Home » Eclipse Projects » Platform - User Assistance (UA) » Branded Infocenters on help.eclipse.org
Branded Infocenters on help.eclipse.org [message #469372] Fri, 01 June 2007 09:41 Go to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
I run the infocenters at help.eclipse.org. Actually, I run three: one
for Eclipse 2.1 (help.eclipse.org/help21), one for Eclipse 3.1
(help.eclipse.org/help31) and one for Eclipse 3.2 (help.eclipse.org/help32).
There are also plans to install a fourth infocenter: one for the latest
stable/RC.
The problem is that from a user's perspective, they all look the same,
and when users hit a docs page from a Google search, it's not obvious
what Eclipse version the docs refer to.
I read up on branding on this page [1], but I'm not quite sure where/how
to do it. I'd essentially like to just change the browser window title,
and put up a nice Eclipse-ish purple banner, similar to that on
bugs.eclipse.org, both of which would state the Eclipse version the docs
refer to.
Can anyone help me out?
[1]
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ua_help_setup_preferences.htm
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Branded Infocenters on help.eclipse.org [message #469378 is a reply to message #469372] Fri, 01 June 2007 10:13 Go to previous messageGo to next message
Setting up a banner is quite easy. You will create a file called
"plugin_customization.ini" that contains the following two lines:
org.eclipse.help.base/banner=<path_to_html_file>
org.eclipse.help.base/banner_height=<pixels>
When you launch the infocenter add the following to the end of the command:
-pluginCustomization <path_to_file>/plugin_customization.ini
Changing the title, however, is significantly more difficult. The title
comes from the name of the product that is being launched. Right now
starting the infocenter launches the "Eclipse SDK" product behind the
scenes. That's why it says "Help - Eclipse SDK" on the titlebar. All we
have direct control over is whether or not to include the "Help - " part
of the title (using
"org.eclipse.help.base/windowTitlePrefix=<true/false>"). To change the
title we would need to setup a new product to be launched that contains
the version of Eclipse in its name.
Perhaps we could add another customization attribute in 3.4 to give full
control over the title that is displayed.
Re: Branded Infocenters on help.eclipse.org [message #469383 is a reply to message #469378] Fri, 01 June 2007 10:23 Go to previous messageGo to next message
Great, I'll get going on the banner. Do you want me to open a FR for
the title as a customizable attribute?
> of the title (using
Re: Branded Infocenters on help.eclipse.org [message #469391 is a reply to message #469383] Fri, 01 June 2007 10:44 Go to previous message
That's alright, I did.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=190487
Re: Branded Infocenters on help.eclipse.org [message #560425 is a reply to message #469372] Fri, 01 June 2007 10:13 Go to previous message
of the title (using
Re: Branded Infocenters on help.eclipse.org [message #560433 is a reply to message #469378] Fri, 01 June 2007 10:23 Go to previous message
> of the title (using
Re: Branded Infocenters on help.eclipse.org [message #571289 is a reply to message #469383] Fri, 01 June 2007 10:44 Go to previous message
Previous Topic:Infocenter help
Next Topic:Improving results of dynamic help search
Current Time: Sat Jun 14 21:25:47 EDT 2025
Powered by FUDForum. Page generated in 0.05029 seconds
