| Home » Eclipse Projects » DTP » Still can't create a connection
 Goto Forum:|
| Still can't create a connection [message #53986] | Thu, 02 April 2009 17:38  |  |
| Eclipse User  |  |  |  |  | I've been trying for three weeks, and I can't figure out to programmatically access a JDBC connection with DTP. My objective is to
 provide a plugin that wraps a JDBC connection, so that other plugins can
 create DB connections without having to know the physical location of the
 jar file, the driver class, etc.
 The approach I'm currently working on is to declare a driverExtension
 extension, which uses a driverOverride element to override the URL and
 dtabase name properties for the MySQL driver template included in the
 enablement plugin. Then I call ProfileManager.createProfile(), giving it
 an arbitrary name, description, and provider ID, as well as a Properties
 object that has the username, password and driver template ID (the ID of
 the driver template that I overrode).
 I can call methods on the profile created in this way, and when I call
 aerPropertiesComplete() it returns true. However, when I try to call
 createConnection() on the profile, I get a Null Pointer Exception. Looking
 in the DTP source code, there's only a single line in that method, and it
 is
 return  mProvider.getConnectionFactory(factoryId).createConnection(t his);
 I suspect it's the mProvider object that is null, because I provided an
 arbitrary name for the provider parameter when I called
 ConnectionProfileManager.createConnection(). I didn't think that was
 right, but I couldn't find anything that tells how to specify the
 provider, or if that's supposed to connect to the profile somehow.
 Maybe the provider is the missing link, or maybe I got something else
 wrong. Can someone please tell me what I have wrong and how I can access a
 connection?
 -Mark
| Re: Still can't create a connection [message #54057 is a reply to message #53986] | Thu, 02 April 2009 19:06   |  |
| Eclipse User  |  |  |  |  | Originally posted by: brianf.sybase.com
 What provider ID are you providing the create call?
 --Fitz
 "Mark Leone" <midnightjava@verizon.net> wrote in message
 news:7f2bf17f632058c4e75fad7f54d0035f$1@www.eclipse.org...
 > is
 > connection?
 > -Mark
| Re: Still can't create a connection [message #54108 is a reply to message #54057] | Thu, 02 April 2009 23:16   |  |
| Eclipse User  |  |  |  |  | Brian Fitzpatrick wrote: > What provider ID are you providing the create call?
 > --Fitz
 I tried a couple things. First I tried arbitrary text, maybe the name of
 my project or something like that, I'm not sure. Then I tried
 org.eclipse.datatools.enablement.mysql.connectionProfile
 Which is the ID of the Connection Profile from the enablement plugin's
 plugin.xml. I was desperate for something to use fo provider because I
 guess I'm missing wherever it is in the documentation that it explains
 what a provider is and how to use it.
 I've pasted below the relevant portion of my plugin.xml and the code I
 use to create the profile.
 Plugin.xml:
 (This attempts to override some driver properties of the driver template
 declared in the enablement plug-in's plugin.xml. I also tried repeating
 the enablement plug-in's driverTemplate element in my plugin.xml, since
 createDefault is set to false.)
 <extension point="org.eclipse.datatools.connectivity.driverExtension">
 <category
 id="org.eclipse.datatools.connectivity.db.driverCategory"
 name="Database"/>
 <driverTemplateOverride
 jarList="mysql-connector-java-5.1.7-bin.jar"
 name="Override for Generic JDBC Driver"
 targetId="org.eclipse.datatools.enablement.mysql.5_1.driverTemplate ">
 <propertyOverrides>
 <propertyOverride
 targetId="org.eclipse.datatools.connectivity.db.databaseName "
 name="Database Name"
 value="test"
 required="true"
 visible="true"/>
 <propertyOverride
 targetId="org.eclipse.datatools.connectivity.db.URL"
 name="Driver Connection URL"
 value="jdbc:mysql://localhost:3306/test"
 required="true"
 visible="true"/>
 </propertyOverrides>
 </driverTemplateOverride>
 </extension>
 And here's the code that attempts to create the profile. Debug output is
 added to resList and returned as an array because I call the method from
 a list view's content provider.
 public class ProfileWrapper {
 private List<String> resList = null;
 private String driverID = "";
 private String userName = "";
 private String password = "";
 public ProfileWrapper(String driverID, String userName, String
 password, List<String> resList){
 this.driverID = driverID;
 this.userName = userName;
 this.password = password;
 this.resList = resList;
 public IConnectionProfile getProfile(){
 IConnectionProfile profile = null;
 ProfileManager pfm = ProfileManager.getInstance();
 if (pfm == null){
 resList.add("No ProfileManager");
 else{
 try {
 pfm.deleteProfile(pfm.getProfileByName("MySQL"));
 } catch (ConnectionProfileException e2) {
 resList.add("Delete Profile: ConnectionProfileException:" +
 e2.getMessage());
 e2.printStackTrace();
 Properties props = new Properties();
 props.setProperty(ConnectionProfileConstants.PROP_DRIVER_DEF INITION_ID,
 driverID);
 props.setProperty(ConnectionProfileConstants.PROP_PWD, password);
 props.setProperty(ConnectionProfileConstants.PROP_UID, userName);
 try {
 pfm.createProfile("MySQL", "MySQL JDBC Driver",
 "org.eclipse.datatools.enablement.mysql.connectionProfile", props);
 } catch (ConnectionProfileException e1) {
 resList.add("Create Profile: ConnectionProfileException:"
 + e1.getMessage());
 e1.printStackTrace();
 profile = pfm.getProfileByName("MySQL");
 resList.add("Provider ID: " + profile.getProviderId());
 resList.add("Profile path: " + pfm.getProfilePath(profile));
 if (profile.arePropertiesComplete()){
 resList.add("Properties are complete");
 } else {
 resList.add("Properties are NOT complete");
 return profile;
| Re: Still can't create a connection [message #54160 is a reply to message #54134] | Fri, 03 April 2009 11:44   |  |
| Eclipse User  |  |  |  |  | I've made further progress, but still getting an exception. I found I was missing some of the dependencies of the enablement plug-in, so I added
 them to the target. Now I seem to be engaging the enablement code, and I
 get farther along.
 I no longer get an exception when I call connect() on the
 IConnectionProfile instance. But then I execute
 org.eclipse.datatools.connectivity.IConnection connection =
 connectionProfile.createConnection("java.sql.Connection");
 java.sql.Connection rawConn = (Connection)connection.getRawConnection();
 Statement s = rawConn.createStatement();//NPE thrown here
 And I get an NPE for the last statement, as shown.
 I also get an exception thrown from the DTP code, which appears to be the
 root cause of the NPE. That exception is
 java.lang.Exception: Driver definition could not be found.
 and it is thrown by
 org.eclipse.datatools.connectivity.DriverConnectionBase.getD riverDefinition
 at line 139.
 Looking at the source code, it appears that my driver definition ID is
 being passed to the profile instance, but the definition is not valid.
 Here's a snippet from getDriverDefinition() that shows where the above
 exception is being thrown. Previous to this snippet, a null check on the
 property PROP_DRIVER_DEFINITION_ID showed it was not null.
 mDriver = DriverManager.getInstance().getDriverInstanceByID(
 driverID);
 if (mDriver == null) {
 throw new Exception(...)); //$NON-NLS-1$
 I should also mention that I'm now getting an indication that all the
 properties on the profile are NOT complete. I'm setting
 PROP_DRIVER_DEFINITION_ID, PROP_PWD, and PROP_UID. Is there somewhere
 identified which properties need to be set?
| Re: Still can't create a connection [message #54186 is a reply to message #54160] | Fri, 03 April 2009 12:58   |  |
 Well that's great!
 The driver template alone isn't enough. You have to create a driver
 definition...
 String profileGenericJDBCDriverTemplateID =
 " org.eclipse.datatools.connectivity.db.generic.genericDriverT emplate ";
 String driverName = "MyDriver";
 String driverID = "MyDriverID";
 String driverClass = "org.apache.derby.jdbc.EmbeddedDriver"; //$NON-NLS-1$
 String driverURL = "jdbc:derby:" + dbPath + ";create=true"; //$NON-NLS-1$
 //$NON-NLS-2$
 String jarList = "C:\\Derby10.1.3.1\\db-derby-10.1.3.1-bin\\lib\\derby.jar";
 //$NON-NLS-1$
 IPropertySet propSet = new PropertySetImpl(driverName, driverID);
 Properties driverProperties = new Properties();
 driverProperties.setProperty(IJDBCConnectionProfileConstants .DRIVER_CLASS_PROP_ID,
 driverClass);
 driverProperties.setProperty(IDriverMgmtConstants.PROP_DEFN_ JARLIST,
 jarList);
 driverProperties.setProperty(IDriverMgmtConstants.PROP_DEFN_ TYPE,
 profileGenericJDBCDriverTemplateID);
 propSet.setBaseProperties(driverProperties);
 DriverManager.getInstance().addDriverInstance(propSet);
 Then you can use the driver definition ID for your connection profile
 properties...
 baseProperties.setProperty(ConnectionProfileConstants.PROP_D RIVER_DEFINITION_ID,
 driverID);
 See if that gets you any further...
 --Fitz
 news:939a8c3a79541b3417b62f76966a3796$1@www.eclipse.org...
 > get farther along.
 > and it is thrown by
 > at line 139.
 > driverID);
| Re: Still can't create a connection [message #54317 is a reply to message #54290] | Fri, 03 April 2009 18:18   |  |
| Eclipse User  |  |  |  |  | yes I understand what you're saying, except I don't know where I would be setting the version to 5.1.7. It's true that the jar file name ends in
 5.1.7, but I can't see anywhere else I'm setting the version number one
 way or the other.
