Home » Eclipse Projects » Standard Widget Toolkit (SWT) » rich tooltips/managing colors with FormText
rich tooltips/managing colors with FormText [message #551364] Fri, 06 August 2010 03:56 Go to next message
No sure which forum to post in. It has to do with SWT, JFace and UI forms.
I wish to have rich tooltips with very simple markup such as bold, bullets and colors. Ideally I would like to do it the Swing way...
I believe the only way is to extend org.eclipse.jface.window.ToolTip and then use one of these:
- SWT Browser. Tried a snippet. Tooltip had a scrollbar --> no way. Advantage: plain portable html.
- StyledText. Looks too complicated to me!
- UI forms FormText. Looks ok! But...
Or is there already a ToolTip implementation on which I can set a marked up text? I am not the only one wanting this right???
Anyway, for now I came to the conclusion that I need a UI forms FormText widget inside the JFace ToolTip.
But when I want to use color red or color yellow for example, I have to write this code:
FormText formText = toolkit.createFormText(form.getBody(), true);
FormColors colors = toolkit.getColors();
colors.createColor("red", colors.getSystemColor(SWT.COLOR_RED));
formText.setColor("red", colors.getColor("red"));
The last two lines I have to repeat for each color that I want.
Is there an easier way or should I just do this?
Re: rich tooltips/managing colors with FormText [message #551376 is a reply to message #551364] Fri, 06 August 2010 04:24 Go to previous messageGo to next message
For interested people, here is my current tooltip implementation and a snippet that uses it:
package nl.hm.ilja.ui;
import org.eclipse.jface.window.ToolTip;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Event;
import org.eclipse.ui.forms.FormColors;
import org.eclipse.ui.forms.widgets.Form;
import org.eclipse.ui.forms.widgets.FormText;
import org.eclipse.ui.forms.widgets.FormToolkit;
 * A tooltip for a {@link Control} which shows a text that can be marked up
 * using Eclipse UI Forms {@link FormText} tags.
 * <p>
 * Our goal is to have a fancy tooltip with simple html markup like in Swings
 * tooltips. This is the best implementation I could think of; see my forum post
 * <a href="http://www.eclipse.org/forums/index.php?t=msg&goto=551364&S=15e3e271d91f521d26beb7b2ba809148#msg_551364"
 * >here</a>. I wouldn't cry if we could later switch back to a true html markup
 * tooltip, this could be easier if we separate tooltip view from data, see
 * issue: OBLII-154.
 * <p>
 * This class supports the following colors. Just <a
 * href="http://blog.platinumsolutions.com/node/155">add more</a> when needed!
 * <ul>
 * <li>"red": SWT.COLOR_RED</li>
 * <li>"yellow": SWT.COLOR_YELLOW</li>
 * </ul>
 * <p>
 * Idea was taken from <a href="http://www.ibm.com/developerworks/opensource/library/os-eclipse-forms/index.html"
 * > this blog</a>.
 * <p>
 * For more info on how to use see the {@link FormText} javadoc, the blog or <a
 * href="http://demo.spars.info/j/frameset.cgi?compo_id=150159&mode=frameset&ref=3&method=34&q=org&hl=org&CASE=0&MORPHO=1&location=1111111111111111111&LANG=1"
 * >this example</a>, or my {@link ManualTestFancyToolTip}.
 * @author Henno Vermeulen
public class FancyToolTip extends ToolTip {
	private final String text;
	public FancyToolTip(Control control, String text) {
		super(control);
		this.text = text;
	protected Composite createToolTipContentArea(Event event, Composite parent) {
		FormToolkit toolkit = new FormToolkit(parent.getDisplay());
		Form form = toolkit.createForm(parent);
		form.getBody().setLayout(new FillLayout());
		// Parse tags but do not expand URLs because they don't make much
		// sense in a tooltip.
