Home » Eclipse Projects » Linux Tools Project » Error installing linuxtools through update manager
| Re: Error installing linuxtools through update manager [message #7522 is a reply to message #7510] |
Fri, 15 May 2009 08:37  |
On Thu, 2009-05-14 at 22:00 +0000, Pankaj Gupta wrote:
> I was finally able to use the update manager to install the linux tools.
> In order to make that work, I had to run eclipse as the super-user.
That doesn't make any sense if you extracted eclipse from an eclipse.org
download into some directory in your home directory.
> Unfortunately, when I use the OProfile, I don't get any output. Instead, I
> get an error:
> FATAL: An error occurred with opxml.
> Reason: The opxml binary cannot be read or executed. Either your user does
> not have sufficient permissions, or the install script was not run.
> I'm not able to find the opxml binary, although I did install OProfile
> using install-noconsolehelper.sh.
consolehelper isn't a Debian thing AFAIK. Kent will be able to provide
more guidance here.
Andrew
| Re: Error installing linuxtools through update manager [message #566062 is a reply to message #7478] |
Wed, 13 May 2009 17:46  |
Andrew,
Thanks for your response. I'm probably behind a proxy server. However,
when I append content.jar to the address and try to access that through a
web browser, it allows me to download the jar file. So I don't know why it
wouldn't work with Eclipse update manager.
I'll appreciate any suggestions you may have.
Thanks!
| Re: Error installing linuxtools through update manager [message #566106 is a reply to message #7500] |
Thu, 14 May 2009 18:00  |
get an error:
| Re: Error installing linuxtools through update manager [message #566125 is a reply to message #7510] |
> get an error:
more guidance here.
Andrew
Current Time: Mon Nov 03 08:14:24 EST 2025
Powered by FUDForum. Page generated in 0.07054 seconds