 I did try setting the following properties on the driver before you told
 me how to set the same ones on the profile, by getting them form the
 driver instance in the profile.
 driverProperties.setProperty(IJDBCConnectionProfileConstants .DATABASE_VENDOR_PROP_ID,
 "MySQL");
 driverProperties.setProperty(IJDBCDriverDefinitionConstants. DATABASE_VENDOR_PROP_ID,
 "MySQL");
 driverProperties.setProperty(IJDBCConnectionProfileConstants .DATABASE_VERSION_PROP_ID,
 "5.1");
 driverProperties.setProperty(IJDBCDriverDefinitionConstants. DATABASE_VERSION_PROP_ID,
 "5.1");
 I set them with two different constants classes because I wasn't sure
 which one to use.
 Here's the statement for creating my profile, in case that relates.
 providerID, props);
 providerID is set to
 which is the only value I found to work, and it's the profile ID from the
 -Mark
| Re: Still can't create a connection [message #54370 is a reply to message #54343] | Fri, 03 April 2009 18:45   |  |
| Eclipse User  |  |  |  |  | Oops. silly error on my end. As yo may have noticed in my previous post, when I set the vendor name property in the driver, I used MySQL instead of
 MySql, which is how the extension point is defined in plugin.xml.
 So now it's working and there are no exceptions. I appreciate your help
 very much. I've been working on this off and on for a few weeks, and it's
 great to have it working going into the weekend.
 I do have one more question, however. I originally wanted to do this by
 declaring the properties for the driver in my plugin.xml. That way I can
 contribute one plug-in that would make the profile available to other
 plug-ins without running the Java code that sets the properties.
 It seemed straightforward how to do that using the driverTemplateOverride
 extension point. I was providing overriden values for jarList, URL, and
 database name, since the other driver properties were the same as that in
 the template i was overriding. Then I provided username and password as
 connection profile props. But I was getting the same NPE I was getting
 before you showed me how to set those properties in Java.
 I have a feeling the problem is with the jarList attribute for the
 driverTemplateOverride element. Is there a way to specify in teh XML a
 path relative to a plugin? For example, my plugin is called
 com.mysql.jdbc, and I'd like to specify a jarList path that's relative to
 that plug-in.
 The example uses
 [PLUGIN]\mydriver\driver.jar
 I thought I could therefore use
 com.mysql.jdbc\<relative path to the jar file>
 Is that correct? If so, I can look elsewhere for the problem. Thanks again.
 -Mark
| Re: Still can't create a connection [message #54478 is a reply to message #54370] | Mon, 06 April 2009 09:25   |  |
 Hey Mark!
 That's great news. You don't know how often I get killed by typos. :)
 As for specifying a plug-in wrapped driver jar, you can definitely do that
 using the [PLUGIN ID]/relative path method...
 So if your plug-in ID is "my.plugin.id", your jar path would look something
 like "my.plugin.id/libs/myjar.jar". If you have issues with that particular
 path, you can try flipping the slashes.
 The other option is to provide a "Driver Values Provider class" like I do
 with the SQLite and Derby drivers. This allows you to hunt in the
 plug-in/bundle registry for your driver plug-in wrapper and find the jar
 that way. You can find examples in
 o.e.d.enablement.sqlite.driver.SQLiteDriverValuesProvider and
 org.eclipse.datatools.connectivity.apache.internal.derby.dri ver.DerbyDriverValuesProvider101.
 Glad you're getting all of this working. I hope to have time to document all
 this stuff soon on the Wiki so it's much easier to find the next time
 someone goes looking. :)
 Thanks for your patience and like I said, don't hesitate to ask more
 questions. We'll be here. :)
 --Fitz
 news:99fadedf8fd2c0129883bd127f5a3531$1@www.eclipse.org...
 > that plug-in.
 > The example uses
 > again.
 > -Mark
| Re: Still can't create a connection [message #54505 is a reply to message #54478] | Mon, 06 April 2009 16:38   |  |
| Eclipse User  |  |  |  |  | Fitz,
 Thanks for the additional instructions. I just completed a plug-in that
 creates a profile bound to the MySQL driver, and with the desired profile
 properties set. This runs via early startup, which is problematic because
 there's no guarantee when execution will complete. For that reason I'm
 looking for a way to declare entirely via XML in plugin.xml the desired
 profile and driver characteristics, so other plug-ins can gab the profile
 from the Profile Manager and establish connections with it.
 I see the Profile definition in the enablement plug-in, and I'm able to
 grab that profile via the Profile Manager. But there's no driver
 associated with it, so if I call connect() on it, I get an NPE as I was
 doing originally. So now I understand how to declare override properties
 for the driver templates defined by the enablement plug-in, which I can
 use to point to my driver. But I don't understand how I can associate the
 driver that I override with the profile that is declared.
 Is there a way I can make this association purely in XML, so that when I
 grab the declared profile by name from the Profile Manager, I can call
 connect() on the profile and the connection will be established via the
 driver whose properties I overrode in plug-in.xml?
 -Mark
| Re: Still can't create a connection [message #54533 is a reply to message #54505] | Mon, 06 April 2009 16:57   |  |
 There is a way to do this, but I've not tried it...
 You can use the
 org.eclipse.datatools.connectivity.ProfileManagerInitializat ionProvider
 extension point to, when the connectivity plug-in fires up, create a profile
 with your specifications.
 I believe BIRT uses this extension point to create their Derby sample
 database at startup, but like I said, I haven't tried it.
 See if that does what you're looking for though. If you need more help, I
 can ask one of the other Connectivity folks who works on ODA & BIRT to help
 out.
 --Fitz
 news:a58e4586cba49f1af7dfbf43347a9dc3$1@www.eclipse.org...
 > Fitz,
 > -Mark
| Re: Still can't create a connection [message #54569 is a reply to message #54533] | Tue, 07 April 2009 10:34   |  |
| Eclipse User  |  |  |  |  | That's helpful info, Fitz. Thanks for all your efforts.
 The schema for ProfileManagerInitializationProvider is pretty
 straightforward, and I created a plug-in providing an implementation of
 that extension. I get an NPE when I grab the profile, which traces into
 the DTP source code indicating that the template is null when retrieved by
 ID.
 I pasted my plugin.xml below. The driver template ID I used is the one
 that appears in the enablement plugin.xml, and I made my plug-in dependent
 on the enablement plug-in.
 One question I have is how to implement the IExecutableExtension instance
 referenced by the connectionInitializer attribute. I see during runtime
 that the method on this class receives a Java representation of the
 elements and attributes I declared for the
 ProfileManagerInitializationProvider extension. I don't do anything with
 these in the method implementation, because I'm assuming that DTP is
 handling the task of creating the profile and driver definitions based on
 my declarations. Indeed it seems the profile gets created, but not the
 driver. Or maybe I need to do some initialization in the
 ExecutableExtension, although I'm hoping that won't be necessary. I'm
 trying to find the BIRT implementation you mentioned, and hopefully that
 will shed some light.
 Unless you happen to know the answer to my questions above, if you can
 point someone else on the Connectivity team to my post as you offered, I'd
 very much appreciate it.
 -Mark
 My plugin.xml:
 <?eclipse version="3.4"?>
 <plugin>
 <extension
 id=" com.tasc.swb.datatools.connctivity.mysql.profileManagerIniti alization "
 name="XML Generated MySQL Connection Profile"
 point=" org.eclipse.datatools.connectivity.ProfileManagerInitializat ionProvider ">
 <connection
 connectionInitializer=" com.tasc.swb.datatools.connectivity.mysql.declaredprofile.My SQLConnectionInitializer "
 connectionProfileID=" com.tasc.swb.datatools.connectivity.mysql.declaredProfile.co nnection1 "
 connectionProfileName=" com.tasc.swb.datatools.connectivity.mysql.declaredProfile.co nnection1 "
 driverDefinitionName=" com.tasc.swb.datatools.connectivity.mysql.declaredProfile.co nnection1 "
 driverTemplateID="org.eclipse.datatools.enablement.mysql.5_1.driverTemplate "
 jarList="com.mysql.jdbc/mysql-connector-java-5.1.7-bin.jar" >
 <property
 id="org.eclipse.datatools.connectivity.db.databaseName"
 value="prophet_test_db">
 </property>
 <property
 id="org.eclipse.datatools.connectivity.db.URL"
 value="jdbc:mysql://localhost:3306/prophet_test_db">
 </property>
 <property
 id="org.eclipse.datatools.connectivity.db.username"
 value="root">
 </property>
 <property
 id="org.eclipse.datatools.connectivity.db.password"
 value="squerdiddle1!">
 </property>
 </connection>
 </extension>
 </plugin>
| Re: Still can't create a connection [message #54650 is a reply to message #54569] | Tue, 07 April 2009 18:57   |  |
 In your driver template override, can you set createDefault = true and see
 if that fixes the problem?
 --Fitz
 news:02778f8973f54e6b78dda8c187a0804c$1@www.eclipse.org...
 > ID.
 > -Mark
 > My plugin.xml:
 > <plugin>
 >   <extension
 >      <connection
 >         <property
 >         </property>
 >         <property
 >         </property>
 >         <property
 >               value="root">
 >         </property>
 >         <property
 >         </property>
 >      </connection>
 >   </extension>
 > </plugin>
| Re: Still can't create a connection [message #54702 is a reply to message #54650] | Wed, 08 April 2009 11:12   |  |
 I thought about the createDefault attribute, but I didn't see how to
 override it. Since the ProfileManagerInitializationProvider extension has
 property members in its Connection element which are defined as property
 overrides for the driverTemplate, I assumed I didn't need a
 driverExtension extension with a driverTemplateOverride.
 But you seem to be saying I should be using a driverTemplateOverride, at
 least to override the createDefault attribute. So I tried that, and it's
 still not working, but maybe I'm not overriding properly. I tried it two
 different ways, overriding the generic driver template and overriding a
 template declared with a driverExtension in my plugin.xml (copied and
 adapted from the enablement plug-in). In each case I used the ID of the
 base template (the one being overriden) for the value of the
 driverTemplateID attribute of the  Connection element in the
 ProfileManagerInitializationProvider extension. I assume this is correct
 since the ID for the driverTemplateOverride element is an optional
 attribute.
