Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo : where is the last release ?
Teneo : where is the last release ? [message #66489] Thu, 04 January 2007 15:19 Go to next message
Originally posted by: mat.loo.gmail.com
I want to update my Teneo from the release 1 week ago. But I cannot access
it, the 20061228 does not seem to be available for download on eclise.org.
Is there something I'm missing ?
Thx
Re: Teneo : where is the last release ? [message #66571 is a reply to message #66489] Thu, 04 January 2007 16:49 Go to previous messageGo to next message
Hi Mat,
There was a problem at eclipse.org which resulted in the builds not being copied to the download
server. This should be solved now.
The last build I did a few minutes ago can be downloaded.
gr. Martin
Mat Lo wrote:
> access it, the 20061228 does not seem to be available for download on
> eclise.org.
> Thx
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo : where is the last release ? [message #66611 is a reply to message #66571] Fri, 05 January 2007 04:30 Go to previous messageGo to next message
Ok, it works now, thanks !
Just a quick question : I have an null pointer error when Teneo tries to
recover the extension point "org.jpox.cache_level1", in JpoxDataStore:269.
I use PMFConfiguration."org.jpox.cache.level1.type" to set my Level1 cache
but no extension point ; am I not parameterizing well ?
Thx
Re: Teneo : where is the last release ? [message #66632 is a reply to message #66571] Fri, 05 January 2007 04:30 Go to previous messageGo to next message
I tried to add this extensoin point, but Eclipse does not show it as an
available extension point.
Thx
Re: Teneo : where is the last release ? [message #66653 is a reply to message #66632] Fri, 05 January 2007 04:44 Go to previous messageGo to next message
Which version of jpox are you using (teneo is on 1.1.3)?
See also here:
http://www.jpox.org/docs/1_1/extensions/level1_cache.html
gr. Martin
> cache but no extension point ; am I not parameterizing well ?
> Thx
The Netherlands
Re: Teneo : where is the last release ? [message #66719 is a reply to message #66653] Fri, 05 January 2007 08:42 Go to previous messageGo to next message
Hi again.
My problem was that I use 1.1.2, indeed !
But, I use jpox.jar as a library and not as a plugin of my dev platform.
But to have the extension point, I have to use it as a plugin. The problem
it seems to require some packages I feel strange :
oracle.*
So oracle is a requirement ?!
Furtermore, if I want to set up my environment correctly I have to ensure
the dependency from to Jpox to jdo.jar.
Till now, I had created a plugin with all needed .jar (jpox, jdo, log4j,
bcel...) and everything was great.
Since I want to update to 1.1.3, it seems mandatory to extend the
cache_level1 extension point and it causes problem..
Any idea ?
Thx
Re: Teneo : where is the last release ? [message #66737 is a reply to message #66719] Fri, 05 January 2007 09:22 Go to previous message
Hi Mat,
Did you read this page:
http://www.jpox.org/docs/1_1/extensions/plugins.html
I can't imagine that jpox has a dependency on oracle. I think that the jpox forum will give you some
more info (they are very responsive).
gr. Martin
Mat Lo wrote:
> Hi again.
> problem it seems to require some packages I feel strange :
> oracle.*
> ensure the dependency from to Jpox to jdo.jar.
> Any idea ?
> Thx
The Netherlands
Re: Teneo : where is the last release ? [message #600694 is a reply to message #66489] Thu, 04 January 2007 16:49 Go to previous message
Hi Mat,
gr. Martin
Mat Lo wrote:
> eclise.org.
> Thx
The Netherlands
Re: Teneo : where is the last release ? [message #600716 is a reply to message #66571] Fri, 05 January 2007 04:30 Go to previous message
Thx
Re: Teneo : where is the last release ? [message #600723 is a reply to message #66571] Fri, 05 January 2007 04:30 Go to previous message
Thx
Re: Teneo : where is the last release ? [message #600729 is a reply to message #66632] Fri, 05 January 2007 04:44 Go to previous message
See also here:
gr. Martin
> Thx
The Netherlands
Re: Teneo : where is the last release ? [message #600763 is a reply to message #66653] Fri, 05 January 2007 08:42 Go to previous message
Hi again.
oracle.*
Any idea ?
Thx
Re: Teneo : where is the last release ? [message #600766 is a reply to message #66719] Fri, 05 January 2007 09:22 Go to previous message
Hi Mat,
gr. Martin
Mat Lo wrote:
> Hi again.
> oracle.*
> Any idea ?
> Thx
The Netherlands
Previous Topic:Using Jet Transformation with EMF documents
Next Topic:Teneo: AnyTypeEObject class not found
Current Time: Sun Aug 31 03:30:44 EDT 2025
Powered by FUDForum. Page generated in 0.10348 seconds
