Home » Archived » OHF » ATNA logging date parsing is broken
ATNA logging date parsing is broken [message #39526] Thu, 03 January 2008 13:54 Go to next message
Hey Matt,
Happy new year to you!
OK here's another issue. Single digit date parsing is not in the "MMM DD
HH:mm:ss" format. As soon as the year rolled over, the public ATNA syslog
gave me "malformed xml" failure messages. The XDS.b stored query I fired
executed perfectly. This is the date header on the xml:
<13>Jan 3 13:21:42 machine1 <?xml version="1.0"
encoding="ASCII"?><AuditMessage
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance".....
"Jan 3 13:21:42" is causing a problem here. As soon as I switched my
system date to Jan 10, 2008 this worked perfectly. I'm not sure I can
control this from the API exposed (can I?).
This could be a blocker for me pretty soon. Please let me know if I should
log this or its something you're already aware of and working on.
Thanks.
Sumedh
Re: ATNA logging date parsing is broken [message #39619 is a reply to message #39526] Thu, 03 January 2008 14:21 Go to previous messageGo to next message
Hi Sumedh, happy New Year to you too!
I just reran our audit tests again and the spacing is right on my tests:
<13>Jan 3 11:19:23 hostname <?xml version="1.0"
encoding="ASCII"?><AuditMessage xmlns:
xsi:noNamespaceSchemaLocation="healthcare-security-audit.xsd ">
<EventIdentification EventActionCode="E"
EventDateTime="2008-01-03T11:19:23.583-08:00" EventOutcomeIndicator="0">
<EventID code="110112" codeSystemName="DCM" displayName="Query"/>
<EventTypeCode code="ITI-18" codeSystemName="IHE Transactions"
displayName="Registry Stored Query"/>
</EventIdentification>
// snip
</AuditMessage>
I wonder if this is an environment issue. What OS are you testing with
on this?
-Matt
Sumedh wrote:
> Hey Matt,
> syslog gave me "malformed xml" failure messages. The XDS.b stored query
> I fired executed perfectly. This is the date header on the xml:
> should log this or its something you're already aware of and working on.
> Thanks.
> Regards,
> Sumedh
Re: ATNA logging date parsing is broken [message #39649 is a reply to message #39619] Fri, 04 January 2008 00:27 Go to previous messageGo to next message
I'm testing on a Win XP box with Java 6. Let me try this on Java 5 as well
and get back to you (since you're not seeing this).
regards,
Sumedh
Re: ATNA logging date parsing is broken [message #39679 is a reply to message #39619] Fri, 04 January 2008 02:36 Go to previous messageGo to next message
This is the log I see pertaining to ATNA:
DEBUG - Begin Document Retrieve.
WARN - Defaulting to IP Address for AuditSourceID. This should be set by
calling setAuditSourceId.
DEBUG - Starting Audit start messages [1]
DEBUG - Sending ActorStartStopMessage Audit message.
INFO - <13>Jan 4 02:25:03 machine1 <?xml version="1.0"
encoding="ASCII"?>.....
Looks like the spacing is correct in my case as well, but the public NIST
syslog server (http://129.6.24.109:9080/SyslogBrowser) is rejecting it
with the following message:
The syslog message should be formated like :
<PRI> MMM DD HH:mm:ss ipAddress TAG:<?xml version="1.0"
encoding="ASCII"?><AuditMessage> ... </AuditMessage>
I feel a trailing 0 on single digit dates should resolve this.
regards,
Sumedh
Re: ATNA logging date parsing is broken [message #39771 is a reply to message #39679] Fri, 04 January 2008 12:24 Go to previous messageGo to next message
Hmmm..... well I know there were some wars last year pertaining to
formatting of ATNA syslog messages and I wasn't involved in most of
those battles. However, from RFC 3164 (BSD Syslog), the standard states:
"dd is the day of the month. If the day of the month is less than 10,
then it MUST be represented as a space and then the number. For
example, the 7th day of August would be represented as "Aug 7", with
two spaces between the "g" and the "7"."
So, space padding single-digit dates *should* be correct, unless DICOM
95 states otherwise (don't believe that's the case).
Should be noted that all of our ATNA logs we did for XDS MESA
verification were done on dates > 10 in December. :)
This may be a question for Bill Majurski.
-Matt
> by calling setAuditSourceId.
> NIST syslog server (http://129.6.24.109:9080/SyslogBrowser) is rejecting
> it with the following message:
> regards,
> Sumedh
Re: ATNA logging date parsing is broken [message #39864 is a reply to message #39771] Sat, 05 January 2008 03:48 Go to previous message
Okay posted this on the IHE google groups for Bill. I'll let you know what
their response is.
Thanks.
regards,
Sumedh
Re: ATNA logging date parsing is broken [message #584111 is a reply to message #39526] Thu, 03 January 2008 14:21 Go to previous message
// snip
</AuditMessage>
on this?
-Matt
Sumedh wrote:
> Hey Matt,
> Thanks.
> Regards,
> Sumedh
Re: ATNA logging date parsing is broken [message #584124 is a reply to message #39619] Fri, 04 January 2008 00:27 Go to previous message
regards,
Sumedh
Re: ATNA logging date parsing is broken [message #584134 is a reply to message #39619] Fri, 04 January 2008 02:36 Go to previous message
regards,
Sumedh
Re: ATNA logging date parsing is broken [message #584187 is a reply to message #39679] Fri, 04 January 2008 12:24 Go to previous message
-Matt
> regards,
> Sumedh
Re: ATNA logging date parsing is broken [message #584219 is a reply to message #39771] Sat, 05 January 2008 03:48 Go to previous message
their response is.
Thanks.
regards,
Sumedh
Previous Topic:Folder creation
Next Topic:Setting "NetworkAccessPointID" on the ActiveParticipant in ATNA messages
Current Time: Fri Nov 07 07:35:54 EST 2025
Powered by FUDForum. Page generated in 0.06736 seconds