 I've pasted below two versions of plugin.xml, showing both approaches
 described above. In each case an NPE is thrown because the driver template
 is null when retrieved by templateID. I also pasted the stack trace below
 (the first lines of it, down to invocation by the Workbench.
 plugin.xml overriding the generic template:
 <plugin>
 <extension
 <connection
 connectionProfileID="some.id"
 connectionProfileName="MySQL2"
 driverDefinitionName="MySQL JDBC Driver"
 driverTemplateID="org.eclipse.datatools.connectivity.db.genericDriverTemplate "
 <property
 </property>
 <property
 </property>
 <property
 value="root">
 </property>
 <property
 </property>
 <property
 id="org.eclipse.datatools.connectivity.drivers.defnType"
 value=" org.eclipse.datatools.connectivity.db.generic.genericDriverT emplate ">
 </property>
 <property
 id="org.eclipse.datatools.connectivity.db.driverClass"
 value="com.mysql.jdbc.Driver">
 </property>
 <property
 id="org.eclipse.datatools.connectivity.db.vendor"
 value="MySql">
 </property>
 <property
 id="org.eclipse.datatools.connectivity.db.version"
 value="5.1">
 </property>
 </connection>
 </extension>
 <extension
 createDefault="true"
 targetId="org.eclipse.datatools.connectivity.db.genericDriverTemplate ">
 <propertyOverrides>
 <propertyOverride
 targetId="org.eclipse.datatools.connectivity.db.databaseName "/>
 <propertyOverride
 targetId="org.eclipse.datatools.connectivity.db.driverClass "/>
 propertyOverride
 targetId="org.eclipse.datatools.connectivity.db.URL"/>
 </extension>
 </plugin>
 plugin.xml overriding a declared template:
 <plugin>
 <extension
 <connection
 driverTemplateID="org.eclipse.datatools.enablement.mysql.5_1.driverTemplate2 "
 <property
 </property>
 <property
 </property>
 <property
 value="root">
 </property>
 <property
 </property>
 <property
 </property>
 <property
 </property>
 <property
 value="MySql">
 </property>
 <property
 value="5.1">
 </property>
 </connection>
 </extension>
 <extension
 <driverTemplate
 emptyJarListIsOK="false"
 id="org.eclipse.datatools.enablement.mysql.5_1.driverTemplate2 "
 name="MySQL JDBC Driver Template"
 parentCategory="org.eclipse.datatools.enablement.mysql.5_1.driverCategory ">
 <properties>
 <property
 generated="false"
 name="Driver Class"
 required="true"
 visible="true"/>
 <property
 generated="false"
 name="Vendor"
 value="MySql"
 required="true"
 visible="false"/>
 <property
 generated="false"
 name="Version"
 value="5.1"
 required="true"
 visible="false"/>
 <property
 generated="false"
 required="true"
 visible="true"/>
 <property
 generated="false"
 name="Connection URL"
 required="true"
 visible="true"/>
 <property
 generated="false"
 name="User ID"
 value="root"
 required="false"
 visible="true"/>
 <property
 generated="false"
 name="Password"
 required="false"
 visible="true"/>
 </properties>
 </driverTemplate>
 </extension>
 </plugin>
 Stack trace:
 at
 org.eclipse.datatools.connectivity.drivers.DriverManager.get DriverInstancesFromMapForTemplateID(DriverManager.java:150)
 at
 org.eclipse.datatools.connectivity.drivers.DriverManager.get DriverInstancesByTemplate(DriverManager.java:189)
 at
 org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getDriverInstance(InternalProfileManager.java:1328)
 at
 org.eclipse.datatools.connectivity.internal.InternalProfileM anager.enableLocalDatabase(InternalProfileManager.java:1252)
 at
 org.eclipse.datatools.connectivity.internal.InternalProfileM anager.loadLocalRegisteredDatabases(InternalProfileManager.j ava:1211)
 at
 org.eclipse.datatools.connectivity.internal.InternalProfileM anager.loadProfiles(InternalProfileManager.java:929)
 at
 org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfiles(InternalProfileManager.java:140)
 at
 org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfileByName(InternalProfileManager.java:215)
 at
 org.eclipse.datatools.connectivity.ProfileManager.getProfile ByName(ProfileManager.java:96)
 at
 com.tasc.swb.datatools.connectivity.testclient.views.TestCli entView.testJDBCConnection(TestClientView.java:96)
 at
 com.tasc.swb.datatools.connectivity.testclient.views.TestCli entView.access$0(TestClientView.java:86)
 at
 com.tasc.swb.datatools.connectivity.testclient.views.TestCli entView$ViewContentProvider.getElements(TestClientView.java: 43)
 at
 org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:937)
 at
 org.eclipse.jface.viewers.ColumnViewer.getRawChildren(Column Viewer.java:703)
 at
 org.eclipse.jface.viewers.AbstractTableViewer.getRawChildren (AbstractTableViewer.java:1071)
 at
 org.eclipse.jface.viewers.StructuredViewer.getFilteredChildr en(StructuredViewer.java:871)
 at
 org.eclipse.jface.viewers.StructuredViewer.getSortedChildren (StructuredViewer.java:994)
 at
 org.eclipse.jface.viewers.AbstractTableViewer.internalRefres hAll(AbstractTableViewer.java:685)
 at
 org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:633)
 at
 org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:620)
 at
 org.eclipse.jface.viewers.AbstractTableViewer$2.run(Abstract TableViewer.java:576)
 at
 org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1365)
 at
 org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1328)
 at
 org.eclipse.jface.viewers.AbstractTableViewer.inputChanged(A bstractTableViewer.java:574)
 at
 org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
 at
 org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1603)
 at
 com.tasc.swb.datatools.connectivity.testclient.views.TestCli entView.createPartControl(TestClientView.java:79)
 at
 org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:371)
 at
 org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:230)
 at
 org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
 at  org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:2127)
 at
 org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:1062)
 at  org.eclipse.ui.internal.WorkbenchPage$19.run(WorkbenchPage.j ava:3773)
| Re: Still can't create a connection [message #54783 is a reply to message #54729] | Wed, 08 April 2009 17:34   |  |
| Eclipse User  |  |  |  |  | I'm sorry this thread is running so long, but I think I'm almost there. My connection is working, but there are two issues remaining.
 1. I found a workaround for the classpath problem, which is not acceptable
 but confirms that the problem is in the way I'm setting the jarList
 attribute. I entered the absolute file path on my development system as
 the value for jarList, and it worked. So the value I used originally for
 jarList (com.mysql.jdbc/mysql-connector-java-5.1.7-bin.jar) doesn't
 resolve to path of the jar file in plugin com.mysql.jdbc, which is what I
 need. Hopefully this is a basic thing I'm missing and someone can
 enlighten me.
 2. For some reason the password property is not being set on the profile.
 I can get around this by specifying it as part of the URL, but I'd rather
 not do that. After stepping through with the debugger, it looks like DTP
 is dropping the password property. I print out the values of all the
 properties set in the ProfileManagerInitializationProvider extension as
 passed to my implementation of the class referenced by the
 connectionInitializer attribute. AT that point, all the properties are
 set, including password. Then using the debugger I looked at
 org.eclipse.datatools.connectivity.internal.ManagedConnectio n during
 runtime.
 Just before createConnection() returns (line 178), I inspect the profile
 (mProfile is the variable name). By traversing the heirarchical set of
 property entries inside mPropertiesMap, I find all the properties set
 except for password. There is no entry for password, not an entry with a
 null value. And downstream when the connection is created from the
 profile, it is made with no password, resulting in a SQLException.
 I'm setting the password property just the same as I set the user
 property, so I'm not sure what's going on. Is there a reason the password
 property would not be passed on? Or is this a bug in the DTP code?
 Repeating from my previous post, here's how I set the password and user
 properties in plugin.xml:
 <connection
 connectionProfileID="org.eclipse.datatools.enablement.mysql.connectionProfile "
 connectionProfileName="MySqlJdbcConnectionProfile"
 jarList="C:\Documents and Settings\leonema\My
 Documents\Eclipse NG\com.mysql.jdbc\mysql-connector-java-5.1.7-bin.jar">
 jarList="Plugin:com.mysql.jdbc/mysql-connector-java-5.1.7-bin.jar "> -->
 <property
 </property>
 <property
 value="jdbc:mysql://localhost:3306">
 </property>
 <property
 value="root">
 </property>
 <property
 </property>
| Re: Still can't create a connection [message #54944 is a reply to message #54783] | Thu, 09 April 2009 10:05   |  |
 Hey Mark...
 No worries. I'm just glad we're making progress. :)
 For 1, can you try simply putting the plug-in id in square brackets?
 [com.mysql.jdbc]. I think that's the trick there. So it would be
 "[com.mysql.jdbc]/mysql-connector-java-5.1.7-bin.jar".
 For 2, there is a "save password" property you would need to set on the
 profile properties when you create it initially... Let me find that...
 IJDBCConnectionProfileConstants.SAVE_PASSWORD_PROP_ID
 Set that to true and it should persist the password for you. It's just
 another property to set on the properties set for the connection profile. We
 default to not saving it because of the security concerns, but the profile
 store is encrypted so you should be ok.
 Let me know if that helps. :)
 --Fitz
 news:7e9d71d9f5fa97902aa8f1ca6a680311$1@www.eclipse.org...
 > enlighten me.
 > runtime.
 > <connection
 >            jarList="C:\Documents and Settings\leonema\My Documents\Eclipse
 >         <property
 >         </property>
 >         <property
 >         </property>
 >         <property
 >               value="root">
 >         </property>
 >         <property
 >         </property>
| Re: Still can't create a connection [message #55049 is a reply to message #55022] | Thu, 09 April 2009 20:50   |  |
 Thanks for trying on your end. Sorry I didn't get back to you earlier, as
 I was doing some re-factoring that consumed me for most of the day.
