Home » Language IDEs » AspectJ » How to determine the aspectj-rt version?
How to determine the aspectj-rt version? [message #53914] |
Mon, 27 June 2005 15:36  |
Andrew sent me a script that upgrades ajdt with the latest aspectj compiler (I'm testing some compiler fixes). It would be helpful if I could determine the version aspectj version included in the ajdt dev releases so I know if I have to run the script. Is this information available anywhere?
thanks
Re: How to determine the aspectj-rt version? [message #54033 is a reply to message #54020] |
Tue, 28 June 2005 11:06  |
Oh, I see now. I didn't notice that adje was org.aspectj.adje. I saw that plugin and always read ajdt. Thanks.
-barry
Matt Chapman wrote:
> On Mon, 27 Jun 2005 14:20:34 -0700, Barry Kaplan wrote:
>>Are we talking about the same thing? I'm looking for the
>>aspectj-runtime/compiler version.
>>-barry
> I think so. The AspectJ compiler gets packaged up into the
> org.aspectj.ajde plugin for use with AJDT. This is currently a manual
> process - Andy takes an AspectJ build, creates the ajde.jar etc files
> which make up the org.aspectj.ajde plugin, and checks that into AJDT. This
> is why there isn't really a precise version number associated with the
> level of AspectJ in AJDT, other than the version numbers in CVS. So as
> long as you're using the latest AJDT dev build, you can find the CVS
> version of AspectJ / ajde that it contains using the link in my previous
> post. Then from the date of this you should be able to see whether you
> need to run the script.
> Hope that helps,
> Matt.
Re: How to determine the aspectj-rt version? [message #588974 is a reply to message #53914] |
Mon, 27 June 2005 16:33  |
> available anywhere?
Hi Barry,
I don't think that information makes it into the AJDT build itself, but
the latest ajdt dev build will contain the latest version of the ajde
plugin, so you can look up when this was last updated in CVS, i.e.:
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.ajd t/AJDT_src/org.aspectj.ajde/ajde.jar
which shows ajde.jar was updated on Mon Jun 20.
Matt.
Re: How to determine the aspectj-rt version? [message #588981 is a reply to message #54005] |
Mon, 27 June 2005 17:20  |
Are we talking about the same thing? I'm looking for the aspectj-runtime/compiler version.
-barry
>>available anywhere?
> Hi Barry,
> Regards,
> Matt.
Re: How to determine the aspectj-rt version? [message #588996 is a reply to message #54014] |
Tue, 28 June 2005 04:09  |
> -barry
Hope that helps,
Matt.
Re: How to determine the aspectj-rt version? [message #589016 is a reply to message #54020] |
-barry
>>-barry
> Hope that helps,
> Matt.
Current Time: Wed Oct 08 06:03:41 EDT 2025
Powered by FUDForum. Page generated in 0.04933 seconds
