Home » Archived » Visual Editor (VE) » Mustang (java 1.6)
Mustang (java 1.6) [message #118235] Fri, 17 February 2006 05:15 Go to next message
Originally posted by: pierre.couvy.free.fr
Hi all :)
Does anyone know if there is any trouble using mustang with VE ?
I'm running linux + mustang + eclipse (3.1.2 and VE 1.1.0.1 or 3.2M4 and
VE 1.2M1). And i get horrible crash when i try the basic "New>Visual
Class". The JVM, itself, crashes when VE is trying to draw the component
in the design tab.
All i've got is a dialog window saying :
JVM terminated. Exit code=1
/usr/bin/java
-Xms40m
-Xmx256m
-jar /opt/eclipse/startup.jar
-os linux
-ws gtk
-arch x86
-launcher /opt/eclipse/eclipse
-name Eclipse
-showsplash 600
-exitdata 62000a
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx256m
I also find a .log file (44ko) in my home directory :
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0xb4bf9458, pid=18484, tid=3084839856
# Java VM: Java HotSpot(TM) Client VM (1.6.0-rc-b71 mixed mode, sharing)
# Problematic frame:
# C [libcairo.so.2+0x16458]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x08057800): JavaThread "main" [_thread_in_native,
id=18485]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x00d487fb
Registers:
EAX=0x00000000, EBX=0xb4c37470, ECX=0xb4c37470, EDX=0x00d487c7
ESP=0xb7dece5c, EBP=0x08ef0170, ESI=0x08ef01f4, EDI=0x08ef0274
EIP=0xb4bf9458, CR2=0x00d487fb, EFLAGS=0x00010246
Top of Stack: (sp=0xb7dece5c)
0xb7dece5c: b4bed234 b5d1c86b 00000000 b5d1c86b
0xb7dece6c: b4bf03da 08ef01f4 b5d1c86b 40240000
0xb7dece7c: 00000000 40240000 b7f41880 00000030
0xb7dece8c: b4c37470 08ef0138 b5d1c86b b7decec8
0xb7dece9c: b4be98e4 b5d1c86b 08057800 b5d14d0d
0xb7deceac: 08058044 b451cd7c 9274b850 08057800
0xb7decebc: b45196c6 b5d1c86b 9274b850 b7decf08
0xb7dececc: b5d1c96d 080578e4 b7decf10 00000000
Instructions: (pc=0xb4bf9458)
0xb4bf9448: 2c c3 8d b6 00 00 00 00 8b 44 24 04 8b 10 31 c0
0xb4bf9458: 8b 4a 34 85 c9 75 0d 8b 42 30 83 f8 01 19 c0 f7
Stack: [0xb7d9e000,0xb7def000), sp=0xb7dece5c, free space=315k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code,
C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.eclipse.swt.internal.cairo.Cairo.cairo_create()I+0
j org.eclipse.swt.graphics.GC.initCairo()V+27
j org.eclipse.swt.graphics.GC.setAlpha(I)V+35
j org.eclipse.draw2d.SWTGraphics.setAlpha(I)V+39
j
org.eclipse.ve.internal.cde.core.OutlineBorder.paint(Lorg/ec lipse/draw2d/IFigure;Lorg/eclipse/draw2d/Graphics;Lorg/eclip se/draw2d/geometry/Insets;)V+35
j org.eclipse.draw2d.Figure.paintBorder(Lorg/eclipse/draw2d/Gr aphics;)V+16
and so on
Do i found a regression ? do i win a sparc :)) ?
Re: Mustang (java 1.6) [message #118257 is a reply to message #118235] Fri, 17 February 2006 07:27 Go to previous messageGo to next message
Looks like it's an SWT crash when working with cairo. Can you run Java
1.4 or 1.5 on the same system to see if the same problem occurs? What
version of the cairo libs do you have installed on your system?
- Jeff
Re: Mustang (java 1.6) [message #118267 is a reply to message #118257] Fri, 17 February 2006 07:58 Go to previous messageGo to next message
> - Jeff
thanks for the reply
it's the next step... just have to find time to do this ;)
i previously upgrade mustang since i used on older version of 1.6 (b70).
i'll post the results with tiger.
Re: Mustang (java 1.6) [message #118277 is a reply to message #118257] Fri, 17 February 2006 08:08 Go to previous messageGo to next message
> - Jeff
Just another comment : it's a JVM crash when it's running SWT classe
(cairo) which running native code. I mean, i haven't got a
NullPointerException or something like that. The JVM crashes without any
"java" explanation.
Re: Mustang (java 1.6) [message #118311 is a reply to message #118267] Fri, 17 February 2006 12:53 Go to previous messageGo to next message
>> Thanks,
>> - Jeff
in fact tiger do the same. The only diff is that i haven't the .log file
will try with 1.4 later
Re: Mustang (java 1.6) [message #118320 is a reply to message #118311] Fri, 17 February 2006 13:15 Go to previous messageGo to next message
That most likely indicates that the version of cairo that you have
installed is not compatible with SWT. SWT requires Cairo version 0.4.0
or later: http://www.eclipse.org/swt/faq.php#nographicslibrary
Depending upon your Linux distribution you should be able to find
install packages for Cairo 1.0.2 (which I know works with SWT).
Hope this helps,
- Jeff
Re: Mustang (java 1.6) [message #118329 is a reply to message #118320] Fri, 17 February 2006 19:00 Go to previous message
> Hope this helps,
> - Jeff
you get it chief ;)
i had cairo1-0.3.0 installed...
i found and installed a cairo2-1.0.0 package.
the crash stayed
i removed the 1-0.3.0 one and now it's running fine !
many thanks.
Re: Mustang (java 1.6) [message #612140 is a reply to message #118235] Fri, 17 February 2006 07:27 Go to previous message
- Jeff
Re: Mustang (java 1.6) [message #612141 is a reply to message #118257] Fri, 17 February 2006 07:58 Go to previous message
> - Jeff
Re: Mustang (java 1.6) [message #612142 is a reply to message #118257] Fri, 17 February 2006 08:08 Go to previous message
> - Jeff
"java" explanation.
Re: Mustang (java 1.6) [message #612146 is a reply to message #118267] Fri, 17 February 2006 12:53 Go to previous message
>> Thanks,
>> - Jeff
Re: Mustang (java 1.6) [message #612147 is a reply to message #118311] Fri, 17 February 2006 13:15 Go to previous message
Hope this helps,
- Jeff
Re: Mustang (java 1.6) [message #612148 is a reply to message #118320] Fri, 17 February 2006 19:00 Go to previous message
> Hope this helps,
> - Jeff
you get it chief ;)
the crash stayed
many thanks.
Previous Topic:Parse Error and partial solution
Next Topic:using jgoodies and swinglabs classes
Current Time: Wed Jun 11 19:52:19 EDT 2025
Powered by FUDForum. Page generated in 0.05785 seconds
