Home » Archived » XML Schema Definition (XSD) » XSD v1.0.2 -- Undesired Messages
XSD v1.0.2 -- Undesired Messages [message #19554] Fri, 02 May 2003 07:11 Go to next message
Originally posted by: paechoi.earthlink.net
When I was creating an instance of XML Schema(XS) by using
the org.eclipse.xsd.XSDSchema.setDocument() from the DOM
using the org.w3c.dom.Document interface all seems well
except an unwanted messages as follows:
// ########## The unwanted messages ############
qNamePrefixToNamespaceMap.put(): start
key: [xsd] and value: [http://www.w3.org/2001/XMLSchema]
key: [xs] and value: [http://www.w3.org/2001/XMLSchema]
key: [hfp] and value: [http://www.w3.org/2001/XMLSchema-hasFacetAndProperty]
key: [null] and value: [http://www.w3.org/2001/XMLSchema]
key: [xsi] and value: [http://www.w3.org/2001/XMLSchema-instance]
I think those message came out after the setElement() method
which inherited from the org.eclipse.xsd.XSDConcreteComponent
interface.
What is happening here and how can we turn them off?
Any comments?
Pae
Re: XSD v1.0.2 -- Undesired Messages [message #19691 is a reply to message #19554] Fri, 02 May 2003 08:17 Go to previous messageGo to next message
Pae,
This looks like some old debugging messages, but I can't reproduce it and I
don't see anything like that in the current code base. What driver does this
happen with?
> interface.
> Any comments?
> Pae
Re: XSD v1.0.2 -- Undesired Messages [message #19736 is a reply to message #19691] Fri, 02 May 2003 22:50 Go to previous message
Ed,
It's my fault. It is referencing the old version, 1.0.1, in my script.
After I changed that to v1.0.2, the problem is gone. Thank you.
Pae
P.S.: Although it seems working with v1.0.2, but breaking the code
when I just tested with v1.1.0. I will have to test it more before I
make any comment on that.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3EB261D0.9C3C6F1F@ca.ibm.com...
> Pae,
I
this
> happen with?
> > interface.
> > Any comments?
> > Pae
Re: XSD v1.0.2 -- Undesired Messages [message #569109 is a reply to message #19554] Fri, 02 May 2003 08:17 Go to previous message
Pae,
happen with?
> interface.
> Any comments?
> Pae
Re: XSD v1.0.2 -- Undesired Messages [message #569159 is a reply to message #19691] Fri, 02 May 2003 22:50 Go to previous message
Ed,
Pae
> Pae,
I
this
> happen with?
> > interface.
> > Any comments?
> > Pae
Previous Topic:XSD and XPath
Next Topic:Cannot run XSDFindTypesMissingFacets in V1.1.0
Current Time: Sun Nov 09 14:21:29 EST 2025
Powered by FUDForum. Page generated in 0.03855 seconds