 I think it may be that the format you gave me for jarList works in the
 drivertemplate but not in the ProfileManagerInitializationProvider. Below
 is my plugin.xml. When I run it as-is, I get a ClasSNotFoundException
 looking for teh driver class. When I use the jarList assignment that is
 commented out, it works fine. I never tried this with DriverExtension,
 only with ProfileManagerInitializationProvider.
 I'm getting around this OK because of the way I've re-factored, in which
 I;ve combined the XML and Java versions I did over the last several days.
 Now I listen for DTP to send me the ConfigurationElement, using the class
 specified as the connectionInitializer attribute. That class just calls a
 configurator that grabs the driver properties out of the
 ConfigurationElement and defiens a driver with them programmatically the
 way you showed me last week. Then the configurator grabs profile
 properties from a file where they're set by an admin user, and it creates
 the profile programmatically, again with the code you gave me, and also
 assigns the driver name and driver ID that came out of the
 COnfigurationElement.
 This way I have my driver properties hard-coded in the XML, and the
 profile properties are set via a properties file. Since I'm doing it this
 way, I go ahead and set the jarFile property by using Java to get the
 plugin-relative location of the jar file. This works, vice the XML version
 which causes a ClassNotFoundException. The Java code I use is
 final File file = new
 File(FileLocator.getBundleFile(Platform.getBundle("com.mysql.jdbc ")),
 "mysql-connector-java-5.1.7-bin.jar");
 I also set the password persistence property on the profile per your
 earlier message, and now the connection works fine. It would be nice to
 solve the jarList issue since it's supposed to work, but it's nto gating
 me.
 The last reamaining question I have is how the Data Source Explorer could
 be used in conjunction with the profile I set up as described above. I see
 the profile, but the only properties I can edit are name and description,
 not password or user ID, etc. Also after I launch the DSE view, all my
 connections fail until I restart the app. I don't have to do anything in
 the DSE; just by showing the view I kill the ability to connect on the
 profile I defined.
 -Mark
| Re: Still can't create a connection [message #55102 is a reply to message #55049] | Fri, 10 April 2009 09:16   |  |
 Very odd. I know it works on the override provider side, so I don't know
 what's going on.
 If you're using the profile provider ID that goes with MySQL for your
 profile, you should be able to edit the profile in the DSE.
 But I'm not all that familiar with what the profile manager initialization
 code is doing under the covers. Let me see if one of the other DTP folks can
 help you out with that part.
 --Fitz
 news:f5a999ec0feda8c269138991584f9ec2$1@www.eclipse.org...
 > Fitz,
 > me.
 > profile I defined.
 > -Mark
| Re: Still can't create a connection [message #55182 is a reply to message #55156] | Mon, 13 April 2009 10:23   |  |
 I worked on this over the weekend, and it's working well now with just two
 DSE issues that seem to be unrelated to what I've coded; hopefully just a
 config issue on my end.
 First, a quick summary of what changed over the weekend.
 1. Issue with the DSE and profile connection not working together is
 fixed; it was a bug with my test client.
 2. I re-factored once more. With my team's decision last week to decouple
 the driver and profile properties, ProfileManagerInitializationProvider
 extension is no longer needed. Now I have no extensions declared for the
 plug-in that provides connectivity. I programmatically define the driver
 and  setup the profile, with the code you showed me earlier in the thread,
 getting the profile property settings from a file in the config directory.
 To get around the startup timing issue when we used earlyStartup with this
 approach, I activate my connectivity plug-in from the RCP app as the
 platform is coming up.
 Now everything works as desired except the following with the DSE.
 1. As mentioned previously, when I edit the connection properties from the
 DSE entry for the profile, I only see the name and description, not the
 properties I set on the profile programmatically.
 2. I don't see child entries for the profile that enable me to view and
 edit the tables.
 This is referring to when I launch an eclipse app with my plug-ins. When I
 look at the DSE in the IDE, I see an entry below the connection that
 enables me to view and edit the tables, schemas, etc. I'd like to have
 this same capability in the DSE when I launch my app.
 I thought I might be missing a DTP plug-in in my target environment, but I
 added every one that seemed even remotely applicable, and I still don't
 have the missing capability. Can you think of a plug-in or plug-ins I
 should check for? Or perhaps there's another property I need to set on my
 profile?
 Below is the code I'm using to define the driver and configure and create
 the profile. The property values are not evident in the snippet, but you
 can see what properties I'm setting.
 public void provideConnectivity() {
 final Properties profileProps = new ConnectionProfileProperties();//
 defineDriver(driverId, driverName);
 createProfile(driverId, profileProps);
 private void defineDriver(final String driverId, final String driverName) {
 final String profileGenericJDBCDriverTemplateID =
 final IPropertySet propSet = new PropertySetImpl(driverName, driverId);
 final Properties driverProperties = new Properties();
 driverProperties.setProperty(IJDBCDriverDefinitionConstants. DRIVER_CLASS_PROP_ID,
 "com.mysql.jdbc.Driver");
 getJarList());
 "MySql");
 "5.1");
 private void createProfile(final String driverID, final Properties
 profileProps) {
 final String driverURL = "jdbc:mysql://" + profileProps.getProperty(
 ProphetConnectionProfileConstants.PROP_DB_HOST_NAME) + ":"
 profileProps.getProperty(ProphetConnectionProfileConstants.P ROP_DB_PORT) +
 "/testdb";
 connectionProfileName =
 profileProps.getProperty(ProphetConnectionProfileConstants.P ROP_PROFILE_NAME);
 final Properties props = new Properties();
 driverID);
 props.setProperty(IJDBCDriverDefinitionConstants.PASSWORD_PR OP_ID,
 profileProps.getProperty(ProphetConnectionProfileConstants.P ROP_PASSWORD));
 props.setProperty(IJDBCDriverDefinitionConstants.USERNAME_PR OP_ID,
 profileProps.getProperty(ProphetConnectionProfileConstants.P ROP_USER_ID));
 props.setProperty(IJDBCDriverDefinitionConstants.URL_PROP_ID , driverURL);
 //DTP will not persist the password if this property is not set
 props.setProperty(IJDBCConnectionProfileConstants.SAVE_PASSW ORD_PROP_ID,
 "true");
 props.setProperty(IJDBCConnectionProfileConstants.DATABASE_N AME_PROP_ID,
 "testdb");
 props.setProperty(IJDBCDriverDefinitionConstants.DATABASE_VE NDOR_PROP_ID,
 DriverManager.
 getInstance().getDriverInstanceByID(driverID)
 getNamedPropertyByID(IJDBCDriverDefinitionConstants.DATABASE _VENDOR_PROP_ID));
 props.setProperty(IJDBCDriverDefinitionConstants.DATABASE_VE RSION_PROP_ID,
 DriverManager.
 getNamedPropertyByID(IJDBCDriverDefinitionConstants.DATABASE _VERSION_PROP_ID));
 ProfileManager pfm = null;
 try {
 } catch (final Exception e) {
 DatatoolsMySqlConnectivityPlugin.logError("Unable to insantiate the
 Connection Profile Manager", e);
 return;
 if (pfm.getProfileByName(this.connectionProfileName) == null) {
 createNewProfile(props);
 } else {
 modifyProfileProperties(props);
 private void createNewProfile(final Properties props) {
 try {
 return;
 try {
 pfm.createProfile(this.connectionProfileName,
 "Default connection profile for accessing the MySQL database",
 this.providerID, props);
 } catch (final ConnectionProfileException e) {
 DatatoolsMySqlConnectivityPlugin.logError("Unable to create the
 connection profile", e);
| Re: Still can't create a connection [message #55209 is a reply to message #55182] | Mon, 13 April 2009 13:18   |  |
 Hey Mark...
 Glad you're a bit futher along...
 Couple of questions... The driver template ID you're providing in the
 DefineDriver routine... Instead of using
 " org.eclipse.datatools.connectivity.db.generic.genericDriverT emplate ", can
 you try using "org.eclipse.datatools.enablement.mysql.5_1.driverTemplate".
 I also don't think you need to set these properties for the driver:
 > "MySql");
 > "5.1");
 When you say that you can't edit anything more than the name/description,
 are you seeing a property page called something like "JDBC Connection
 Properties"? There should be more than one property page associated with
 your profile.
 If we can get the first part resolved, the catalog loader should be
 satisfied as well, which should satisify your tree population issues.
 --Fitz
 news:2b36aedb74d3a857293328f26715a1ba$1@www.eclipse.org...
 > Fitz,
 > edit the tables.
 > profile?
 > getJarList());
 > "MySql");
 > "5.1");
 > profileProps) {
 > "/testdb";
 > driverID);
 > "true");
 > "testdb");
 > DriverManager.
 > DriverManager.
 > try {
 > return;
 > } else {
 > try {
 > return;
 > try {
 > pfm.createProfile(this.connectionProfileName, "Default connection profile
 > for accessing the MySQL database", this.providerID, props);
 > DatatoolsMySqlConnectivityPlugin.logError("Unable to create the connection
 > profile", e);
| Re: Still can't create a connection [message #55234 is a reply to message #55209] | Mon, 13 April 2009 14:29   |  |
| Eclipse User  |  |  |  |  | Thanks Fitz.
 The value of driverID was already set to
 org.eclipse.datatools.enablement.mysql.5_1.driverTemplate via an instance
 variable assignment I didn't include in the snippet I posted. But I
 changed the value of property IDriverMgmtConstants.PROP_DEFN_TYPE to be
 the same value as driverID, and I took out the lines that set the values
 of the vendor and version properties. If I don't set PROP_DEFN_TYPE to
 reference the MySQL enablement template, everything works OK, I think, but
 when I look at the driver in the Preference page it doesn't show the
 vendor and version values.
 With the above changes, I still have the two problems I mentioned earlier
 when I launch my eclipse application. When I open the DSE view, I see a
 top level entry "Database Connections" and below that is
 "MySqlJdbcConnectionProfile", the profile that I created programmatically.
 If I right-click and select ping, it works. If I double-click it, it
 connects. But I never see any items below it, for schema, tables, etc.
