Home » Eclipse Projects » Mylyn » Example code for Headless Bugzilla use
Example code for Headless Bugzilla use [message #49931] Wed, 11 June 2008 17:29 Go to next message
The Example code for Headless use of the Bugzilla
API( http://wiki.eclipse.org/Mylyn/Integrator_Reference#Quick_Exa mple)
doesn't seem work for me; there is no class AbstractRepositoryTask that I
can locate. The following code seems to work, but only for a few bugzilla
(eclipse works, redhat doesn't) repositories; the rest end with a core
exception thrown when it parses the HTML:
BugzillaRepositoryConnector connector = new
BugzillaRepositoryConnector();
connector.init(new TaskList());
TaskRepository repository = new
TaskRepository(BugzillaCorePlugin.REPOSITORY_KIND,
"https://bugzilla.redhat.com/");
AbstractTaskDataHandler handler = connector.getTaskDataHandler();
RepositoryTaskData taskdata = null;
try{
taskdata = handler.getTaskData(repository, "123", new
NullProgressMonitor());
}catch(CoreException e){
System.out.println("Couldn't get task data for bug
123"+((RepositoryStatus)e.getStatus()).getHtmlMessage());
e.printStackTrace();
I'm not quite sure where to go from here
David Marple
Re: Example code for Headless Bugzilla use [message #49960 is a reply to message #49931] Fri, 13 June 2008 14:51 Go to previous message
Well I've gotten it working for at least one more. The Mozilla repository
you must remove the trailing slash from the URL, ie put
"https://bugzilla.mozilla.org", but there are still many others that don't
work.
Re: Example code for Headless Bugzilla use [message #590045 is a reply to message #49931] Fri, 13 June 2008 14:51 Go to previous message
work.
Previous Topic:Mylyn monitor doesn't capture selection and edit event?
Next Topic:Information to write a Mylyn bridge.
Current Time: Wed Oct 15 18:17:24 EDT 2025
Powered by FUDForum. Page generated in 0.04054 seconds
