Home » Archived » Eclipse Communications Framework (ECF) » OSGi XMPP
OSGi XMPP [message #615224] Wed, 18 April 2007 10:30 Go to next message
Originally posted by: ricker.distributedinstruments.com
Has there been any discussion of creating an OSGi service for XMPP
similar to the OSGi HTTP service? Looking into the ECF architecture, I
expected to find such a lower level service with the higher level ECF
functionality built on top. This service would be especially useful as
the Eclipse community moves forward with server side OSGi.
- Ricker
Re: OSGi XMPP [message #615240 is a reply to message #615224] Wed, 18 April 2007 12:37 Go to previous messageGo to next message
Hi Ricker,
There hasn't been any requests for this to this point, but it is an
excellent idea.
ECF already has a 'presence service' interface
(org.eclipse.ecf.presence.service.IPresenceService) that is intended for
exposing the presence API as an OSGi service. XMPP implements that
service interface, but I don't think that currently it is actually
registering itself as an IPresenceService. This is a trivial thing to
do/add, however.
So although there hasn't been any discussion about it, basically it's
already there.
Note that we also have/register the following services:
identity factory
container factory
discovery API
filetransfer API
and we can/could add more (i.e. the presence API).
If you would like to file a bug/enhancement request specifically for the
presence service it would be most appreciated.
Scott
> - Ricker
Simple Headless XMPPS Container [message #615251 is a reply to message #615224] Fri, 20 April 2007 07:48 Go to previous message
Hi ECF,
I need to use the ECF libs in a headless, programmatic way outside of
OSGi/Eclipse runtime. The code I've used in the past allowed me to add
the Container type description so that I could get an IContainer from
the factory and proceed with getting a connection.
Unfortunately, the API has changed quite a bit and the working code I
had is now broken. Could somebody help me out with a working code
snippet to create an ecf.xmpps.smack container outside of Eclipse?
The old working code is below. I tried experimenting with
BaseContainerInstantiator, but now even ContainerFactory.getDefault() is
throwing NullPointerExceptions in headless, non-Eclipse runtime.
Bob
Old ECF 0.7-0.8 Working Code
// Create IContainerInstantiator manually
IContainerInstantiator instantiator = new ContainerInstantiator();
// Create a container description that associates the
// appropriate name with the instantiator
// These values from org.eclipse.ecf.example.collab plugin.xml
//<containerFactory> element
String[] argTypes =
{"org.eclipse.ecf.core.identity.ID","java.lang.Integer"};
String[] argDefaults = {"","30000"};
String[] argNames = {"id", "keepAlive"};
// Generic used here, but ecf.xmpps.smack desired
ContainerTypeDescription cd = new
ContainerTypeDescription("ecf.generic.client",
instantiator,"ecf.generic.client", argTypes, argDefaults, argNames);
// Add this new description to ContainerFactory
IContainerFactory factory = ContainerFactory.getDefault();
factory.addDescription(cd);
Previous Topic:ECF Skype Provider
Next Topic:ECF Bundle Documentation
Current Time: Tue Jun 17 03:29:39 EDT 2025
Powered by FUDForum. Page generated in 0.22303 seconds
