| Issue in building feature - Eclipse 3.4.1 [message #59739] |
Wed, 06 May 2009 00:10  |
We have our feature developed in Eclipse 3.4.1
I tried exporting it as an archive file using export wizard and then
extract it into a fresh eclipse install. I tried switching the perspective
to my feature and it worked properly.
Now, I tried building the same feature by referring to help contents -
Plug-in Development Environment Guide > Tasks > PDE Build
The build was successful. However, when I extracted the archive in my
eclipse folder and tried switching to my feature's perspective I got an
error - Problems opening perspective
'com.infy.finacle.fss.ui.FinaclePerspective'
And the error shown in error log is :
Root exception:
java.lang.NoClassDefFoundError:
com/infy/finacle/fss/core/metadata/managers/FSSAppMetadataMa nager
at com.infy.finacle.fss.ui.FSSUIPlugin.start(Unknown Source)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
Also, there is a discrepancy in the sizes of the jars of the plugins
created by exporting the feature and by building it.
What could have gone wrong here ?
| Re: Issue in building feature - Eclipse 3.4.1 [message #60067 is a reply to message #59858] |
Thu, 07 May 2009 07:30  |
Found out what went wrong. I accidentally used a version of eclipse while
building which was different from the version on which the feature was
developed. Its working fine now. Thanks for the helps anyways.
Nitin
>Andrew Niefer wrote:
> Are you just missing some of the class files, but most of the files are
> there?
> There is problem on windows if the path gets too long. Ant silently
> fails to copy some files and pde/build has no idea anything went wrong.
> Could that be your problem? I can't find the bug report for this now,
> but I think things work better with a 1.6 vm.
> Nitin Bohara wrote:
>> Hi,
>> perspective to my feature and it worked properly.
>> Root exception:
>> at
| Re: Issue in building feature - Eclipse 3.4.1 [message #596885 is a reply to message #59739] |
Wed, 06 May 2009 18:43  |
there?
Nitin Bohara wrote:
> Root exception:
> at
| Re: Issue in building feature - Eclipse 3.4.1 [message #596977 is a reply to message #59858] |
Nitin
> there?
> Nitin Bohara wrote:
>> Hi,
>> Root exception:
>> at
FUDForum. Page generated in 0.04837 seconds