 If I right-click the profile and select Properties, a window comes up that
 is titled "Properties for MySqlJdbcConnectionProfile". It has a tree on
 the left that has top-levle elements "Common" and "Version". If I select
 Common, on the right I have text box fields I can set for Name and
 Description (optional), as well as a check box "Connect every time the
 workbench is started." I'm hoping to see fields for setting the username,
 password, etc. I also don't see any reference to the driver in the profile
 properties, which I would think would be there. I don't see any other
 property pages or references to such in the window that appears.
 When I display the DSE in the IDE, of course I don't see any profiles
 until I create them via the DTP GUI. From the context menu in the DSE, I
 select New, to launch the New Connection Profile wizard. On the second
 wizard page, I specify the driver from the drop-down menu, and configure
 the driver properties. Then when I complete the wizard, in the DSE under
 the entry for the profile, I see an entry for the database instance, which
 I can then expand to see "Schemas" and "Tables", etc.
 I thought maybe the problem only occurs for profiles created
 programmatically. So I tried in the DSE for my launched eclipse
 application to create a driver and profile manually via the DSE GUI. That
 one behaved the same as the one created programmtically. I can ping it and
 connect to it, but I don't see the child elements for it.
 One possible hint for the cause of the difference is that my Preferences
 pages are different between the IDE and the launched application. For the
 IDE, I have a perference page Data Management/Connectivity/Database
 Conenction Profile. Ut has two checkboxes "Show schema" and "Show database
 object owner". I don;t have this preference page on the launched
 application.  I have the page Data Management/Connectivity, but it's only
 child page is Driver Definitions. That's what made me think I may be
 missing a plug-in for the launched application.
| Re: Still can't create a connection [message #55314 is a reply to message #55288] | Tue, 14 April 2009 11:38   |  |
 > And on the Driver Properties page, you can't edit the properties for the
 > profile?
 > --Fitz
 Actually, I can edit the properties there. I was assuming that I'd be
 modifying the properties bound to the driver rather than those bound to
 the profile in that case, since the properties page is named Driver
 Properties. It's my understanding that DTP intends to provide a driver
 definition independent of profile definitions, so users can create
 multiple profiles that potentially use the same driver, with the driver
 providing a single physical connection spec and the profiles providing
 different user-oriented connection properties. For our purposes, we'd like
 to have one fixed driver definition (class name and jar file) and
 (potentially) different connection profiles with distinct user IDs,
 passwords, databases, or URLs.
 Am I correct that I'd be modifying the driver properties vice the profile
 properties on the Driver properties page that comes up when viewing a
 profile? Either way, this is not too big of a deal. I'm more concerned
 with having the ability to view and edit tables through the DSE. That
 would be a very convenient development support capability.
| Re: Still can't create a connection [message #55341 is a reply to message #55314] | Tue, 14 April 2009 19:10   |  |
 Actually even though it's labeled "Driver Properties" -- it's actually the
 properties for the profile. It's very poorly labeled. If you feel so
 inclined, you can create a bug in Bugzilla for it so we change the label.
 But even so, you're still not able to connect and drill into the profile to
 see the tables?
 --Fitz
 news:2160e030dcac13e21edfeda9bea74219$1@www.eclipse.org...
 >> profile?
 >> --Fitz
| Re: Still can't create a connection [message #55423 is a reply to message #55395] | Wed, 15 April 2009 13:06   |  |
 > What DTP plug-ins do you have in your project so far and I can probably tell
 > you what's missing?
 > --Fitz
 These are the DTP plug-ins I have in my target:
 02/17/2009  10:21 PM            25,804
 org.eclipse.datatools.connectivity.console.profile_1.0.0.v20 0805231345.jar
 02/17/2009  10:21 PM            27,692
 org.eclipse.datatools.connectivity.db.generic.ui_1.0.1.v2008 05152355.jar
 04/10/2009  04:38 PM            13,015
 org.eclipse.datatools.connectivity.db.generic_1.0.1.v2008101 40922.jar
 02/17/2009  10:21 PM             8,695
 org.eclipse.datatools.connectivity.dbdefinition.genericJDBC_ 1.0.1.v200810300511.jar
 02/17/2009  10:21 PM           324,241
 org.eclipse.datatools.connectivity.sqm.core.ui_1.1.3.v200902 070558.jar
 04/10/2009  04:38 PM           309,127
 org.eclipse.datatools.connectivity.sqm.core_1.0.7.v200902180 551.jar
 04/10/2009  04:38 PM            75,769
 org.eclipse.datatools.connectivity.ui.dse_1.1.3.v20081014034 9.jar
 02/17/2009  10:22 PM            70,272
 org.eclipse.datatools.connectivity.ui.templates_1.0.0.v20080 5152355.jar
 04/10/2009  04:38 PM           532,625
 org.eclipse.datatools.connectivity.ui_1.1.3.v200901150027.ja r
 04/10/2009  04:38 PM           230,243
 org.eclipse.datatools.connectivity_1.1.2.v200901090028.jar
 02/17/2009  10:24 PM            18,632
 org.eclipse.datatools.enablement.mysql.dbdefinition_1.0.4.v2 00901090853.jar
 02/17/2009  10:24 PM            11,736
 org.eclipse.datatools.enablement.mysql.ui_1.0.0.v20080515235 5.jar
 02/17/2009  10:24 PM            57,210
 org.eclipse.datatools.enablement.mysql_1.0.2.v200810160130.j ar
 04/10/2009  04:38 PM            13,677
 org.eclipse.datatools.help_1.5.0.v200805152355.jar
 04/10/2009  04:38 PM           161,196
 org.eclipse.datatools.modelbase.dbdefinition_1.0.1.v20090109 0853.jar
 02/17/2009  10:26 PM           274,569
 org.eclipse.datatools.modelbase.sql.edit_1.0.0.v200805152355 .jar
 02/17/2009  10:26 PM           190,244
 org.eclipse.datatools.modelbase.sql.query.edit_1.0.0.v200806 070329.jar
 02/17/2009  10:26 PM           554,526
 org.eclipse.datatools.modelbase.sql.query_1.0.1.v20090124114 5.jar
 02/17/2009  10:27 PM           256,701
 org.eclipse.datatools.modelbase.sql.xml.query_1.0.0.v2008070 80500.jar
 04/10/2009  04:38 PM           429,277
 org.eclipse.datatools.modelbase.sql_1.0.1.v200812031125.jar
 02/17/2009  10:27 PM           125,565
 org.eclipse.datatools.sqltools.common.ui_1.0.0.v200812121740 .jar
 02/17/2009  10:27 PM            62,994
 org.eclipse.datatools.sqltools.data.core_1.0.1.v200902140515 .jar
 02/17/2009  10:27 PM           109,403
 org.eclipse.datatools.sqltools.data.ui_1.1.1.v200901140830.j ar
 02/17/2009  10:27 PM           144,149
 org.eclipse.datatools.sqltools.db.derby_1.0.0.v200805152355. jar
 02/17/2009  10:27 PM           131,176
 org.eclipse.datatools.sqltools.db.generic_1.0.0.v20090203160 0.jar
 02/17/2009  10:27 PM            66,532
 org.eclipse.datatools.sqltools.ddlgen.ui_1.0.0.v200808140615 .jar
 02/17/2009  10:27 PM           116,271
 org.eclipse.datatools.sqltools.debugger.core_1.0.0.v20080814 0615.jar
 02/17/2009  10:27 PM           149,776
 org.eclipse.datatools.sqltools.doc.user_1.6.1.v2008082813371 3.jar
 02/17/2009  10:28 PM           172,920
 org.eclipse.datatools.sqltools.editor.core_1.0.0.v2009020316 00.jar
 02/17/2009  10:28 PM           137,865
 org.eclipse.datatools.sqltools.parsers.sql.lexer_1.0.1.v2008 11081015.jar
 02/17/2009  10:28 PM           299,987
 org.eclipse.datatools.sqltools.parsers.sql.query_1.0.1.v2008 10291500.jar
 02/17/2009  10:28 PM           274,409
 org.eclipse.datatools.sqltools.parsers.sql.xml.query_1.0.0.v 200808140615.jar
 02/17/2009  10:28 PM            42,531
 org.eclipse.datatools.sqltools.parsers.sql_1.0.1.v2008081406 15.jar
 02/17/2009  10:28 PM           123,971
 org.eclipse.datatools.sqltools.plan_1.0.0.v200812121520.jar
 02/17/2009  10:28 PM           374,293
 org.eclipse.datatools.sqltools.result_1.0.0.v200902120900.ja r
 02/17/2009  10:28 PM           185,043
 org.eclipse.datatools.sqltools.routineeditor_1.0.0.v20080721 1830.jar
 02/17/2009  10:28 PM         1,029,608
 org.eclipse.datatools.sqltools.sqlbuilder_1.0.0.v20090128065 0.jar
 02/17/2009  10:29 PM           451,600
 org.eclipse.datatools.sqltools.sqleditor_1.0.0.v200901220945 .jar
 02/17/2009  10:29 PM           123,355
 org.eclipse.datatools.sqltools.sqlscrapbook_1.0.0.v200901151 810.jar
 02/17/2009  10:28 PM            89,401
 org.eclipse.datatools.sqltools.sql_1.0.0.v200902031600.jar
 02/17/2009  10:29 PM            28,366
 org.eclipse.datatools.sqltools.tabledataeditor_1.0.0.v200901 280500.jar
 02/17/2009  10:29 PM            72,146
 org.eclipse.datatools.sqltools.tablewizard_1.0.0.v2008081406 15.jar
| Re: Still can't create a connection [message #55477 is a reply to message #55423] | Wed, 15 April 2009 16:05   |  |
 Based on that list, I don't think you're missing anything.
 And you're getting absolutely nothing in the tree when you connect? No +
 sign to expand or anything?
 --Fitz
 news:c9a1e5c0ee4ac2350bb0f3c21cee032d$1@www.eclipse.org...
 >> tell you what's missing?
