Home » Eclipse Projects » EGit / JGit » Not possible to vote on EGit bugs?
Not possible to vote on EGit bugs? [message #538192] Sun, 06 June 2010 05:32 Go to next message
Why is it not possible to vote on EGit bugs (in Bugzilla)?
Re: Not possible to vote on EGit bugs? [message #538294 is a reply to message #538192] Mon, 07 June 2010 05:31 Go to previous messageGo to next message
http://dev.eclipse.org/mhonarc/lists/egit-dev/msg01248.html
Re: Not possible to vote on EGit bugs? [message #538317 is a reply to message #538294] Mon, 07 June 2010 06:44 Go to previous messageGo to next message
Matthias Sohn wrote on Mon, 07 June 2010 11:31
Thanks Matthias.
Perhaps a few more than 10 as the max votes per user, since it can't do any harm?
Re: Not possible to vote on EGit bugs? [message #538445 is a reply to message #538317] Mon, 07 June 2010 12:08 Go to previous messageGo to next message
We enabled bugzilla voting on EGit and JGit projects.
Thanks for asking Razz
Re: Not possible to vote on EGit bugs? [message #538469 is a reply to message #538445] Mon, 07 June 2010 12:55 Go to previous messageGo to next message
Matthias Sohn wrote on Mon, 07 June 2010 18:08
Excellent. Thanks! Smile
[Updated on: Mon, 07 June 2010 12:55] by Moderator
Re: Not possible to vote on EGit bugs? [message #538478 is a reply to message #538192] Mon, 07 June 2010 13:19 Go to previous messageGo to next message
Matthias,
I'd like to vote for 12 bugs at this point, but there's a limit of 10. Could you please increase the maximum to 100?
_da.
Re: Not possible to vote on EGit bugs? [message #538525 is a reply to message #538478] Mon, 07 June 2010 16:28 Go to previous messageGo to next message
darkangel wrote:
> Matthias,
My € 0.02 on voting:
Voting is not about making a decision on what bugs to fix and which ones,
not to fix. That decision is made by the developers. It is however helpful
input to the decision making process; it means someone will appreciate a fix
a little bit.
Having a lot of votes makes the votes less useful, hence you should decide
which bugs are dearest to you. Ten is about a number that for which you can
manage to keep your votes up-to-date.
And you don't have to use all your votes. If you only use, say two, out of
your ten votes, that may actually be more useful to you, than if you cast
all your votes. And you probably don't want to waste them on a bug that is
likely to be fixed anyway.
-- robin
Re: Not possible to vote on EGit bugs? [message #538627 is a reply to message #538192] Tue, 08 June 2010 05:06 Go to previous messageGo to next message
Okay, I'll just have to CC myself on the other two bugs for now.
Re: Not possible to vote on EGit bugs? [message #538649 is a reply to message #538317] Tue, 08 June 2010 06:33 Go to previous messageGo to next message
We decided to go for the settings used by most other projects.
If many users vote on almost all bugs the vote statistics are
less likely to help in prioritization.
So put your 10 votes on those bugs you want most. An even better way
to ensure that your favorite bugs get closed is start contributing Smile
Re: Not possible to vote on EGit bugs? [message #581239 is a reply to message #538192] Mon, 07 June 2010 05:31 Go to previous messageGo to next message
Re: Not possible to vote on EGit bugs? [message #581250 is a reply to message #538294] Mon, 07 June 2010 06:44 Go to previous messageGo to next message
Thanks Matthias.
Re: Not possible to vote on EGit bugs? [message #581267 is a reply to message #581250] Mon, 07 June 2010 12:08 Go to previous messageGo to next message
Thanks for asking :p
Re: Not possible to vote on EGit bugs? [message #581285 is a reply to message #581267] Mon, 07 June 2010 12:55 Go to previous messageGo to next message
Excellent, thanks! :)
Re: Not possible to vote on EGit bugs? [message #581302 is a reply to message #538192] Mon, 07 June 2010 13:19 Go to previous messageGo to next message
Matthias,
_da.
Re: Not possible to vote on EGit bugs? [message #581343 is a reply to message #538478] Mon, 07 June 2010 16:28 Go to previous messageGo to next message
darkangel wrote:
> Matthias,
a little bit.
-- robin
Re: Not possible to vote on EGit bugs? [message #581363 is a reply to message #538192] Tue, 08 June 2010 05:06 Go to previous messageGo to next message
Re: Not possible to vote on EGit bugs? [message #581409 is a reply to message #581250] Tue, 08 June 2010 06:33 Go to previous message
to ensure that your favorite bugs get closed is start contributing :)
Previous Topic:NPE when pasting github URL in push wizard
Next Topic:[JGit] History details
Current Time: Thu Oct 23 18:48:33 EDT 2025
Powered by FUDForum. Page generated in 0.33110 seconds
