Home » Archived » DSDP - Real-Time Software Components (RTSC) » Timing of deleting instance from the internal queue
Timing of deleting instance from the internal queue [message #549808] Wed, 28 July 2010 01:05 Go to next message
Please assume Mod is characterized by @InstanceFinalize.
If Mod_delete/destruct() is called for runtime-created module instance, Mod_Instance_finalize is called.
Now question is :
Is this true that the Mod_Instance_finalize() is always called after clearing the instance registration from the internal Mod instance queue, which it can be searched by the following loop.
«Mod»_Handle obj;
/* loop over all runtime created instances managed by «Mod» */
for (obj = «Mod»_Object_first(); obj != NULL; obj = «Mod»_Object_next(obj)) {
: /* use «Mod»_handle obj */
-Kawada
Re: Timing of deleting instance from the internal queue [message #550503 is a reply to message #549808] Fri, 30 July 2010 10:37 Go to previous message
Yes.
Mod_delete() eventually calls Core_deleteObject() which is defined in
the xdc.runtime package; see Core-mem.c. You can see from this function
that object deletion roughly proceeds as follows:
1. remove the instance from a its linked list
2. call the module's finalize function (if one is defined)
3. free up the memory of the instance object itself
On 7/27/2010 10:05 PM, Naoki Kawada wrote:
> Hi
> Now question is :
> «Mod»_Handle obj;
> Regards,
> -Kawada
Previous Topic:Problem with Log_write generation
Next Topic:Release notification for XDCtools 3.20.02
Current Time: Thu Sep 18 18:47:54 EDT 2025
Powered by FUDForum. Page generated in 0.02830 seconds