 >> --Fitz
| Re: Still can't create a connection [message #55712 is a reply to message #55685] | Fri, 17 April 2009 10:04  |  |
 Hooray! :)
 You bet. I'm glad I could help and it was a relatively minor problem of
 missing bundles in the end. I had a few more options, but they got ugly
 quickly. ;)
 I'm going to take this thread and try and write up some basics on using the
 APIs and the various options available on the Wiki. It was a great exercise
 trying to walk someone else through the process -- thanks for being patient!
 Do let us know if you need anything else and if you find more bugs or
 issues, give us a holler!
 Have a great weekend!
 --Fitz
 news:ac29597ba240eb07094fa7c5dd29cc5a$1@www.eclipse.org...
 >> Can you create a different type of connection profile? Such as for a
 >> Derby database or something?
 > Fitz,
 > Success at last! The Derby suggestion was a good one. I had to add a
 > number of bundles to get the Derby bundles to resolve, and some of those
 > turned out to be the ones needed to make the MySQL profile drill-down
 > work. The missing bundles were:
 > org.eclipse.datatools.connectivity.sqm.server.ui
 > It's interesting that the dependencies were identified when I used Derby,
 > but for MySQL profiles the DSE silently failed to expose the drill-down
 > capability. Perhaps that's something that can be addressed.
 > Once again, I;'m very grateful for the superb help you gave me. You hung
 > in there with me, and we were able to get everything that I needed
 > working.
 > -Mark
| Re: Still can't create a connection [message #594971 is a reply to message #53986] | Thu, 02 April 2009 19:06  |  |
| Eclipse User  |  |  |  |  | What provider ID are you providing the create call? --Fitz
 > is
 > connection?
 > -Mark
| Re: Still can't create a connection [message #594990 is a reply to message #54057] | Thu, 02 April 2009 23:16  |  |
 > --Fitz
 Plugin.xml:
 <category
 name="Database"/>
 <propertyOverrides>
 <propertyOverride
 value="test"
 required="true"
 visible="true"/>
 <propertyOverride
 required="true"
 visible="true"/>
 </extension>
 if (pfm == null){
 else{
 try {
 e2.getMessage());
 driverID);
 try {
 + e1.getMessage());
 } else {
 return profile;
| Re: Still can't create a connection [message #594999 is a reply to message #54108] | Fri, 03 April 2009 00:16  |  |
| Eclipse User  |  |  |  |  | I just realized I didn't include the code that calls the ProfileWrapper class, so you can see the parameters I pass. here it is.
 String driverID =
 "org.eclipse.datatools.enablement.mysql.5_1.driverTemplate";
 String userName = "root";
 String password = "*********";
 ProfileWrapper pw = new ProfileWrapper(
 driverID,
 userName,
 password,
 resList);
 IConnectionProfile profile = pw.getProfile();
 try {
 profile.connect();//NPE occurs here.
| Re: Still can't create a connection [message #595007 is a reply to message #54134] | Fri, 03 April 2009 11:44  |  |
 get farther along.
 and it is thrown by
 at line 139.
 driverID);
| Re: Still can't create a connection [message #595020 is a reply to message #54160] | Fri, 03 April 2009 12:58  |  |
| Eclipse User  |  |  |  |  | Well that's great!
 definition...
 //$NON-NLS-2$
 //$NON-NLS-1$
 driverClass);
 jarList);
 properties...
 driverID);
 --Fitz
 > get farther along.
 > and it is thrown by
 > at line 139.
 > driverID);
| Re: Still can't create a connection [message #595030 is a reply to message #54186] | Fri, 03 April 2009 16:07  |  |
| Eclipse User  |  |  |  |  | Thanks!
 That worked for me. At least I can make queries on the connection and get
 the results back. I'm getting some exceptions however, with the root cause
 apparently that I don't have an entry in the database definition registry.
 I couldn't find any properties to set on the driver or connection profile
 that seem to pertain to this.
 Here's the stack trace
 at java.util.TreeMap.getEntry(TreeMap.java:324)
 at java.util.TreeMap.get(TreeMap.java:255)
 at
 org.eclipse.datatools.connectivity.sqm.internal.core.definit ion.DatabaseDefinitionRegistryImpl.getDefinition(DatabaseDef initionRegistryImpl.java:71)
 at
 org.eclipse.datatools.connectivity.sqm.internal.core.connect ion.ConnectionInfoImpl. <init>(ConnectionInfoImpl.java:629)
 at
 org.eclipse.datatools.connectivity.sqm.internal.core.connect ion.ConnectionInfoImpl. <init>(ConnectionInfoImpl.java:640)
 at
 org.eclipse.datatools.connectivity.sqm.internal.core.connect ion.ConnectionFactory.createConnection(ConnectionFactory.jav a:38)
 at
 org.eclipse.datatools.connectivity.sqm.core.SQMConnectionFac tory.createConnection(SQMConnectionFactory.java:45)
 at
 org.eclipse.datatools.connectivity.sqm.internal.core.connect ion.ConnectionFactory.createConnection(ConnectionFactory.jav a:59)
 at
 org.eclipse.datatools.connectivity.internal.ConnectionFactor yAdapterProvider.createConnection(ConnectionFactoryAdapterPr ovider.java:114)
 at
 org.eclipse.datatools.connectivity.internal.ManagedConnectio n.createConnection(ManagedConnection.java:163)
 at
 org.eclipse.datatools.connectivity.internal.CreateConnection Job.run(CreateConnectionJob.java:56)
| Re: Still can't create a connection [message #595042 is a reply to message #54212] | Fri, 03 April 2009 17:31  |  |
| Eclipse User  |  |  |  |  | Cool. Glad we're getting closer. :)
 I'm guessing it's because you're missing the Vendor and Version properties
 in your connection profile properties...
 After you get your driver definition, try adding these properties to your
 baseProperties.setProperty(IJDBCDriverDefinitionConstants.DA TABASE_VENDOR_PROP_ID,
 DriverManager.getInstance().getDriverInstanceByID(driverID). getNamedPropertyByID(IJDBCDriverDefinitionConstants.DATABASE _VENDOR_PROP_ID));
 baseProperties.setProperty(IJDBCDriverDefinitionConstants.DA TABASE_VERSION_PROP_ID,
 DriverManager.getInstance().getDriverInstanceByID(driverID). getNamedPropertyByID(IJDBCDriverDefinitionConstants.DATABASE _VERSION_PROP_ID));
 The Database definition is retrieved by the vendor/version combo...
 HTH
 --Fitz
 news:734aa0a1e3abfd50d699e087b0851b79$1@www.eclipse.org...
 > Thanks!
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
| Re: Still can't create a connection [message #595049 is a reply to message #54238] | Fri, 03 April 2009 17:54  |  |
| Eclipse User  |  |  |  |  | Yes, closer indeed, but still not at the finish line. Now it's complaining about the catalog. Here's the stack trace.
 -Mark
 at
 org.eclipse.datatools.connectivity.sqm.internal.core.util.Da tabaseProviderHelper.getCatalogDatabase(DatabaseProviderHelp er.java:37)
 at
 org.eclipse.datatools.connectivity.sqm.internal.core.util.Da tabaseProviderHelper.setDatabase(DatabaseProviderHelper.java :47)
 at
 org.eclipse.datatools.connectivity.sqm.internal.core.connect ion.ConnectionInfoImpl.initializeJDBCConnection(ConnectionIn foImpl.java:672)
 at
 org.eclipse.datatools.connectivity.sqm.internal.core.connect ion.ConnectionInfoImpl. <init>(ConnectionInfoImpl.java:644)
 at
 at
 at
 at
 at
 at
| Re: Still can't create a connection [message #595056 is a reply to message #54264] | Fri, 03 April 2009 18:10  |  |
| Eclipse User  |  |  |  |  | Wow I really need to document this stuff on the Wiki...
 That's an interesting bug. Basically the underlying code is looking for a
 "org.eclipse.datatools.connectivity.sqm.core.catalog" extension with the
 5.1.7 version I think you're providing as the version # for the profile.
 The org.eclipse.datatools.enablement.mysql plug-in defines a catalog
 element:
 <extension
 point="org.eclipse.datatools.connectivity.sqm.core.catalog" >
 <catalog
 product="MySql"
 provider=" org.eclipse.datatools.enablement.mysql.catalog.MySqlCatalogP rovider "
 version="5.1">
 </catalog>
 </extension>
 If you're changing the driver/profile version from 5.1 to 5.1.7, you're
 going to have to copy and change a couple of extensions... And I'm not sure
 you can actually do it for the dbdefinition plug-in simply because it's
 looking for the dbdefinition IN that plug-in, which will make it difficult
 to override outside.
 I'm guessing that if you change your version back to 5.1 you won't run into
 an issue.
 Can you let me know?
 --Fitz
 news:7570df0c4625a511d2831067c0810323$1@www.eclipse.org...
 > -Mark
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
| Re: Still can't create a connection [message #595065 is a reply to message #54290] | Fri, 03 April 2009 18:18  |  |
 way or the other.
 "MySQL");
 "MySQL");
 "5.1");
 "5.1");
 which one to use.
 providerID, props);
 -Mark
| Re: Still can't create a connection [message #595079 is a reply to message #54343] | Fri, 03 April 2009 18:45  |  |
 that plug-in.
 The example uses
 -Mark
| Re: Still can't create a connection [message #595088 is a reply to message #54343] | Fri, 03 April 2009 18:45  |  |
| Eclipse User  |  |  |  |  | Can you trace into that org.eclipse.datatools.connectivity.sqm.internal.core.util.Da tabaseProviderHelper.getCatalogDatabase(DatabaseProviderHelp er.java:37)
 call?
 I'm just wondering why it's not finding it based on the vendor/version.
 Sorry I can't be more help today, I have to head off to soccer for my
 youngest. I'll try to help more on Monday.
 --Fitz
 news:d35cb22fa146a1a829a16437cdc4b3f8$1@www.eclipse.org...
