Home » Modeling » MDT (Model Development Tools) » [UML2] programmatically set the type of a newly created Parameter???
[UML2] programmatically set the type of a newly created Parameter??? [message #378091] Mon, 03 March 2008 11:41 Go to next message
Hello everyone,
I have a questions:
I've programmatically created a Parameter, and how can I set the type of
it to Integer?
I've tried as following:
1 Parameter p = UMLFactory.eINSTANCE.createParameter();
2 p.setDirection(ParameterDirectionKind.RETURN_LITERAL);
3 p.setUpper(1);
4 p.setLower(1);
5 LiteralInteger li = UMLFactory.eINSTANCE.createLiteralInteger();
6 li.setValue(3);
7 System.out.println("type" + li.getType().toString());
8 p.setType(li.getType());
9 return p;
but at line 7, the type of "li" is still null??
so how to set the type of a Parameter to a primitive tpye, such as Integer
or String or boolean?
regards
Jinhui
Re: [UML2] programmatically set the type of a newly created Parameter??? [message #378097 is a reply to message #378091] Mon, 03 March 2008 13:27 Go to previous messageGo to next message
Jinhui,
This question is more appropriate for the UML2 newsgroup (copied).
To progammatically set the type of a parameter, simply call setType(Type),
passing the desired type as an argument.
Kenn
"Jinhui" <zhuj@in.tum.de> wrote in message
news:0cf126e1bb6a4f41a1a402583bbd8e00$1@www.eclipse.org...
> Hello everyone,
> I have a questions: I've programmatically created a Parameter, and how can
> I set the type of it to Integer?
> 3 p.setUpper(1);
> 4 p.setLower(1);
> 6 li.setValue(3);
> 9 return p;
> regards
> Jinhui
Re: [UML2] programmatically set the type of a newly created Parameter??? [message #378100 is a reply to message #378097] Mon, 03 March 2008 13:32 Go to previous messageGo to next message
Jinhui,
Additionally, note that a LiteralInteger does not come into existence
knowing that its type is (or even should be) Integer. You will have to
retrieve the Integer primitive type from the UML (or Java) Primitive Types
model library in order to reference it as the parameter's type.
Christian
Kenn Hussey wrote:
> Jinhui,
> Kenn
>> Hello everyone,
>> can I set the type of it to Integer?
>> 3 p.setUpper(1);
>> 4 p.setLower(1);
>> 6 li.setValue(3);
>> 9 return p;
>> Integer or String or boolean?
>> regards
>> Jinhui
Re: [UML2] programmatically set the type of a newly created Parameter??? [message #378104 is a reply to message #378100] Mon, 03 March 2008 13:59 Go to previous message
Hi Christian,
well, I figured out this Problem too, but the problem now turned to be I
can't load the PrimitiveTypes.
See the other threads from me:
http://www.eclipse.org/newsportal/article.php?id=147&gro up=eclipse.modeling.mdt#147
btw, I am using RSA7.0.0.4.
best regards.
Jinhui
Re: [UML2] programmatically set the type of a newly created Parameter??? [message #584788 is a reply to message #378091] Mon, 03 March 2008 13:27 Go to previous message
Jinhui,
Kenn
> Hello everyone,
> 3 p.setUpper(1);
> 4 p.setLower(1);
> 6 li.setValue(3);
> 9 return p;
> regards
> Jinhui
Re: [UML2] programmatically set the type of a newly created Parameter??? [message #584802 is a reply to message #378097] Mon, 03 March 2008 13:32 Go to previous message
Jinhui,
Christian
Kenn Hussey wrote:
> Jinhui,
> Kenn
>> Hello everyone,
>> 3 p.setUpper(1);
>> 4 p.setLower(1);
>> 6 li.setValue(3);
>> 9 return p;
>> regards
>> Jinhui
Re: [UML2] programmatically set the type of a newly created Parameter??? [message #584813 is a reply to message #378100] Mon, 03 March 2008 13:59 Go to previous message
Hi Christian,
best regards.
Jinhui
Previous Topic:[UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY
Next Topic:[Announce] UML2 Tools at EclipseCon 2008
Current Time: Sun Jul 27 09:21:25 EDT 2025
Powered by FUDForum. Page generated in 0.04988 seconds
