Home » Eclipse Projects » Platform - User Assistance (UA) » Re: Providing contextual help in tooling
Re: Providing contextual help in tooling [message #473742] Thu, 08 May 2008 13:17 Go to next message
David Whiteman wrote:
> Chris Aniszczyk wrote:
>> If you create a view using one of the PDE templates, there should be a
>> checkbox that says "create context help." With that, the template
>> should generate the proper context xml files for you along with the
>> html file. Furthermore, it will also add the hook where it informs the
>> Platform that you're providing context-sensitive (F1) help.
>> Let me know if this helps, if not, I can blog about this.
>> Cheers,
>> ~ Chris
> I've had the view for a long time and did not use the templates when I
> created it initially. However, I can certainly generate a dummy view
> just to see what is needed, and then copy that approach for my plugin.
> Thanks, Chris!
> David
OK, I have set this up. What I've observed is you can add help hooks to
any control, which takes you to a context that can link you to a topic
in the documentation.
What I'd like to do is have the help hook go straight to the
documentation. If the documentation describes the indicated control,
why should the user have to read something like "This is the panic
button." and click on a link to see the real documentation? Plus, this
introduces more maintenance if you have more to document in the
contexts.xml file.
It would be nice if I could define a <context> and then indicate that a
<topic> auto-loads. That would solve the problem I mentioned nicely.
[Cross posting to eclipse.platform.ua, since I just learned of that
group, and this really belongs there.]
David
Re: Providing contextual help in tooling [message #473743 is a reply to message #473742] Thu, 08 May 2008 13:45 Go to previous messageGo to next message
If you use Eclipse 3.4M7 or later a context with a single topic and no
description will take you straight to the page in the link.
Re: Providing contextual help in tooling [message #473744 is a reply to message #473743] Thu, 08 May 2008 17:17 Go to previous message
Wow, exactly what I was looking for. Thanks!
Re: Providing contextual help in tooling [message #614204 is a reply to message #473742] Thu, 08 May 2008 13:45 Go to previous message
Re: Providing contextual help in tooling [message #614208 is a reply to message #473743] Thu, 08 May 2008 17:17 Go to previous message
Previous Topic:When does help preference "Use external browser" take effect?
Next Topic:In what Eclipse source plug-in/file is default "ButtonFace" color set?
Current Time: Wed Jul 23 18:10:54 EDT 2025
Powered by FUDForum. Page generated in 0.03661 seconds
