| BeanInfo [message #89633] |
Wed, 04 May 2005 10:37  |
I have a beaninfo class Xbeaninfo in the same package as the class X. If I
debug (remote) the class Xbeaninfo the breakpoints in the class will not
be reached. (But If I debug the class comboboxbeaninfo the breakpoints
will be reached. It means the debug process is ok)
In what class in VE I could set the breakpoints to see if my beaninfo
class would be picked up?
Thank you in advance
Elena
| Re: BeanInfo [message #89745 is a reply to message #89633] |
Wed, 04 May 2005 13:11  |
Hi Elena,
Assuming that you have used the remote debugger to attach to the correct
VM (which is documented in the Help so I presume you have) the key class
to look at is java.beans.Introspector.
Joe
| Re: BeanInfo [message #607337 is a reply to message #89633] |
Wed, 04 May 2005 11:32  |
How did you do the debugging? BeanInfo is done in a special remote vm,
the IDE that is doing the debugging needs to have the BeanInfo class in
the project that the remote debugging session is using to do the debugging.
Elena wrote:
> Hello,
> I debug (remote) the class Xbeaninfo the breakpoints in the class will
> not be reached. (But If I debug the class comboboxbeaninfo the
> breakpoints will be reached. It means the debug process is ok)
> Elena
Rich Kulp
| Re: BeanInfo [message #607339 is a reply to message #89633] |
Hi Elena,
Joe
FUDForum. Page generated in 0.03403 seconds
