Home » Language IDEs » AspectJ » Linux broken where Windows works?
Linux broken where Windows works? [message #64515] Mon, 24 April 2006 03:37 Go to next message
I am getting a difference in behaviour for AJDT 1.3.1 on Windows vs Linux.
Both machines are running the same in terms of:
- Eclipse 3.1.2
- AJDT 1.3.1
- MyEclipse
All of this is checked into CVS (including Eclipse .classpath and
project) for a multiproject workspace, with project source dependencies.
On Windows everything appears to be fine, with no compile time errors.
On Linux I get: "The project cannot be built until its prerequisite
ProjectX is built. Cleaning and building all projects is recommended".
Where ProjectX is an AJDT enabled project and has no errors.
If I make the offended project an AJDT project then everything is ok, but
this is only needed on Linux and is not an acceptable path forward.
Is there a difference in the Linux way of things and AJDT?
Re: Linux broken where Windows works? [message #64541 is a reply to message #64515] Mon, 24 April 2006 05:37 Go to previous messageGo to next message
There shouldn't be any difference between the two - we also use Linux
ourselves. So this sounds pretty clearly like a bug. Can you reproduce
the problem with a small test project?
Matt.
> - Eclipse 3.1.2
> - AJDT 1.3.1
> - MyEclipse
Re: Linux broken where Windows works? [message #64586 is a reply to message #64541] Wed, 26 April 2006 01:32 Go to previous messageGo to next message
Further investigation yielded that to fix the problem on Linux was to:
1. Remove aspect nature from all aspect projects
2. Build all projects (when none have aspect nature)
3. Add back the aspect natures removed in step 1
4. Build all
That works reliably.
-- Cory
Re: Linux broken where Windows works? [message #64651 is a reply to message #64586] Wed, 26 April 2006 08:53 Go to previous message
> 4. Build all
That's great, but of course it'd be even better if the problem didn't
occur in the first place. If you can reproduce this in a test project,
please raise a bug and attach it.
Matt.
Re: Linux broken where Windows works? [message #593460 is a reply to message #64515] Mon, 24 April 2006 05:37 Go to previous message
Matt.
> - Eclipse 3.1.2
> - AJDT 1.3.1
> - MyEclipse
Re: Linux broken where Windows works? [message #593477 is a reply to message #64541] Wed, 26 April 2006 01:32 Go to previous message
4. Build all
-- Cory
Re: Linux broken where Windows works? [message #593501 is a reply to message #64586] Wed, 26 April 2006 08:53 Go to previous message
> 4. Build all
Matt.
Previous Topic:3.1.1 installation problem - ajdt functionality not showing up OR needs Eclipse SDK installed
Next Topic:AJDT New Feature: Eclipse Product Export Wizard
Current Time: Fri Oct 17 04:10:23 EDT 2025
Powered by FUDForum. Page generated in 0.03889 seconds
