Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Build update: new GMF tutorial, Entity.extends annotation, many-to-one with containment==tru
[Teneo] Build update: new GMF tutorial, Entity.extends annotation, many-to-one with containment==tru [message #115036] Mon, 17 March 2008 21:17 Go to next message
The latest build of Teneo contains a number of changes:
- Integration with GMF: the integration with GMF has been re-visited. The tutorial has been updated.
The latest release of Teneo supports persisting the model as well as the diagram in the same
database. See the tutorial on elver.org for more details. Let me know if the tutorial needs to be
changed to accomodate different situations.
- For hibernate the UPDATE_SCHEMA option has been removed, the corresponding hibernate option
hibernate.hbm2dll_auto should be used.
- A number of issues related to the HibernateResource have been solved
- A many-to-one with containment=true and required=true will now also have a unique constraint
- The Hibernate propertyhandlers will not set a value in an EObject if the current value and new
value are object equal (==), before only a check on null was done.
- Teneo is also available for Eclipse 3.4. Use the stable builds (prefixed with S) for Eclipse 3.4,
the I-builds should be used for Eclipse 3.3. The code base of both builds is exactly the same.
And a number of other issues have been solved, please check the release notes.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Build update: new GMF tutorial, Entity.extends annotation, many-to-one with containment= [message #115049 is a reply to message #115036] Tue, 18 March 2008 11:13 Go to previous message
I think it's hibernate.hbm2ddl_auto not hibernate.hbm2dll_auto.
Thanks for the new build, Martin!
> The tutorial has been updated. The latest release of Teneo supports
> persisting the model as well as the diagram in the same database. See
> needs to be changed to accomodate different situations.
> corresponding hibernate option hibernate.hbm2dll_auto should be used.
> the current value and new value are object equal (==), before only a
> (prefixed with S) for Eclipse 3.4, the I-builds should be used for
> notes.
Re: [Teneo] Build update: new GMF tutorial, Entity.extends annotation, many-to-one with containment= [message #615927 is a reply to message #115036] Tue, 18 March 2008 11:13 Go to previous message
> notes.
Previous Topic:[Teneo] Build update: new GMF tutorial, Entity.extends annotation, many-to-one with containment==tru
Next Topic:Emfatic update site
Current Time: Sun Jul 27 16:11:09 EDT 2025
Powered by FUDForum. Page generated in 0.03636 seconds
