Home » Archived » Eclipse Communications Framework (ECF) » Is there any built-in API in Eclipse to support Radar Views?
Is there any built-in API in Eclipse to support Radar Views? [message #605143] Mon, 26 June 2006 22:46 Go to next message
Originally posted by: Chan_ryu.yahoo.com
Hi there,
I'm an undergraduate with a Singapore University majoring in computer
engineering. For my final year project I was to develop a collaborative
plugin for eclipse. This plugin is created in such a way that is based on a
server client architecture and a copy of the file is downloaded from the
server side. Each mouse movement/cursor is sent back to the server through
messages.
Now I would like to enquire if Eclipse has any built in support for radar
views meaning such that the Server can "see" where is the current
mouse/cursor is in Client A, Client B. ===> likened to a monitoring kind of
mode (think a security centre with multiple cameras looking at a particular
place).
My apologies if it sounds complicated. I hope someone will be kind enough to
hint me the right directions.
Thank You
Adrian
Re: Is there any built-in API in Eclipse to support Radar Views? [message #605160 is a reply to message #605143] Tue, 27 June 2006 11:15 Go to previous messageGo to next message
Hi Adrian,
I'm not sure I understand your intended application. Do you just
want the position of the mouse cursor from clients sent to a server when
they are using the Eclipse IDE, or do you want to see the desktop and
what is being typed, etc. even outside of Eclipse?
-Ken
Adrian Chan wrote:
> Hi there,
> messages.
> place).
> Thank You
> Adrian
Re: Is there any built-in API in Eclipse to support Radar Views? [message #605263 is a reply to message #605160] Wed, 28 June 2006 10:44 Go to previous messageGo to next message
Hi Ken,
Sorry for the confusion caused and thank you for replying.
I was hoping to find out if there were any Eclipse API that allows me to
have multiple views.
And yes, I would like to send the position of the mouse cursor to the server
with the intention of imaging/superimpose multiple cursors from various
views( from various desktops) into 1 common view.
Rgds
"Ken Gilmer" <kgilmer@gmail.com> wrote in message
news:e7ri21$c72$2@utils.eclipse.org...
> Hi Adrian,
> I'm not sure I understand your intended application. Do you just want
> the position of the mouse cursor from clients sent to a server when they
> are using the Eclipse IDE, or do you want to see the desktop and what is
> -Ken
> Adrian Chan wrote:
>> Hi there,
>> a
>> through
>> messages.
>> of
>> particular
>> place).
>> to
>> Thank You
>> Adrian
Re: Is there any built-in API in Eclipse to support Radar Views? [message #605267 is a reply to message #605263] Wed, 28 June 2006 11:00 Go to previous messageGo to next message
Adrian,
If by "view" you mean a ViewPart or a WorkbenchPart or something
Eclipse related, then no, there is no API for this sort of thing that
currently exists, as far as I know. If by "view" you mean computer
screen or window, I'd probably recommend using something like VNC in
read-only mode to achieve your goal, although that doesn't give you much
opportunity for Eclipse development...
-Ken
Adrian Chan wrote:
> Hi Ken,
> Rgds
>> Hi Adrian,
>> -Ken
>> Adrian Chan wrote:
>>> Hi there,
>>> a
>>> through
>>> messages.
>>> of
>>> particular
>>> place).
>>> to
>>> Thank You
>>> Adrian
Re: Is there any built-in API in Eclipse to support Radar Views? [message #605297 is a reply to message #605267] Thu, 06 July 2006 00:17 Go to previous message
Ok thanks Ken for yr advice
Adrian
news:e7u5ic$hfs$1@utils.eclipse.org...
> Adrian,
> If by "view" you mean a ViewPart or a WorkbenchPart or something Eclipse
> related, then no, there is no API for this sort of thing that currently
> exists, as far as I know. If by "view" you mean computer screen or
> window, I'd probably recommend using something like VNC in read-only mode
> to achieve your goal, although that doesn't give you much opportunity for
> -Ken
> Adrian Chan wrote:
>> Hi Ken,
>> server with the intention of imaging/superimpose multiple cursors from
>> various views( from various desktops) into 1 common view.
>> Rgds
>>> Hi Adrian,
>>> -Ken
>>> Adrian Chan wrote:
>>>> Hi there,
>>>> on a
>>>> the
>>>> through
>>>> messages.
>>>> radar
>>>> kind of
>>>> particular
>>>> place).
>>>> enough to
>>>> Thank You
>>>> Adrian
Previous Topic:ScribbleShare white board Plugin
Next Topic:ECF through internet
Current Time: Mon Jun 16 02:01:31 EDT 2025
Powered by FUDForum. Page generated in 0.05579 seconds