 > Just to clarify, I set those properties for vendor name and version again
 > after I added the statements for setting them on the profile properties,
 > and i still get the exception about the catalog.
| Re: Still can't create a connection [message #595102 is a reply to message #54397] | Mon, 06 April 2009 08:57  |  |
| Eclipse User  |  |  |  |  | Brian Fitzpatrick wrote: > Can you trace into that
 > call?
 Fitz,
 Looks like we posted at the same time. I managed to mis-spell MySQL,
 i.e. I had the wrong capitalization vis a vis that used in the
 enablement plug-in's XML file.
 Thanks again for all your help Friday. I do have one additional question
 in my previous post, regarding how I can make this work via plug-in XML
 declarations exclusively vice Java code that runs via early startup.
 -Mark
| Re: Still can't create a connection [message #595111 is a reply to message #54370] | Mon, 06 April 2009 09:25  |  |
| Eclipse User  |  |  |  |  | Hey Mark!
 --Fitz
 > that plug-in.
 > The example uses
 > again.
 > -Mark
| Re: Still can't create a connection [message #595120 is a reply to message #54478] | Mon, 06 April 2009 16:38  |  |
 -Mark
| Re: Still can't create a connection [message #595131 is a reply to message #54505] | Mon, 06 April 2009 16:57  |  |
| Eclipse User  |  |  |  |  | There is a way to do this, but I've not tried it...
 You can use the
 out.
 --Fitz
 > Fitz,
 > -Mark
| Re: Still can't create a connection [message #595139 is a reply to message #54533] | Tue, 07 April 2009 10:34  |  |
 ID.
 -Mark
 My plugin.xml:
 <plugin>
 <extension
 <connection
 <property
 </property>
 <property
 </property>
 <property
 value="root">
 </property>
 <property
 </property>
 </connection>
 </extension>
 </plugin>
| Re: Still can't create a connection [message #595161 is a reply to message #54569] | Tue, 07 April 2009 18:57  |  |
| Eclipse User  |  |  |  |  | In your driver template override, can you set createDefault = true and see if that fixes the problem?
 --Fitz
 > ID.
 > -Mark
 > My plugin.xml:
 > <plugin>
 >   <extension
 >      <connection
 >         <property
 >         </property>
 >         <property
 >         </property>
 >         <property
 >               value="root">
 >         </property>
 >         <property
 >         </property>
 >      </connection>
 >   </extension>
 > </plugin>
| Re: Still can't create a connection [message #595182 is a reply to message #54650] | Wed, 08 April 2009 11:12  |  |
 attribute.
 <plugin>
 <extension
 <connection
 <property
 </property>
 <property
 </property>
 <property
 value="root">
 </property>
 <property
 </property>
 <property
 </property>
 <property
 </property>
 <property
 value="MySql">
 </property>
 <property
 value="5.1">
 </property>
 </connection>
 </extension>
 <extension
 <propertyOverrides>
 <propertyOverride
 <propertyOverride
 propertyOverride
 </extension>
 </plugin>
 <plugin>
 <extension
 <connection
 <property
 </property>
 <property
 </property>
 <property
 value="root">
 </property>
 <property
 </property>
 <property
 </property>
 <property
 </property>
 <property
 value="MySql">
 </property>
 <property
 value="5.1">
 </property>
 </connection>
 </extension>
 <extension
 <driverTemplate
 <properties>
 <property
 generated="false"
 name="Driver Class"
 required="true"
 visible="true"/>
 <property
 generated="false"
 name="Vendor"
 value="MySql"
 required="true"
 visible="false"/>
 <property
 generated="false"
 name="Version"
 value="5.1"
 required="true"
 visible="false"/>
 <property
 generated="false"
 required="true"
 visible="true"/>
 <property
 generated="false"
 required="true"
 visible="true"/>
 <property
 generated="false"
 name="User ID"
 value="root"
 required="false"
 visible="true"/>
 <property
 generated="false"
 name="Password"
 required="false"
 visible="true"/>
 </properties>
 </driverTemplate>
 </extension>
 </plugin>
 Stack trace:
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
 at
| Re: Still can't create a connection [message #595192 is a reply to message #54702] | Wed, 08 April 2009 13:12  |  |
| Eclipse User  |  |  |  |  | I found the problem with the driver template. Stepping though with teh debugger I saw that the NPE was actually occurring when DTP tried to load
 a template using a key for a template that I defined previously for the
 earlyStartup version of the plug-in. A co-worker then told me about the
 need to clear my workspace in my run configuration, which I wasn't clued
 into. Sorry about that, as I'm pretty new to eclipse plug-in development.
 So I'm going to say this was a hardware error: a loose nut on the keyboard.
 I also found that I need to have profile id and name to match an existing
 declared profile (I used the one defined in the enablement plug-in),
 otherwise the catyegory is unknown and it blows up when trying to
 establish a connection. I pasted my plugin.xml below.
 However... I still have a problem. I'm getting a ClassNotFoundException of
 rhte driver class, com.mysql.jdbc.Driver. I added a dependency to a
 plug-in that wraps the COnnector/J jar file and exports package
 com.mysql.jdbc. But I think that's not what it's using to resolve the
 classpath, right? I believe that's what the jarList attribute is for.
 I'm using com.mysql.jdbc/mysql-connector-java-5.1.7-bin.jar because
 com.mysql.jdbc is the name of the plug-in, and the jar file is in the root
 directory of the plug-in. I also tried a backslash instead of the forward
 slash. Any other ideas for specifying the jarList attribute?
 Do you agree this is probably where my problem is?
 My current plugin.xml
 <plugin>
 <extension
 <connection
 connectionProfileName="MySQL"
 <property
 </property>
 <property
 </property>
 <property
 value="root">
 </property>
 <property
 </property>
 <property
 </property>
 <property
 </property>
 <property
 value="MySql">
 </property>
 <property
 value="5.1">
 </property>
 </connection>
 </extension>
 </plugin>
| Re: Still can't create a connection [message #595205 is a reply to message #54729] | Wed, 08 April 2009 17:08  |  |
| Eclipse User  |  |  |  |  | Hey Mark...
 I think to be a programmer you have to be a little nuts anyway. :) So no
 worries there.
 As for the other bit, I'm going to take a look at this tomorrow to see if I
 can figure out what's going on by recreating some of what you're doing here.
 There has to be a reason that the createDefault isn't triggering a creation
 of the driver when it ought to.
 Unfortunately I'm knee-deep in another issue today. So I apologize for
 pushing you off another day, but I hope you'll understand.
 I'll get back to this first thing tomorrow.
 --Fitz
 "Mark Leone" <midnightjava@verizon.net> wrote in message
 news:ef84239000030b68d75bb07dc86349b8$1@www.eclipse.org...
 >debugger I saw that the NPE was actually occurring when DTP tried to load a
 > <plugin>
 >   <extension
 >      <connection
 >         <property
 >         </property>
 >         <property
 >         </property>
 >         <property
 >               value="root">
 >         </property>
 >         <property
 >         </property>
 >         <property
 >         </property>
 >         <property
 >         </property>
 >         <property
 >               value="MySql">
 >         </property>
 >         <property
 >               value="5.1">
 >         </property>
 >      </connection>
 >   </extension>
 >   </plugin>
| Re: Still can't create a connection [message #595219 is a reply to message #54729] | Wed, 08 April 2009 17:34  |  |
 enlighten me.
 runtime.
 <connection
 <property
 </property>
 <property
 </property>
 <property
 value="root">
 </property>
 <property
 </property>
| Re: Still can't create a connection [message #595236 is a reply to message #54756] | Wed, 08 April 2009 17:40  |  |
 No worries at all. You've been super with all the help you've given. Once
 again our messages crossed in the mail, so please look at my post just
 before this one. There's no longer an issue with creating the driver, and
 I have it working with two workarounds that I'd like to not have to use.
 One is probably a simple matter that someone can clear up, and the other
 seems to be a bit thornier, based on running through some DTP code with
 the debugger. Have a great evening.
 -Mark
| Re: Still can't create a connection [message #595284 is a reply to message #54783] | Thu, 09 April 2009 10:05  |  |
 --Fitz
 > enlighten me.
 > runtime.
 > <connection
 >         <property
 >         </property>
 >         <property
 >         </property>
 >         <property
 >               value="root">
 >         </property>
 >         <property
 >         </property>
| Re: Still can't create a connection [message #595294 is a reply to message #54944] | Thu, 09 April 2009 11:18  |  |
| Eclipse User  |  |  |  |  | Thanks, Fitz. I'll give those both a try. I have one quick question about #2 however:
 When you say to set the property
 It looks like that's a property I should use in the Java code. Is there an
 equivalent property I can set in the XML via the
 ProfileManagerInitializationProvider extension?
| Re: Still can't create a connection [message #595299 is a reply to message #54944] | Thu, 09 April 2009 11:28  |  |
 I tried
 jarList="[com.mysql.jdbc]/mysql-connector-java-5.1.7-bin.jar "
 and I'm still getting ClassNotFoundException for the driver class. If I
 set jarList tot he absolute path of the jar file, it works fine. I also
 tried a backslash after the plugin designator, with the same result. Do
 you have any other ideas, or how I can investigate the class loading
 problem?
 FWIW here's the stack trace:
 java.lang.ClassNotFoundException: com.mysql.jdbc.Driver
 at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
 at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
 at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
 at  java.net.FactoryURLClassLoader.loadClass(URLClassLoader.java :592)
 at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
 at
 org.eclipse.datatools.connectivity.drivers.jdbc.JDBCConnecti on.createConnection(JDBCConnection.java:88)
 at
 org.eclipse.datatools.connectivity.DriverConnectionBase.inte rnalCreateConnection(DriverConnectionBase.java:104)
 at
 org.eclipse.datatools.connectivity.DriverConnectionBase.open (DriverConnectionBase.java:53)
 at
 org.eclipse.datatools.enablement.internal.mysql.connection.J DBCMySQLConnectionFactory.createConnection(JDBCMySQLConnecti onFactory.java:28)
 at
 org.eclipse.datatools.connectivity.internal.ConnectionFactor yProvider.createConnection(ConnectionFactoryProvider.java:83 )
 at
 org.eclipse.datatools.connectivity.internal.ConnectionProfil e.createConnection(ConnectionProfile.java:355)
 at
 org.eclipse.datatools.connectivity.internal.ManagedConnectio n.createConnection(ManagedConnection.java:166)
 at
| Re: Still can't create a connection [message #595310 is a reply to message #54995] | Thu, 09 April 2009 15:42  |  |
| Eclipse User  |  |  |  |  | Ok. I'm close to having this working locally.