		formText.setText(text, true, false);
		addColors(formText, colors);
		return parent;
	private void addColors(FormText formText, FormColors colors) {
		addSystemColor(SWT.COLOR_RED, "red", formText, colors);
		addSystemColor(SWT.COLOR_YELLOW, "yellow", formText, colors);
	private void addSystemColor(int colorCode, String key, FormText formText,
		colors.createColor(key, colors.getSystemColor(colorCode));
		formText.setColor(key, colors.getColor(key));
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class ManualTestFancyToolTip {
		final Display display = new Display();
		Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable() {
			public void run() {
				Shell shell = new Shell(display);
				shell.setLayout(new FillLayout());
				new ManualTestFancyToolTip().createPartControl(shell);
				shell.pack();
				shell.open();
				while (!shell.isDisposed()) {
					if (!display.readAndDispatch())
						display.sleep();
	protected static void createPartControl(Shell shell) {
		Text text = new Text(shell, SWT.NONE);
		text.setText("Hover over me to show tooltip");
		String string = "<form><p>This is a simple <b>test</b></p>"
				+ "<p>And this too.</p>"
				+ "<p>And <span color=\"red\">here</span> are "
				+ "some <span color=\"yellow\">colors</span>.</p>"
				+ "<p>Test with list items:</p>"
				+ "<li>A default (bulleted) list item.</li>"
				+ "<li>Another bullet list item.</li>" + "</form>";
		new FancyToolTip(text, string);
		shell.setSize(300, 200);
Re: rich tooltips/managing colors with FormText [message #551383 is a reply to message #551376] Fri, 06 August 2010 04:27 Go to previous messageGo to next message
I think JFace-Text has a component they use to display the JavaDoc
information and it understands HTML-Commands.
Tom
Am 06.08.10 10:24, schrieb SlowStrider:
> * * <p>
> Swings
> forum post
> * <a
> href=" http://www.eclipse.org/forums/index.php?t=msg&goto=55136 4&S=15e3e271d91f521d26beb7b2ba809148#msg_551364"
> markup
> * issue: OBLII-154.
> * * <p>
> needed!
> * <ul>
> * </ul>
> * * <p>
> href=" http://www.ibm.com/developerworks/opensource/library/os-ecli pse-forms/index.html"
> * > this blog</a>.
> * * <p>
> or <a
> href=" http://demo.spars.info/j/frameset.cgi?compo_id=150159&mo de=frameset&ref=3&method=34&q=org&hl=org& ;CASE=0&MORPHO=1&location=1111111111111111111&LA NG=1"
> * * @author Henno Vermeulen
> super(control);
> this.text = text;
> @Override
> parent) {
> return parent;
> formText,
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> Runnable() {
> public void run() {
> shell.pack();
> shell.open();
> display.sleep();
Re: rich tooltips/managing colors with FormText [message #551384 is a reply to message #551383] Fri, 06 August 2010 04:28 Go to previous messageGo to next message
Could be JDT-UI also - not sure yet.
Tom
Am 06.08.10 10:27, schrieb Tom Schindl:
> Tom
>> * * <p>
>> Swings
>> forum post
>> * <a
>> markup
>> * issue: OBLII-154.
>> * * <p>
>> needed!
>> * <ul>
>> * </ul>
>> * * <p>
>> * > this blog</a>.
>> * * <p>
>> or <a
>> super(control);
>> this.text = text;
>> @Override
>> parent) {
>> return parent;
>> formText,
>> Runnable() {
>> public void run() {
>> shell.pack();
>> shell.open();
>> display.sleep();
Re: rich tooltips/managing colors with FormText [message #551389 is a reply to message #551384] Fri, 06 August 2010 05:02 Go to previous messageGo to next message
Thank you Tom. I tried some googling and found for example this blog with hovers over a text editor.
My fear is that it will take me several hours or longer of searching google and noodling around with code until I can turn this info into a simple html tooltip on an SWT control... At least my time estimate is unclear.
I was hoping someone knew an out of the box solution. Otherwise for the moment, I think i'll stick to the FormEditor markup which seems to work good enough at the moment.
[Updated on: Fri, 06 August 2010 05:03] by Moderator
Re: rich tooltips/managing colors with FormText [message #772362 is a reply to message #551364] Thu, 29 December 2011 10:52 Go to previous messageGo to next message
I originally solved my problem by extending org.eclipse.jface.window.ToolTip and using a form with formtext. Now I want some real html and I think this might be easier than I originally thought with the SWT browser control, because the following snippet is quite easy and works like a charm:
http://git.eclipse.org/c/platform/eclipse.platform.swt.git/tree/examples/org.eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet136.java
Re: rich tooltips/managing colors with FormText [message #772642 is a reply to message #772362] Fri, 30 December 2011 04:18 Go to previous message
I tried using a Browser control inside a org.eclipse.jface.window.ToolTip. This is easy, however you have the problem that it cannot calculate it's own size so that the contents fit nicely (https://bugs.eclipse.org/bugs/show_bug.cgi?id=232501) which is not nice for tooltips with dynamic content. You can provide a fixed size e.g. by overwriting computeSize.
So I think the best option for dynamic content is using a custom ToolTip with SWT controls or having a look at the Javadoc tooltip which Eclipse uses.
Previous Topic:ComboBox in Popup window
Next Topic:Help regarding image manipulation using eclipse plugin
Current Time: Mon Oct 27 06:05:35 EDT 2025
Powered by FUDForum. Page generated in 0.03729 seconds
