tue, 01 April 2008 15:07 Go to previous messageGo to next message
Hi Calin,
This is actually more an issue with that EMF assumes these mandatory features to be unset because it
compares the value with the default value. See the italic text here:
http://www.elver.org/hibernate/tutorialtwo/tutorial2_2.html
I remember thet this topic was discussed earlier on the newsgroup.
For starting the editor directly without going through the wizard, see here:
http://www.elver.org/hibernate/resource_utility.html
When you use this utility, see also the remark in italic:
http://www.elver.org/hibernate/tutorialtwo/tutorial2_1.html
gr. Martin
> Hello Martin,
> ..library file..
> Thanks a lot!
> Calin
> e_version=?
> must be set
> must be set
> must be set
> must be set
> at
> at
> at
> at
> at
> at
> at
>> Hi Calin,
>> location:
>> gr. Martin
>>> Hi Martin,
>>> tutorial available somewhere so I can maybe compare mine with that
>>> Thank you,
>>> Calin
>>>> Hi Calin,
>>>> gr. Martin
>>>>> Hi,
>>>>> Thank you,
>>>>> Calin
>>>>> loading collection
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
The Netherlands
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #116523 is a reply to message #116514] Tue, 01 April 2008 15:44 Go to previous message
Thank you very much!
Calin
> Hi Calin,
> features to be unset because it compares the value with the default
> here:
> gr. Martin
>> Hello Martin,
>> default category (Mistery) and pages (0), the category and pages are
>> not set on the new object, the save fails and the editor crashes.
>> the state of the editor is never saved on the disk, the way it was in
>> the ..library file..
>> Thanks a lot!
>> Calin
>> e_version=?
>> book1_."book_author_e_id"=writer2_.e_id where books0_."writer_e_id"=?
>> must be set
>> must be set
>> must be set
>> must be set
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Hi Calin,
>>> location:
>>> one for the hibernate.teneo plugin and one for a plugin containing
>>> all hibernate.jar files. This last plugin is not in cvs because of
>>> gr. Martin
>>>> Hi Martin,
>>>> A new library is created at this point. When I click on it, to add
>>>> Thank you,
>>>> Calin
>>>>> Hi Calin,
>>>>> you describe which steps you take to open the editor and which
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> Thank you,
>>>>>> Calin
>>>>>> loading collection
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #616034 is a reply to message #116341] Mon, 31 March 2008 04:01 Go to previous message
Hi Calin,
gr. Martin
> Thank you,
> Calin
> collection
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #616040 is a reply to message #116399] Tue, 01 April 2008 01:45 Go to previous message
Hi Martin,
Thank you,
Calin
> Hi Calin,
> gr. Martin
>> Hi,
>> Thank you,
>> Calin
>> collection
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #616043 is a reply to message #116445] Tue, 01 April 2008 03:38 Go to previous message
Hi Calin,
gr. Martin
> Hi Martin,
> Thank you,
> Calin
>> Hi Calin,
>> gr. Martin
>>> Hi,
>>> Thank you,
>>> Calin
>>> collection
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
The Netherlands
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #616049 is a reply to message #116469] Tue, 01 April 2008 14:41 Go to previous message
Hello Martin,
..library file..
Thanks a lot!
Calin
e_version=?
must be set
must be set
must be set
must be set
at
at
at
at
at
at
> Hi Calin,
> gr. Martin
>> Hi Martin,
>> what's different?
>> Thank you,
>> Calin
>>> Hi Calin,
>>> gr. Martin
>>>> Hi,
>>>> Thank you,
>>>> Calin
>>>> collection
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #616050 is a reply to message #116506] Tue, 01 April 2008 15:07 Go to previous message
Hi Calin,
gr. Martin
> Hello Martin,
> ..library file..
> Thanks a lot!
> Calin
> e_version=?
> must be set
> must be set
> must be set
> must be set
> at
> at
> at
> at
> at
> at
> at
>> Hi Calin,
>> location:
>> gr. Martin
>>> Hi Martin,
>>> Thank you,
>>> Calin
>>>> Hi Calin,
>>>> gr. Martin
>>>>> Hi,
>>>>> Thank you,
>>>>> Calin
>>>>> loading collection
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
The Netherlands
Re: [Teneo] org.hibernate.LazyInitializationException: illegal access to loading collection [message #616051 is a reply to message #116514] Tue, 01 April 2008 15:44 Go to previous message
Calin
> Hi Calin,
> here:
> gr. Martin
>> Hello Martin,
>> Thanks a lot!
>> Calin
>> e_version=?
>> must be set
>> must be set
>> must be set
>> must be set
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Hi Calin,
>>> location:
>>> gr. Martin
>>>> Hi Martin,
>>>> Thank you,
>>>> Calin
>>>>> Hi Calin,
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> Thank you,
>>>>>> Calin
>>>>>> loading collection
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Previous Topic:Deleting objects
Next Topic:class hierarchies
Current Time: Wed Aug 20 16:24:35 EDT 2025
Powered by FUDForum. Page generated in 0.08536 seconds
