| Synchronization of fix version updated JIRA tasks [message #64501] | Tue, 20 January 2009 05:27  |  |
| Eclipse User  |  |  |  |  | Hi :)
 Before posting to the Mylyn team, I would like to know if the following
 is a bug :) Here are the differents steps :
 1- A JIRA task is updated on the JIRA server : precisely a new version is
 added to the project and the fix version of the task is modified to be now
 the newly added version. For example, there were 2 initial versions (2.2.3
 and 2.5), version 2.4 is added and the fix version of TASK-XXX is moved
 from 2.5 to 2.4 ;
 2- On Mylyn/Eclipse, TASK-XXX is opened. Fix versions listbox (Attributes
 section) contains 2.2.3 and 2.5 values. Then TASK-XXX is synchronized
 (F5). The link "Task has incoming changes" appears  ;
 3- Clicking on the link does not modify Fix versions listbox which still
 contains 2.2.3 and 2.5 values ;
 4- Every time the Synchronize action is done, link "Task has incoming
 changes" appears even if no modification on the JIRA has been done.
 It looks like a bug but did someone face this before ?
 Thanks in advance for your help and your advices
 Eric
| Re: Synchronization of fix version updated JIRA tasks [message #64524 is a reply to message #64501] | Tue, 20 January 2009 05:40  |  |
| Eclipse User  |  |  |  |  | Eric TOURNIER wrote: > Hi :)
 > is added to the project and the fix version of the task is modified to
 > be now the newly added version. For example, there were 2 initial
 > versions (2.2.3 and 2.5), version 2.4 is added and the fix version of
 > TASK-XXX is moved from 2.5 to 2.4 ;
 > (Attributes section) contains 2.2.3 and 2.5 values. Then TASK-XXX is
 > synchronized (F5). The link "Task has incoming changes" appears  ;
 > Eric
 You can update the server values by going to the query definition window
 and clicking the appropriate button (at least for trac and bugzilla).
 Does it work then?
 Perhaps a new feature for Mylyn could be that new server values are
 retrieved automatically when it encounters an unknown value during
 synchronization. Mylyn could also display a friendly dialog explaining
 that it had encountered unknown value and asks if the values should be
 updated from the repository. This dialog should contain a checkbox to
 disable the dialog, because maybe some bad configured repository causes
 tasks to be sent out with unknown properties that can never be retrieved.
 Jorrit
| Re: Synchronization of fix version updated JIRA tasks [message #595871 is a reply to message #64501] | Tue, 20 January 2009 05:40  |  |
 > Eric
 Does it work then?
 Jorrit
FUDForum. Page generated in 0.02579 seconds
