Home » Language IDEs » C / C++ IDE (CDT) » Latestest CDT builds: problems installing
Latestest CDT builds: problems installing [message #59928] Tue, 28 January 2003 10:10 Go to next message
Hi all,
There have been some sporadic problems reported regarding installing the CDT
in both Eclipse 2.0.x and 2.1.
The following is a guide to installing the CDT and a workaround for this
intermittent problem
If you unzip the bin.dist.zip file into the eclipse directory:
1) Be sure that all previous installations of the CDT have
been removed from your plugins and features directories
2) If the Install/Update manager will not let you install the CDT saying
something to the effect of Eclipse C/C++ Development Tools (Windows)
requires Eclipse C/C++ Development Tools 1.0.1
a) Eclipse will still install the plugins but it will disable them.
(Disabled plugins are not visible in the default view)
b) In the Install/Update Perspective, Install Configuration View
i) select the icon to show disabled features
ii) The Eclipse C/C++ Development Tools (Windows) will show as
disabled
iii) Click the "Enable" button in the Details Preview View
iv) Both plugins should now be fully enabled.
I will continue to look into why this is happening and hope to have it
solved in the near future
Re: Latestest CDT builds: problems installing [message #59978 is a reply to message #59928] Tue, 28 January 2003 16:59 Go to previous messageGo to next message
I've tried this and it still doesn't work - but I did find a possible
cause. This is the error I get after pressing "Enable" in the
Install/Update Manager:
Error creating feature "file:/C:/Program Files/eclipse/eclipse
2.0.2/features/org.eclipse.cdt_1.0.1.jar/".[java.io.FileNotFoundException:
C:\Program Files\eclipse\eclipse
2.0.2\features\org.eclipse.cdt_1.0.1.jar\feature.xml
The problem seems to be that it's looking for
"features/org.eclipse.cdt_1.0.1.jar", when the zip expansion actually
creates "features/org.eclipse.cdt_1.0.1" (no ".jar").
Does this help?
Josh
Judy N. Green wrote:
> Hi all,
> disabled
> ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨ ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨
> Judy N. Green Software Engineer
> Eclipse CDT Team www.eclipse.org/cdt
> QNX Software Systems Ltd. www.qnx.com
Re: Latestest CDT builds: problems installing [message #60008 is a reply to message #59928] Tue, 28 January 2003 17:50 Go to previous messageGo to next message
Originally posted by: sqlserverdude.hotmail.com
When I attempted to perform step 2)iii) in your workaround, I continue to
get an error. It indicates:
"file:C:IDE/eclipse/features/org.eclipse.cdt_1.0.1.jar".
C:\IDE\eclipse\features\org.eclipse.cdt_1.0.1.jar\feature.xm l (The system
cannot find the path specified)].
Obviously, feature.xml is in
"C:\IDE\eclipse\features\org.eclipse.cdt_1.0.1\" not
"C:\IDE\eclipse\features\org.eclipse.cdt_1.0.1.jar\"...
I was unable to come up with a workaround though. Ideas?
"Judy N. Green" <jgreen@qnx.com> wrote in message
news:b1659b$uku$1@rogue.oti.com...
> Hi all,
CDT
> disabled
Re: Latestest CDT builds: problems installing [message #60859 is a reply to message #60008] Mon, 03 February 2003 15:44 Go to previous messageGo to next message
Which platform are you working on?
I cannot reproduce the failure of the workaround on Win32 with Eclipse
2.0.1, 2.0.2 or M4.
I am looking at the build regarding the reference to
C:\IDE\eclipse\features\org.eclipse.cdt_1.0.1.jar, which is obviously not
correct.
-Judy
"D Gardner" <sqlserverdude@hotmail.com> wrote in message
news:b1707m$m2e$1@rogue.oti.com...
| > Hi all,
| CDT
| > disabled
Re: Latestest CDT builds: problems installing [message #60868 is a reply to message #60859] Mon, 03 February 2003 16:02 Go to previous message
Originally posted by: gjxl.pbtest.myhostdns.org
As acknowledged by me in thread "Problems with CE installation" this
happened to me in Eclipse 2.0.2 build 200211071448, and CDT 1.0.1 GA -
Windows, on Windows XP (SP 1). Same cause of error
(FileNotFoundException on the .jar/feature.xml). Have Eclipse installed
in c:/Program Files/eclipse.
I have the plugin working now, by reinstalling 1.0.0 CDT build, while
leaving 1.0.1 in the file system. Getting warnings that the main plugin
(1.0.0) is using 1.0.1 packages instead of 1.0.0 packages, so it seems
to pick what I want.
I also have the problem described in thread "CDT Debugging", which might
be due to the upgrade to 1.0.1, or to my upgrade of GDB to 2003-1-28.
> 2.0.1, 2.0.2 or M4.
> correct.
> Thanks
> -Judy
> | > Hi all,
> | CDT
> | > disabled
Previous Topic:Problems with cdt installation
Next Topic:Address breakpoints and watchpoints
Current Time: Sat Nov 01 20:43:54 EDT 2025
Powered by FUDForum. Page generated in 0.03794 seconds
