Home » Language IDEs » AspectJ » AJDT asking to enable weaving in Eclipse
AJDT asking to enable weaving in Eclipse [message #73887] Mon, 11 May 2009 09:03 Go to next message
Originally posted by: jacek.pospychala.pl.ibm.com
hi AJDT :-)
How does AJDT enable the aspects weaving support in the Eclipse it's
running? (To enable the advanced integration with JDT)
Which class does that?
Thanks!
Rational Elite Support for Eclipse
Re: AJDT asking to enable weaving in Eclipse [message #73905 is a reply to message #73887] Mon, 11 May 2009 09:27 Go to previous messageGo to next message
Ok, I see it:
org.eclipse.contribution.jdt.preferences.WeavingStateConfigu rer
in org.eclipse.contribution.jdt bundle.
Jacek
Jacek Pospychala pisze:
> hi AJDT :-)
> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #73940 is a reply to message #73905] Mon, 11 May 2009 18:50 Go to previous messageGo to next message
Originally posted by: andrew.eisenberg.springsource.com
That's right.
A description of how it is implemented is here:
http://wiki.eclipse.org/JDT_weaving_features
And org.eclipse.contribution.jdt.preferences.WeavingStateConfigu rerUI
provides UI support for it.
What are you trying to do?
On 11/05/09 6:27 AM, in article gu9938$eeo$1@build.eclipse.org, "Jacek
Pospychala" <jacek.pospychala@pl.ibm.com> wrote:
> Ok, I see it:
> Jacek
>> hi AJDT :-)
>> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #74011 is a reply to message #73940] Mon, 25 May 2009 09:05 Go to previous messageGo to next message
hi Andrew,
I was looking at how to most seamlessly plug into weaving Eclipse
plugins. My own plug-in would just contribute aspects, and I would not
have to worry whether weaving hook is enabled or not, but leave it to
user to enable/disable Weaving as it is done in AJDT/JDT integration.
I found that your code depends on JDT and the aspect that verifies
Weaving hook installation success also requires some particular JDT class.
I used that as an example for my own Weaving hook enabler. However
someone could come up with solution generic enough so that it would not
require JDT.
In my case I wanted to weave various plug-ins and not assume that JDT is
available.
Andrew Eisenberg pisze:
> That's right.
>> Ok, I see it:
>> Jacek
>>> hi AJDT :-)
>>> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #74029 is a reply to message #74011] Tue, 26 May 2009 14:48 Go to previous message
In your case, you might be better off using Equinox Aspects alone, without
using the JDT weaving service. EA is available from the AJDT update site.
Also, instructions on how to use it in your osgi application are available
here:
http://www.eclipse.org/equinox/incubator/aspects/index.php
On 25/05/09 6:05 AM, in article gve519$h73$1@build.eclipse.org, "Jacek
> hi Andrew,
> require JDT.
> available.
>> That's right.
>>> Ok, I see it:
>>> Jacek
>>>> hi AJDT :-)
>>>> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #599951 is a reply to message #73887] Mon, 11 May 2009 09:27 Go to previous message
Ok, I see it:
Jacek
> hi AJDT :-)
> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #599966 is a reply to message #73905] Mon, 11 May 2009 18:50 Go to previous message
That's right.
> Ok, I see it:
> Jacek
>> hi AJDT :-)
>> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #599997 is a reply to message #73940] Mon, 25 May 2009 09:05 Go to previous message
hi Andrew,
require JDT.
available.
> That's right.
>> Ok, I see it:
>> Jacek
>>> hi AJDT :-)
>>> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #600006 is a reply to message #74011] Tue, 26 May 2009 14:48 Go to previous message
here:
> hi Andrew,
> require JDT.
> available.
>> That's right.
>>> Ok, I see it:
>>> Jacek
>>>> hi AJDT :-)
>>>> Thanks!
Previous Topic:3.5M7 problem with eclipse preferences AspectJ Compiler
Next Topic:cannot install AJDT 1.6.4, org.eclipse.swt [3.4.0.v3448f]
Current Time: Thu Sep 18 12:02:48 EDT 2025
Powered by FUDForum. Page generated in 0.14829 seconds