 Can you paste in the (I'm guessing minimal) code for your initializer class?
 I'm just trying to get as close to what you're doing as I can. I was able to
 create a default driver definition with this:
 <extension
 point="org.eclipse.datatools.connectivity.driverExtension">
 <driverTemplateOverride
 jarList="[com.mysql.jdbc]/mysql-connector-java-5.1.5-bin.jar "
 priority="4"
 targetId="org.eclipse.datatools.enablement.mysql.5_1.driverTemplate ">
 </driverTemplateOverride>
 </extension>
 So now I'm just trying to figure out the initialization part.
 --Fitz
 news:44a7a5cb5c0662470861917ffb79ca08$1@www.eclipse.org...
 > Fitz,
 > I tried
 > problem?
 > at java.security.AccessController.doPrivileged(Native Method)
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
| Re: Still can't create a connection [message #595320 is a reply to message #55022] | Thu, 09 April 2009 20:50  |  |
 me.
 profile I defined.
 -Mark
| Re: Still can't create a connection [message #595331 is a reply to message #55049] | Thu, 09 April 2009 20:51  |  |
| Eclipse User  |  |  |  |  | Forgot to attach plugin.xml
 plugin>
 <extension
 <connection
 connectionInitializer=" com.tasc.swb.datatools.connectivity.mysql.ConfigurationEleme ntInitializer "
 driverDefinitionName="Prophet MySQL JDBC Driver"
 jarList="[com.mysql.jdbc]/mysql-connector-java-5.1.7-bin.jar ">
 <!-- jarList="C:\Documents and Settings\leonema\My
 Documents\Eclipse NG\com.mysql.jdbc\mysql-connector-java-5.1.7-bin.jar" -->
 <property
 </property>
 <property
 value="MySql">
 </property>
 <property
 value="5.1">
 </property>
 </connection>
 </extension>
 </plugin>
| Re: Still can't create a connection [message #595345 is a reply to message #55049] | Fri, 10 April 2009 09:16  |  |
| Eclipse User  |  |  |  |  | Very odd. I know it works on the override provider side, so I don't know what's going on.
 --Fitz
 > Fitz,
 > me.
 > profile I defined.
 > -Mark
| Re: Still can't create a connection [message #595352 is a reply to message #55102] | Fri, 10 April 2009 10:45  |  |
| Eclipse User  |  |  |  |  | Fitz, thanks for passing on the question about DSE interaction.
 Can you help me verify I'm using the right provider ID? The only thing I
 found that enables the profile to provide a working connection is
 I got this from the MySQL enablement plugin.xml, as the id of the declared
 connectionProfle. I pass it as the providerID parameter when I call
 ProfileManager.createProfile(). Can you point me to somewhere else for the
 provider ID value if this isn't correct?
 Thanks.
 -Mark
| Re: Still can't create a connection [message #595360 is a reply to message #55129] | Fri, 10 April 2009 11:51  |  |
| Eclipse User  |  |  |  |  | That provider ID should be correct if you got it from the connection profile extension. So that's probably not it.
 Not sure what the deal is. I've asked Linda to chime in to see if she can
 figure out what's going on.
 --Fitz
 news:94ed6745c1da894f26309770a32e742c$1@www.eclipse.org...
 > Thanks.
 > -Mark
| Re: Still can't create a connection [message #595369 is a reply to message #55156] | Mon, 13 April 2009 10:23  |  |
 edit the tables.
 profile?
 " org.eclipse.datatools.connectivity.db.generic.genericDriverT emplate ";
 driverProperties.setProperty(IDriverMgmtConstants.PROP_DEFN_ JARLIST,
 getJarList());
 driverProperties.setProperty(IDriverMgmtConstants.PROP_DEFN_ TYPE,
 profileGenericJDBCDriverTemplateID);
 driverProperties.setProperty(IJDBCDriverDefinitionConstants. DATABASE_VENDOR_PROP_ID,
 "MySql");
 driverProperties.setProperty(IJDBCDriverDefinitionConstants. DATABASE_VERSION_PROP_ID,
 "5.1");
 propSet.setBaseProperties(driverProperties);
 DriverManager.getInstance().addDriverInstance(propSet);
 profileProps) {
 "/testdb";
 props.setProperty(ConnectionProfileConstants.PROP_DRIVER_DEF INITION_ID,
 driverID);
 "true");
 "testdb");
 DriverManager.
 DriverManager.
 try {
 pfm = ProfileManager.getInstance();
 return;
 } else {
 try {
 return;
 try {
| Re: Still can't create a connection [message #595384 is a reply to message #55182] | Mon, 13 April 2009 13:18  |  |
 > "MySql");
 > "5.1");
 your profile.
 --Fitz
 > Fitz,
 > edit the tables.
 > profile?
 > getJarList());
 > "MySql");
 > "5.1");
 > profileProps) {
 > "/testdb";
 > driverID);
 > "true");
 > "testdb");
 > DriverManager.
 > DriverManager.
 > try {
 > return;
 > } else {
 > try {
 > return;
 > try {
 > profile", e);
| Re: Still can't create a connection [message #595391 is a reply to message #55209] | Mon, 13 April 2009 14:29  |  |
| Re: Still can't create a connection [message #595401 is a reply to message #55234] | Mon, 13 April 2009 14:36  |  |
| Eclipse User  |  |  |  |  | Correction: I do see a see reference to the driver from the profile properties page. In addition to the Common and Version pages in the tree
 on the left, I also see pages for filters (schema, tables, and stored
 procs) and a page for Driver Properties.
| Re: Still can't create a connection [message #595417 is a reply to message #55261] | Tue, 14 April 2009 09:58  |  |
| Eclipse User  |  |  |  |  | And on the Driver Properties page, you can't edit the properties for the profile?
 --Fitz
 news:9334931d851f5832bf04c37d0974132b$1@www.eclipse.org...
| Re: Still can't create a connection [message #595426 is a reply to message #55288] | Tue, 14 April 2009 11:38  |  |
 > profile?
 > --Fitz
| Re: Still can't create a connection [message #595436 is a reply to message #55314] | Tue, 14 April 2009 19:10  |  |
| Eclipse User  |  |  |  |  | Actually even though it's labeled "Driver Properties" -- it's actually the properties for the profile. It's very poorly labeled. If you feel so
 see the tables?
 --Fitz
 >> profile?
 >> --Fitz
| Re: Still can't create a connection [message #595442 is a reply to message #55341] | Wed, 15 April 2009 09:11  |  |
 > see the tables?
 > --Fitz
 Thanks, it's good to know those are the profile properties. I'll go ahead
 and create a Bugzilla entry about changing the label.
 Yes, the only remaining problem I have with my current DTP-based
 implementation is the inability to drill into my profile via the DSE and
 view or edit tables. I can connect to the profile in the DSE, but I just
 don't see any child entries for the profile.
 I can drill down in the DSE if I just launch the eclipse IDE and display
 the DSE view. But when I launch an eclipse application with the plug-ins
 that I and my team have created, the DSE doesn't have the ability to
 drill-down to tables. That's why I'm thinking I might just be missing the
 DTP plug-in that enables this capability in the DSE, though I've tried
 adding various DTP plug-ins to my workspace and/or target environment.
| Re: Still can't create a connection [message #595450 is a reply to message #55369] | Wed, 15 April 2009 09:20  |  |
| Eclipse User  |  |  |  |  | What DTP plug-ins do you have in your project so far and I can probably tell you what's missing?
 --Fitz
 news:7f35f0f751f03ba21095ae5b11fc27e1$1@www.eclipse.org...
 >> to see the tables?
 >> --Fitz
| Re: Still can't create a connection [message #595458 is a reply to message #55395] | Wed, 15 April 2009 13:06  |  |
 > you what's missing?
 > --Fitz
| Re: Still can't create a connection [message #595474 is a reply to message #55423] | Wed, 15 April 2009 16:05  |  |
| Eclipse User  |  |  |  |  | Based on that list, I don't think you're missing anything.
 --Fitz
 >> --Fitz
| Re: Still can't create a connection [message #595482 is a reply to message #55477] | Wed, 15 April 2009 16:36  |  |
 Yes, that's correct, absolutely nothing. Since it works in the IDE, I know
 what I'm supposed to see, and it's definitely not there when running an
 eclipse app. And as I mentioned previously, I tried defining a profile
 manually via the DSE view menu, and that profile also didn't have any
 child elements either.
| Re: Still can't create a connection [message #595491 is a reply to message #55504] | Wed, 15 April 2009 16:55  |  |
| Eclipse User  |  |  |  |  | Can you create a different type of connection profile? Such as for a Derby database or something?
 I'm just trying to determine if it's the fact that the driver is overridden
 or that something is missing...
 --Fitz
 news:af7cd8bb467a50921c10385ff9e92cd3$1@www.eclipse.org...
| Re: Still can't create a connection [message #595543 is a reply to message #55529] | Thu, 16 April 2009 15:12  |  |
 Fitz,
 in there with me, and we were able to get everything that I needed working.
 -Mark
| Re: Still can't create a connection [message #595555 is a reply to message #55685] | Fri, 17 April 2009 10:04  |  |
| Eclipse User  |  |  |  |  | Hooray! :)
 quickly. ;)
 --Fitz
 > Fitz,
 > working.
 > -Mark
 Current Time: Fri Oct 31 00:08:39 EDT 2025
 Powered by FUDForum . Page generated in 0.26425 seconds |
